Bikesdirect Mini Velo upgrade thread
Old 05-31-11, 10:35 AM
  #101
james_swift
All ur bike r belong Enki
james_swift's Avatar
Originally Posted by NormanF
Panaracer is an excellent brand.
No doubt about that, but after the 2nd flat due to glass puncture just last weekend, I've resigned the tires and concluded that fast, feather-weight tires and urban streets simply do not mix.
Now that I'm back on the 65psi/100psi (front/back) Kenda Kwest tires, I'm really noticing the rolling resistance and rotational weight. The Panaracers are road scorchers by comparison, but the fastest tires in the world won't make any difference when you're slowing down for every bump and rail car track, or stuck on the side of the road having a wrestling match with a tire that is reluctant to be unmounted.
james_swift is offline
Old 06-07-11, 10:02 PM
  #102
punkgeek
Does anyone know the length of the stock stem on this bike? I'm thinking about swapping mine for something longer.
punkgeek is offline
Old 06-07-11, 10:27 PM
  #103
rcnute
90mm.
rcnute is offline
Old 06-08-11, 11:52 AM
  #104
nerobro
So what did YOU do to it?
Bikes: 2006 Fetish Penna, 2014 Fuji Cross 2.0
Well, I got mine. And I did my first "upgrade". Which was making the brake pads actually touch the rims.
I already bought a threadless adapter. And I have bars to put on it. I need to decide what size stem to use.
How light have you guys gotten the bike down to?
nerobro is offline
Old 06-09-11, 10:36 AM
  #105
hubcap
One Man Fast Brick
hubcap's Avatar
Bikes: Specialized Langster, Bianchi San Jose, early 90s GT Karakoram, Yuba Mundo, Mercier Nano (mini velo), Nashbar Steel Commuter, KHS Tandemania Sport
Has anyone got a set of fenders on one yet?
hubcap is offline
Old 06-09-11, 11:18 AM
  #106
Kabir
Kabir's Avatar
Bikes: Downtube IXNS
There seems to be enough clearance to put a set of fenders on, such as planet bike 20". However, the caliper brake uses recessed nut. To put the fenders on in a perfect way, you need Sheldon fender nuts.
I just learned that the hard way after messing with my bike and fenders for an hour.
Kabir is offline
Old 06-12-11, 12:25 PM
  #107
martinus
martinus's Avatar
Liked 6 Times in 6 Posts
Is that the, 48 or the 53 ? ... what was worng with the brakes ? cable tension issue ? ... or the pads where too low in the caliper...
martinus is offline
Old 06-12-11, 12:30 PM
  #108
rcnute
Not sure if this has been mentioned but the bolts on the stock brake levers leave deep gouges in the bar when the clamp is tightened. I swapped mine out for Cane Creeks.
rcnute is offline
Old 06-12-11, 04:20 PM
  #109
martinus
martinus's Avatar
I don't really see a problem there ... the handlebar *might* be a little on the soft side. As long as the levers dont slide down, who cares ... its all under the bar tape, no?
martinus is offline
Old 06-12-11, 05:56 PM
  #110
james_swift
Noticed the same when I changed-out my brake levers for Tektros.
Old 06-12-11, 06:41 PM
  #111
rcnute
All things being equal I'd rather not have deep gouges in an aluminum bar if only for safety.
rcnute is offline
Old 06-12-11, 09:46 PM
  #112
NormanF
Quoted: 147 Post(s)
Liked 8 Times in 8 Posts
Tektro R365 brakes are solid on a mini velo. Standard Shimano BL R770 brakes will work with that brakeset. And the price isn't too bad for the quality and safety you're buying for your bike.
NormanF is offline
Old 06-13-11, 02:43 AM
  #113
nerobro
The pads cleared the rim due to being to low on the caliper arms. Most bikes come with that at least vaguely adjusted right.
If the bolt is to long. Trim the bolt.
nerobro is offline
Old 06-13-11, 03:00 PM
  #114
Kabir
Kabir's Avatar
For folks who are still using the stock brake levers, I notice that my right lever's QR pin holder is plastic and it is broken on arrival. It still stops the lever when released but off a bit. It is just a matter of time before the holder is completely broken. I am upgrading them 'cause I need a set of small hand levers anyway. Why didn't them put on a small version on small frame?
Kabir is offline
Old 06-14-11, 10:39 AM
  #115
cedar_lake
All right- I ordered my Nano today (Black, big size) and I can't imagine it will stay stock for long. Anybody thought about building a 406 wheel with an ENO hub for fixie fun?
cedar_lake is offline
Old 06-14-11, 12:14 PM
  #116
james_swift
I think about it all the time, but every time I take out my fixed sub-19lb Xootr Swift for a ride, I begin to have serious doubts as to how fun a ~24lb fixed-gear Nano would be.
If only the frame were a lot lighter.
File Type: jpg
Old 06-14-11, 05:30 PM
  #117
Dynocoaster
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times in 6 Posts
How much would it cost to have a wheel built like that?
Speed Uno
Dawes Kingpin 2speed
Dynocoaster is offline
Old 06-15-11, 09:41 AM
  #118
hubcap
One Man Fast Brick
hubcap's Avatar
Count me among those that experienced a flat on their first real ride on this bike.
I tooled around on the bike in the driveway a bit previously, but last night was the first time I took it out for a real ride. I flatted a couple miles from my house. I knew of this issue that others have had and even ordered some rim tape that should be arriving tomorrow, but I risked it anyway and it bit me.
I was in a hurry to get somewhere and grabbed the bike without much thought (and without a flat repair kit). I was only going a few miles, right? Needless to say, I was late for where I was going since I went ahead and walked the rest of the way there and ended up walking the whole way home late last night. :-(
I have not had a chance to inspect the wheel yet, but I presume it is most likely the exposed spoke nipple issue.
hubcap is offline
Old 06-15-11, 09:49 AM
  #119
james_swift
You've just completed your initiation process. Welcome to the wonderful world of Nano ownership.
Old 06-15-11, 09:52 AM
  #120
james_swift
The custom 406 fixed-gear wheel I had built for my Swift by Wheelsmith cost $250, and that was with a $30 Surly track hub. The Eno hub retails anywhere from $160 to $180. So to answer your question, more than the cost of the bike itself.
Old 06-15-11, 11:51 AM
  #121
Kabir
Kabir's Avatar
Thanks to the warnings, I skipped this process entirely. My rim tape came after my bike and I didn't even dare to ride out far before it came.
Kabir is offline
Old 06-15-11, 01:10 PM
  #122
cedar_lake
Yeah I'm always on the lookout for a cheap(er) swift but haven't found what I was looking for yet. I decided a nano in the stable for now is better than no small-wheel fun at all!
Old 06-15-11, 02:23 PM
  #123
nerobro
So I should go buy some cloth rim tape eh? :-) I'll be buying a new stem tonight too.
nerobro is offline
Old 06-15-11, 02:39 PM
  #124
Kabir
Kabir's Avatar
$5-6 for even just saving one flat, I would say it is well worthy it. The stock tape is quite narrow and slippery. No wonder it moves around. Now, the weather is warm. Removing the tires is quite easy.
Kabir is offline
Old 06-15-11, 04:20 PM
  #125
clanke01
Bikes: Dahon Mu Uno, Mercier Mini Velo Nano, 99' Haro Cyclocross
Which stem(s) are you looking at? I've been looking around too.
clanke01 is offline
