Weird Front Mech - Help!
Quoted: 167 Post(s)
Liked 252 Times
I'm rebuilding a Bianchi Sika which has a strange LX front derailleur. Instead of the usual hex bolt clamp for the cable, it has a machined and recessed round thingy that looks like it will take the end of the cable housing. Anyone have experience with this?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Can you post pictures? I've never seen one that doesn't have a bolt-type clamp of some sort.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Looks like top pull cable routing if that helps....
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likely a bottom pull FD set up for top pull. My 1990 Trek 970 has that. Cable runs from the top and the, housing goes into the derailleur arm and inner cable continues to anchor under a bolt below. Inner cable stays stationary and the housing moves the arm.
SE Wis
Liked 3,401 Times
Like this.
Likes For dedhed:
Note that in this setup, the cable housing needs to have enough of a curve to allow the housing to move downward when the shifter is activated.
Likes For Moe Zhoost:
Expired Member
Liked 5,437 Times
Thanks, new to me as well.
Quoted: 6196 Post(s)
Liked 4,810 Times
So is it correct that the cable end is held fast to the frame and the housing moves to change the DR position?
That's a new one for me too!
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
After many decades of working on bikes this is the first time seeing this for me too. Thanks!
Quoted: 4209 Post(s)
Liked 3,875 Times
Seen this only a few times. But those of us who have worked on Simples sliding ft ders know well the nature of a cable stop moving type of design. The longer one does the old bike servicing the more simple logic helps Andy
AndrewRStewart
AndrewRStewart
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
That was one way to do top pull cables before derailers were designed for top pull. Another way was to run the cable from a stop, down around a pulley, and back up to the derailer. Keeps the front cable out of the gunk that bottom routed cables can encounter.
What’s the question?
Stuart Black
Stuart Black
