Steel Fork Bent, Can It Be Repaired?
Quoted: 702 Post(s)
Liked 672 Times
I realize that it would be better to replace the fork, but I would like to keep the bike original.
Is it possible to repair it?
There are no other visible signs of damage to the frame or fork, head-tube looks to be free of damage. It's nothing special, just high tension steel from a 1970's era Raleigh Super Grand Prix.
framebuilder
Yes it makes sense to try and bend the blades back. The original straight fork blades were bent a lot to get the curve. Where do you live in Michigan? I'm in the SW corner just above South Bend Indiana if you want to bring it by. I've got all the tools and knowledge.
Quoted: 702 Post(s)
Liked 672 Times
Looks to be about a 2 hour drive to South Bend, I'm wondering if I can bend it back myself?
Although I'd love to see your shop.
framebuilder
The problem is to know when to bend until everything is in the right place. There are a lot of checks. For starters you need to bend both blades back until they have the same rake as they originally had. I have a fixture to accurately measure the rake. Then you have to check that both blades have the exact same rake and furthermore bend the blades so the dropouts are equidistant to the steerer's centerline. And finally you have to make sure that the dropout faces are exactly parallel to each other. For this we use Campy H tools. Park makes some dropout alignment tools but they are not accurate enough to my liking. And then we have to check with a true wheel to see that it centers. The rebending process may have made one blade longer than the other. A bit of filing can center the wheel again. And since one aspect can move after another one is bent, it is necessary to repeat the whole process until the fork passes all tests without more tweaking.
My frame shop is in Niles and you are welcome to come over as long as you don't bring the Coronavirus with you. I'll walk you through it. I'd be willing to bet that you could have driven back and forth several times in the time it would to figure out how to do it yourself with any accuracy.
Likes For Doug Fattic:
Quoted: 702 Post(s)
Liked 672 Times
Thank you. There's no urgency so when things cool down, hopefully soon, I'd love to stop by.
Quoted: 4200 Post(s)
Liked 3,854 Times
branko 76- I would strongly consider taking Doug up on his gracious offer. Besides repairing the fork and learning a lot along the way Doug is a really good person and I'm sure you'll enjoy his company. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Messrs Fattic and Stewart are more knowledable than me, but it looks to me like the steerer is bent just above the fork crown. That is something that "nothing special" forks are vulnerable to. Not so easy to fix, but can be done with an appropriate mandrel.
Likes For Sluggo:
Liked 3,854 Times
Hard to tell is the steerer is bent right at it's base or if the crown is where the twist is, besides the likely blade bends. I've "fixed" steerer bends (to a degree, pun intended) by re facing the crown race seat. Andy
AndrewRStewart
AndrewRStewart
Liked 3,854 Times
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
clamp steerer in vise using blocks with blades horizontal. lay 4 or 5 spare sokes
across blades in intervals to use as a visual guide as to where to make corrections.
I learned it from Keith Lippy when he was the instructor at a regional occupational program
for bike repairs in 1972 in San Diego. worked in shops for 26 yrs. and straightened
at least 100 forks that way. tried to walk Branko thru the process on another forum
that's why I brought it up.
Liked 3,854 Times
Steve- Good idea. Much like what I've done but with a few straight lengths of whatever was laying about. Never considered using spokes. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,696 Times
interesting variant on winding sticks https://www.google.com/search?q=wind...iw=877&bih=487
Liked 3,854 Times
https://www.bikeforums.net/bicycle-m...ard-right.html Here's a link to my reply to a fork alignment thread many years ago. Some might find it interesting, others might not Andy
AndrewRStewart
AndrewRStewart
When I was 17 a pakistani man drove a Datsun Sunny in front of my Lambretta Li 150 by doing a right turn.
It had a fork with a normal axle. Fork was bent back and the scooter's handling was severely compromised.
After my leg healed I removed the fork and stuck it in the drain grid outside the house and heaved on it until it looked right.
Job done.
Job done.
