Right jersey fitting?
I'm new on this forum, so first of all hello to everyone.
I have a question regarding jerseys I bought recently. I'm not sure if they fit the way they are supposed to.
The blue jersey seems a bit short on the waist and tight on the neck, it puts a bit of pressure on the throat when zipped all the way up.
The red jersey is a little loose, but comfortable.
They are both BL brand (although different logo, so I'm not sure if it really is the same brand).
They are both size M.
I can't attached photos, but if you remove the space from URLS, it wiill work, so take a look and tell me what you think. Thanks.
Spoiler
I was unsure if the blue jersey was too short on the front size, it seems to end just an inch below the navel.
Problem with the photos is I could not paste the valid urls, because of the newbie limit. So I added the urls with the space after the 'https', you could see them if you c/p the url in address bar and remove the space. I know it's a chore, but I really wanted to hear forums opinion .
Quoted: 2952 Post(s)
Liked 3,106 Times
Correct. A good jersey is cut to be comfortable in a riding position. And I prefer mine snug. Tight actually. If it's loose, it will flap in the wind, which is both annoying and inefficient.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Fit is all personal, but if it is uncomfortable, it doesn't fit properly.
I'm a big guy, and I've got wide shoulders and neck, so I size up and as such jerseys on me tend to fit snug up top and looser around the belly. That said, I got a couple I cannot zip all the way up to my neck, which otherwise fit well so I keep them.
LR÷P=HR
Quoted: 848 Post(s)
Liked 1,161 Times
For me, the red is too short, and the blue even shorter.
How tall are you?
Barry
How tall are you?
Barry
Quoted: 4559 Post(s)
Liked 2,798 Times
Spoiler
I have a couple of similar jerseys from Pearl Izumi. Yeah, the zipper can feel a bit snug at the throat. I usually unzip it to the suprasternal notch, the hollow at the base of the throat just above the sternum/clavicle. I'm not racing so nobody is going to dock my check for failing to zip up before the finish line. And I doubt pulling the zipper an inch or so down will cost me any KOMs -- I'd need a better engine more than a more aero jersey for that.
Quoted: 811 Post(s)
Liked 1,946 Times
^^^^ Welcome to the world of cycling where buying apparel is exasperating at first. Race fit or Pro fit will be extremely tight on most non-pro or non-Cat racers. You might want to consider Club Fit for jerseys. They are a little more generous in the neck and torso for bigger riders. Also, manufacturers have their own sizing, nothing is uniform. For instance, I am usually an XL in US sizes but will have to size up to XXL or even XXXL with Chinese or Euro jerseys.
