Is Converting a Huret Dropout by Welding Difficult?
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 251 Post(s)
Liked 268 Times
I have a Schwinn with a huret dropout and I was wondering if converting it by welding a bit of metal like this https://www.flickr.com/photos/493535...n/photostream/ is difficult?
I don't know how to weld and I wasn't planning on doing it myself. Is this something that somebody who knows how to weld and hasn't done it before can do with a good chance of success?
Or should I leave well enough alone?
Thanks
Thanks
Bikes: '84 Miyata 610 91 Cannondale ST600,'83 Trek 720 84 Trek 520, 620, 91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 678 Post(s)
Liked 362 Times
Thanks
Thanks
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4667 Post(s)
Liked 5,765 Times
I do it pretty much like Peter Weigle does (that's his picture from Flickr you posted). And yes,
The reason, for those wondering what the heck we're yakking about, the Huret dropout in the linked picture has a derailleur stop at the 4 o'clock position, whereas the "Campy standard" is 7 o'clock. Braze in a bit of brass, some filing, Bob's your uncle. Many welders know how to braze as well, if you know someone with a careful hand.
Likes For Narhay:
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,273 Times
If you'll be using a derailer having sprung upper pivot, there will never be any impact force on the rotation stop from hitting holes in the road (the spring will absorb all of the peak force).
In such a case, I think that a 3/16" steel welding rod could be instantly stuck to the bottom of the hanger and then cut off just a few mm in length to adequately support the tip of the adjustment screw, or perhaps of the derailer's sprung tabbed washer (as on 1980's Huret).
The advantage of such arc welding is that the heated area will be tiny compared to a brazed addition, and the cost much lower.
Quoted: 2992 Post(s)
Liked 3,704 Times
Could be tig welded too. Localized heat like arc, but a more precise method. Remove chrome/paint, wrap brazed joints with wet cloth, and Bob's yer uncle.
Car free since 2018
Quoted: 251 Post(s)
Liked 268 Times
Thanks for the replies.
I did see an example of using a washer here https://16incheswestofpeoria.wordpre...sports-tourer/ but even that is beyond my very meagre reach.
I guess I will leave it the way it is for now.
On my Stella, a PO drilled and tapped the hanger (M4 I think) and inserted a small cap bolt as a stop. I happen to run that bike as a fixed gear, but I would have no problem hanging a derailleur on it.
Quoted: 1124 Post(s)
Liked 1,704 Times
Not difficult, imo, if you have the tools and materials for the task. It's a very small area one could silver braze some brass or steel to the spot or blob some brass and sand to finish.
Old fart
Quoted: 3571 Post(s)
Liked 3,366 Times
I just melted a blob of brass onto the dropout and filed it into shape:
Likes For JohnDThompson:
