Headset service cost
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
Being quarantined I thought it would be a good time to start servicing my bicycles. With the help I've gotten on here I've been able to clean and put new bearings in two of my bikes bottom brackets and wheel hubs. I'm not sure if I want to tackle doing the headsets so I'm wondering what a fair price would be to have a shop do this?
Quoted: 5888 Post(s)
Liked 3,471 Times
If you can overhaul a bottom bracket and hubs, you can overhaul a headset.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
Headsets are easy...easier than a bottom bracket. Go for it.
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 677 Post(s)
Liked 459 Times
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
Headset wrench like these. I think the 32/36mm works for the Sequoia. But not the Miyata.
Quoted: 702 Post(s)
Liked 672 Times
The Shimano requires a special set of wrenches that can be found on ebay.
for the other one, you'll need to measure the nuts. They're typically 30, 32 and/or 36mm
for the Shimano
for the Shimano
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 702 Post(s)
Liked 672 Times
There is only one size Shimano with the scalloped nuts
Quoted: 677 Post(s)
Liked 459 Times
Likes For robertj298:
Quoted: 702 Post(s)
Liked 672 Times
I just saw these on ebay, looks custom made and reasonably priced
https://www.ebay.com/itm/Headset-wre...QAAOSwVMFdd7xh
Likes For branko_76:
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 1639 Post(s)
Liked 829 Times
Please oh please don't go the vise-grip route with your poor headsets!
Only philistines would use such tool on a headset!
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 472 Post(s)
Liked 1,028 Times
I trust you have a good metric vernier caliper so you can measure the parts and know what size wrenches you need. Mm?
So, for the hex parts either purchase the right wrenches (you could need two of the same, ex: 36mm, or two sizes) or find a co-op with them. If you buy, buy good ones. Cheap/bargain wrenches will not fit snugly and will bend from the forces you need.
For the Shimano HS either purchase them or see if one of us will loan em. Anyone near by? Put out the call. Great coffee, fresh cinnamon rolls, and a pack of TP as a thanks.
Likes For Prowler:
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
I can assemble the headset just fine, the BB I needed help with as they took it apart for shipping even after I ASKED them not to. I didn't have the right tools for that.
I believe I do now...
Quoted: 1106 Post(s)
Liked 1,327 Times
Purists will say no.
Practical people will say yes, of course.
There are two issues:
a) will it work (yes)
b) will it mar the headset (not if you are careful)
For b), if possible use a spanner with flat jaws, that fits tightly against the projections of the locknut. Carefully snug it down until it is tight enough not to slip, make sure the spanner is aligned with the locknut (I put use hand around it and feel with fingertips where the spanner grips the nut), and take it off. Especially if all you have is a vise-grip, use a pair of bits of thin ply, soft enough to crush/cushion/grip the locknut. Bits from the boxes satsumas come in are excellent.
Shimano using this type of locknut and cup configuration was the height of hubris[1]. I bought the special spanners when they were cheap, but before that I just used normal ones and care (and grease on the the threads - always. Always. ALWAYS.)
[1] internal cable routing is probably second, but lots frame makers have made that sin, only Shimano would use a birthday cake as a model for a bicycle part.
Quoted: 1607 Post(s)
Liked 2,216 Times
Is the headset on the Sequoia use loose bearings? It says it is sealed. Does that refer to a seal between the cup and "cone?"
As my mechanic Uncle Joe used to say, "Proper tools give good results". Which I never fully understood til I met this one girl...uh never mind, a story for different forum.
Back on topic, the '86 Ironman came with that style Headset. I used a rag and huge wrench. It works , but be careful as it doesn't take much to jack it up.
BTW, I ended up replacing that headset with a standard style nut, but if I were you I'd get the correct wrench if I planned on using the star style nut. Because when you overhaul headsets and it can get tricky. Too loose and there's a chance (after many miles) of ruining the headset. Too tight and it's like riding a unicycle and I don't know how to ride a unicycle. But for most DIY wrenchers that's the fun of it. You get it just right and you feel confident about your build. Ultimately you should get the correct tool.
Quoted: 1372 Post(s)
Liked 1,751 Times
Head sets are easier to work on than bottom bracket and/or wheel hubs, in my opinion. Have a look a Head Set Rebuild and see if that bolsters your confidence. My advice is do it yourself...
Useless Member
Quoted: 380 Post(s)
Liked 181 Times
I've owned several bikes with the scalloped headset nuts. I've never purchased the tool. And I've never buggered them up either. Where there is a will, there's a way.
