New grips don’t have end plugs?
I’m a bit old school and still use bar ends.
I recently ordered some new grips (single lock ons) and intended on cutting the closed end and using a plug to enable installation of my bar ends. It seems however that the internal structure of the grip is such that you can’t simply cut the grip as the internal structure has a solid end plate.
Im now looking at alternative grips and there don’t seem to be many with basic plastic plugs. Some seem to have these removable metal plugs which I’m not sure whether they are bar end compatible?
Can anyone advise what what I should be looking for in a grip that will work with bar ends? Appreciate any advice or even recommendations on particular grips.
Thanks
Thanks
I.m not sure I understand your issue. Bar ends being the funky 'grips' that provide an alternate way to position your hands, right.?? Now, what exactly are you trying to achieve.??
If I understand right after reading it 18 times, check out Lizard Skin grips.
Quoted: 1088 Post(s)
Liked 1,024 Times
Just go to the bike shop and ask for a left over pair for the bar ends. Lock on grips are integrated systems and while the ends can be popped off the goal of them is to make the whole riding experience better and safer by having plugs that actually stay in place. Every basic set of foam or rubber grips has a bar plug just like they always did.
Quoted: 1188 Post(s)
Liked 1,154 Times
A lot of the Ergon grips will do what you want.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,682 Times
Thanks
Thanks
Many double lock grips will work with barends and you don't have to cut them. Many come with bar plugs too. For the best in bar plugs, look into BMX plugs.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Thanks
Thanks
If you are using lock-on grips, why can’t you just slide them in to make room in the ends for the bar ends. Why would you have to cut anything?
Why do you need a plastic plug?
Bikes: everywhere
Liked 7,682 Times
Bar plugs are nice to have, even with barends on. I like to go for the expander type. Odyssey are nice and cheap.
Liked 1,154 Times
