Where can I get a reproduced headbadge?
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,831 Times
I have searched ebay briefly, for original or anyone selling reproduction headbadges.
Have not investigated 3D.
Anyone got a lead?
Here's what I wish to have.
Paint on the frame is in good shape, so new reproduced, with care to the colors (if any) is acceptable.
Edit:
Calling you vintage Euro guys or anyone in USA with connections to the Ted Ernst family - to see if an original is available.
Anyone got a lead?
Edit:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Veteran, Pacifist
Liked 4,831 Times
A clean palate on a (presumed) 1959 bike with a 25 year old repaint.
Quoted: 472 Post(s)
Liked 1,028 Times
My first thought was a British TV show we've been watching - The Repair Shop. It has several very talented people doing repair and restoration of historic objects. Impressive talent. I wonder if such a person (maybe known to museums in your area) could restore your head badge. Ex: someone who works on historic porcelain, who has a great eye for color matching, durable finishes, levels of gloss, etc.
Or someone in the jewelry field that restores lockets, enameled pieces, trophies, etc.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
OP
My earlier response was based on an understanding that you wanted to restore not reproduce a HB...sorry I can't offer any advice.
Ben
Ben
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,060 Times
Years back I worked at a company that used a Chinese vendor make some pot-metal, flat, "fake-cloisonne" badges (plastic filled, not melted glass) These turned out OK, vendor worked from vector files with notes and PMS colors called out. They could do a "short run" but the cost was high since everything is in the set-up, not materials. These outfits were mainly makers of pins, probably some are still in business.Might not be ideal for this final "curved" product but you could try that angle.
Bikes: Yes
Liked 3,868 Times
Here's what I ended up with on my Stella.
Here's version1 of the above next to the original Stella head badge, which I acquired later but haven't bothered with because I'm happier with the reproduction.
My Bikes
My Bikes
Quoted: 350 Post(s)
Liked 276 Times
Here's an old BF thread that depicts RHM's work.
https://www.bikeforums.net/framebuil...-creation.html
Likes For tyler_fred:
Liked 2,180 Times
I did a little more research...and I think that you could look into 3D printing shops in your area and see if they will do a single in metal.
I am not sure of the cost but you already have an image that can be used to make a copy...cost may be prohibitive.
Good Luck, Ben
Good Luck, Ben
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
I like the old badge you posted. The colored rings remind me of both Frankenstein and The Jetsons.
Here might be a more modern ('60s, '70s) one:
That Bainbridge bike shop might still have their Rickert track bike. If so, you could tool over there and take some pics and dimensions of the badge.
Quoted: 3015 Post(s)
Liked 3,793 Times
Good Luck, Ben
Good Luck, Ben
In retirement I want to get a mini-furnace for cloisonne. Plenty of how-tos on youtube.
small ring
Quoted: 437 Post(s)
Liked 925 Times
maybe headbadges.com could make one
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Still kicking.
I think that headtube badge can be revived.
Appreciate the old bikes more than the new.
Likes For Dannihilator:
Liked 2,180 Times
Still kicking.
Must have mis read. My bad.
Veteran, Pacifist
Liked 4,831 Times
Clarification:
Image from Classic Rendezvous is below - showing a headbadge that I would like to either
A. Find an original - deemed unlikely, given an impatient personality
B. Replicate closely or stylistically recreate the shape and image
i am investigating a 3D print in plastic ,
and a metal fabricator to recreate the design, if not the colors
thanks @iab for Shapeways.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
If I were doing that Rickert badge, I'd draw it up in CorelDraw (cuz that's what I use), ending up with black lines and black letters over a gray background. Then I'd use Shapeways' 2D to 3D app. The trick at that point is to get them to print the thinnest version of the badge possible. You have to trick the app, which isn't that hard to do Brass is pretty easy to bend to fit the tube. Plastic could look good, but curving it would be a challenge for me. Someone more adept at 3D modeling should be able to handle it
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 7348 Post(s)
Liked 2,463 Times
There is a jeweler in Philly whose name I've forgotten. I know she's on Instagram. @KonAaron Snake commissioned her to do at least one badge, and she did an outstanding job. Aaron, can you give her contact info?
Quoted: 3808 Post(s)
Liked 6,681 Times
Google is a wonderful thing: Custom Order - Revolution Cycle Jewelry
Likes For nlerner:
Veteran, Pacifist
Liked 4,831 Times
thanks to all for replies!
Likes For Wildwood:
Liked 3,793 Times
$32 from Shapeways made of aluminum
Likes For iab:
Veteran, Pacifist
Liked 4,831 Times
Das ist wunderbar.
Vielen dank, @iab.
Vielen dank, @iab.
