New Shimano cassette missing rivet pin
Just purch'd a new 7-speed HG-41 cassette from an eBay bicycle-parts seller.
Noted that one of the three rivet pins is is missing (see rear photo).
Looking at from view may reveal why -- the spacer has no provision for third pin.
Not sure how common this is.
But won't get a flush mounting for rear/freehub interface (not without adding a minor shim or similar)
EDIT:
I just stuck a toothpick in the hole, and it goes in about 2.5mm before encountering resistance (pin from the top spacer??).
EDIT:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Think of the weight savings. Now you’ll have more time to wave at people while riding on the sidewalk. I seriously hope you’re riding carbon wheels!
Likes For AdkMtnMonster:
Quoted: 1324 Post(s)
Liked 927 Times
Remove the other two pins and you can take the entire cassette apart for a thorough cleaning of the individual cogs when they get dirty/grunged up.
Cheers
Cheers
If you use a spacer, to fit it on a wider freehub body, the spacer will need to be shaped to accommodate the rivets. If you have a spacer that does not accommodate the rivets, it's fairly easy to check how the rivets align with the spacer (when they're mounted on the freehub) and file those spots down a little to make room.
Likes For HTupolev:
Quoted: 1074 Post(s)
Liked 295 Times
You’re worrying over a non-issue. The base of the splined freehub body isn’t a smooth flange. It’s notched to provide clearance for the rivets. It’ll fit just fine as it is.
Uh.... no, toots ... I ain't ... 'cause some of us "non-issuers" ...
Hmmm .... I think a small pieces of Al foil, folded over 3x may work.
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Shimano Spacer
IIRC a SRAM compatible freehub plus one of these will fit a Shimano cassette.
my Mavic wheels came with just such a 3 notch spacer.
Plus a 1mm spacer, never did work out what that’s for!
Barry
Barry
Likes For Barry2:
Liked 927 Times
Here's an image of a 6-speed Uniglide cassette I took off a wheel. When I took it off the cogs were a black/brown colour from the buildup of the grunge on them. Being able to take that cassette apart enabled me to do a thorough cleaning of all the individual parts. This is what was under that grunge. I wish I'd taken a Before image.
I now do this with all my cassettes = remove the pins so I can use individual cogs and spacers.
Cheers
Cheers
