Seat post bolt for early 50s rebuild
Brit Rider
Bikes: Mercian King of Mercia (1983), Balance XR-550 (1993), Surly Cross Check, 1948 Condor British steel lightweight.
Quoted: 33 Post(s)
Hi
Rebuilding an early 50s classic british lightweight. Balancing mix of ridability with authenticity. Usually I would go for campag bolt but not sure its ideal for this fitting. Any suggestions?
Regards
arb
Regards
arb
Likes For Andiroo99:
Disraeli Gears
Inside diameter and the nominal span across the lugs might be useful info to have.
Here's the seat post bolt from a 1950 R.O. Harrison frame:
The bolt is 35 mm (1-3/8") long below the head, with a rounded head (no flats or other means of holding it) that's keyed as you can see. The unthreaded part of the shaft is 7.8 mm (0.307", not quite 5/16") in diameter, and the nut is a "pierced acorn" type. I suspect that the washer may be a replacement -- I at first thought it was brass, but I think that's just some sort of yellowish chromate corrosion coating.
The one on a 1950s R.J.R. (early Bob Jackson) is virtually identical, with a thinner washer, which also might be a replacement.
Somewhere or other around here there's the bolt for a late 1950s F.W. Evans too. Seatpost clamp lugs on all 3 bikes look pretty much the same, but they're the formed/bent type, not brazed-on tubes like you have (which are similar to later (80s) frames I have, such as a Serotta, a TSD Guerciotti, a Motobécane Team Champion and Specialized Expedition.
Brit Rider
Quoted: 33 Post(s)
Will get out the calipers later today.
Brit Rider
Quoted: 33 Post(s)
Hi
The outside span is 0.82" (2.08cm) and the inside diameter of the hole is 0.31" (0.78cm).
Any further thoughts on vintage or more modern (but suitable) options?
Arb
Arb
Shifting is fun!
Bikes: Yes, please.
Quoted: 2192 Post(s)
Liked 4,580 Times
Bolts like that are readily available for a couple of quarters. A dozen for €4.90, to be precise:
https://www.internet-bikes.com/30857...-per-12-stuks/
Disraeli Gears
A pretty-much-standard Campagnolo seat post binder bolt from the 80s is 8 mm diameter x about 20 mm nominal length (screwed in all the way, I think) -- and these things are available (both vintage and new) on eBay, by many manufacturers, either bike marques or Sugino. Armed with the knowledge you now have, press on. The 80s type typically have either a knurled end by the "fixed" side of the bolt (for a non-keyed hole) or a key like the bolt shown above. But provided the diameter and length are reasonably correct, a key can be filed into one side (carefully, with file or Dremel tool), and doesn't prevent use of the knurled type either. The later models have no nut, but internal threads and are tightened with a hex key.
Quoted: 472 Post(s)
Liked 1,028 Times
A seat binder bolt like Charles Wahl shows depends on the strength of the steel key and the slot on the frame. I've seen too many of those fail due to the torque applied on the nut, trying to secure the seat post. Turns the bolt, strips the key, then the bolt just spins and you have to grab the head with vice grip pliers. Then folks replace the whole thing with a plain bolt so they can hold the bolt head. Then lock washers and star washers. UGH! I'll only use binder bolts that have a hex socket in the head, using two tools to apply torque on each side of the binder. And I always use two tools (ex: two 5mm hex keys). Even if the binder bolt had a key on the head too (ex: Sugino seat bolts) I use two keys. Why damage things when you don't have too? Two keyed bolts are a design that lasts.
So, I recommend finding or making a bold with a "socket head", either a dual headed binder bolt or a stainless socket head bolt with a nut. It will hold the post without buggering the frame. Maybe you can find a neat 1950's Carlton specialty nut. They're out there.
