Shimano SM-CB90 barrel adjuster and Mini-V
Hi, installed Tektro 926 mini-v on a 96 Cannondale. I also put Jagwire inline Pro barrel adjusters. With the brakes properly adjusted I can’t get enough slack to allow me to open the noodle. Anyone have experience with the Shimano SM-CB90 in-line barrel adjusters? Will the “release” give me enough slack to open the noodle? Below is a picture of the item.
I’ve just used adjustable noodles
Quoted: 2495 Post(s)
Liked 738 Times
Those Shimano barrel adjusters look pretty nifty. I might get a couple. I would expect that they will work for what you want to do. That said, although it is sometimes a bit of a fight, you should be able to get the noodle undone without any quick release. I set up the barrel adjusters so they can give that little bit of room that is needed to pull the nipple free. That is my way of saying I would look hard at the brake setup before spending more money. What you have already can do the job, the Shimano thingy's just make it easier. The run to the rear brake especially can ... can make one use words that come out all in asterisks on BF.
I was toying with that idea but further reading about those suggest the long term viability wasn’t that great so I went with the Jagwire inline Pro’s. The Jagwire works but I would have to screw and unscrew the barrel every time I needed to pull the wheels off to transport the Tandem.
To be clear, I have both in-line barrel adjusters and adjustable noodles. The adjustable noodle on the rear is more convenient because the adjustment is right where you need to open the brake to remove the wheel. Never had an issue with adjustable noodles over many years.
Installed these, makes getting the noodle undone lots easier while keeping the pad position where you set it. In the words of the Mandalorian, “This is the Way”.
