Cycling and Other Aerobic Exercises
I do both weight lifting and cardio/aerobic; cycling would be my main cardio.
But I am wondering if adding other types of cardio would benefit me even more. Or would it be insignificant?
Basically, these are the options that I am interested in:
1. Jump roping (up and down motion) and cycling.
2. Running/jogging and cycling
3. Jump roping, running and cycling (I probably won't have enough time for this option).
4. Cycling is good enough; adding other things won't benefit you much.
Quoted: 12197 Post(s)
Liked 1,497 Times
Rowing is great.
Adding other types of exercise is always beneficial. It keeps your body guessing.
Quoted: 71 Post(s)
Cycling is about as pure cardio as it gets, and if you are already lifting I'd add something to help offset muscle imbalances introduced by too much time cycling. Maybe one of hiking, running, basketball, football, rowing or tennis one day a week.
hiking in mountainous terrain is great. I have bagged peaks where my Heart rate was at 90% for over an hour on long steep pitches. It does not pound you like running but has a high aerobic benefit. I use hiking poles and that engages upper body like Nordic skiing.
That is awesome. Thank you
Quoted: 4227 Post(s)
Liked 2,488 Times
Self defence is all about finishing the fight as quickly as possible which requires speed, explosive strength , power and good technique. You don't need endurance to run in circles around your opponent for 2 hours...Strong core is the most important thing because every powerful kick, punch and many other self-defence movements originate from the core and hips.
If you're taking self-defence then you need: speed, power, explosive strength and flexibility. You are already doing cycling which is cardio, don't waste time doing more cardio. Focus your energy on improving and practising your self defence techniques instead of doing more cardio.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Self defense or sport fighting? Must be differentiated.
Self defense no need any physical performance. Gouge eyes, squeeze windpipe, kick balls etc no need much force.
Sport fighting need strength and conditioning.
The Left Coast, USA
+1. And you think you have your cardio optomized, and then you try something new and end up hands on knees huffing and puffing. I added private boxing lessons to my work-outs, jeez...totally fried after 30 minutes. And, I'm used to one/two hour runs.
Wow. Thanks for this advice.
Bikes: 2012 Trek DS 8.5 all weather hybrid, 2008 LeMond Poprad cyclocross, 1992 Cannondale R500 roadbike
My cardiologist (actually his exercise physiologist) asked me to add HIIT 2-3 times a week to my routine. The routine he recommended was running on a treadmill in intervals of 4x4 for total of 30-40 minutes.
Also, I have found that running uses -- and strengthens -- different muscles than does cycling.
Quoted: 5224 Post(s)
Liked 3,585 Times
add some swimming to feel amazing
It's not a bad idea for cyclists to add a weight-bearing exercise to help maintain bone density and strength. Whatever you can do and not blow out your knees.
And a strong core helps everything.
Old Lady mcmoose
Old Lady mcmoose
One form of activity that no one mentioned is rollerblading. Done with good skating form it builds a lot of power. It also builds good core strength.
