Helix Update?
#2201
Quoted: 800 Post(s)
Liked 247 Times
Yes, that will happen on any bike with suspension and is why lockout is a feature. I ride a Birdy and can modify my pedal stroke to minimize bob up to about 100 rpm but I get bob at higher cadence or when I go out of the saddle. As long as the pedal stroke is good, those losses are relatively minor. If your goal is going fast on a Birdy, the first thing to fix is the body position and the second is the gearing. Hitting 100 rpm on a 52/11 gear ratio is only ~21 mph.
The loss is minimal and on rough road you actually ride faster with a suspended bike than with a not suspended bike. And if you want even more confort, with the 18" wheels you can mount 50mm wide Big Apple tires.
The gearing of the Pacific Cycles Birdy with 52/11 and 18" wheels (or even 20"wheels) is much too short.
Riese und Müller Birdy with derailleur use a special 9-32 cassette (and special rear freewheel) that provides a much longer 52/9 ratio (about 7.8m depending of the tires size).
I changed the wheels to have a SRAM XDR freewheel and mounted a 11s 3T 9-32 cassette.
#2202
Schwinnasaur
I agree that on very rough pavement, shocks make the bike faster. And while you find the loss minimal, I found it constant. Over the years I had two Moultons and eventually parted with them. I have not had a Birdy. My small wheel bike is my Brompton, which has a shock and needs the shock for comfort.
#2203
Quoted: 800 Post(s)
Liked 247 Times
My experience is that the rear suspension both of the Moulton Speed (note that the Moulton AM and older models have a different rear suspension) and Birdy do not cause an efficiency loss.
The main benefit of suspension for speed on rough road comes from the front suspension that makes the bike safer while the rear mainly affect the comfort.
I have also a Brompton, a superlight with titanium fork and rear triangle, on cobbles the front wheel bumps from one cobble to the next and force the rider to reduce its speed.
The problem of the Brompton is the combination of small wheels + rigid fork + narrow high pressure tires.
I am afraid that the same will happen with the very rigid single arm fork of the Helix.
The bigger wheels won't help a lot because the tires are too narrow and too high pressure. Peter should have made the frame to accept 50mm wide tires (which is the most common width of ETRTO 507 tires).
I have a titanium frame with carbon fork road bike with even bigger = ETRTO 622 high end wheels and even with 28mm wide tires, the same happens.
The only clear benefit of bigger wheels is on soft ground, sand for instance, where the smaller wheels are blocked faster. But also in this case, wider tires are needed.
#2204
Schwinnasaur
I find that that the primary suspension and the best are the bike's tires. I too have a 622 with nice lare tires, 38. On the brompton I run Primo Comets at 65 to 75 psi and it helps. I like wide supple tires and may try Scorchers next. I find rear suspension is to be more beneficial than front. It is the comfort that is letting you ride faster on broken pavement.
#2205
Quoted: 5 Post(s)
Quoted: 5 Post(s)
dear bike forums
thank you for your pm. i cannot replay because i have not 10 posts yet ;o)
we're based in switzerland. what is the fs section on bike forums?
best, namor
best, namor
#2208
Quoted: 800 Post(s)
Liked 247 Times
For the Greenspeed Scorcher, they are currently 40mm wide and as far as I know too wide for the Brompton (I saw there was s narrower test version made for the Brompton but not in production yet I think).
Now, a full suspension Birdy even with narrow high pressure tires like the 32x355 Kojak at 8bar provides a level of safety and comfort on cobbles totally unknown with a Brompton, whatever the tires used.
#2209
Schwinnasaur
I think I can fit them to my Brompton. Others have done it.
#2210
Quoted: 800 Post(s)
Liked 247 Times
If you can fit the Scorcher on the Brompton, they will surely be a very good solution, they are wide, supple, fast tires. Maybe without mudguards ?
But Greenspeed made a narrower test version of the Scorcher especially for the Brompton, so the 40mm won't fit on all Brompton's
#2211
Schwinnasaur
#2212
Quoted: 800 Post(s)
Liked 247 Times
So, its the rear fenders and its mounting that cause the problem !
With the original rear fender, there is indeed not enough clearance between the tire and the fender, sooner or later dirt will clog between the tire and the fender.
Removing the mudflap of the rear fender is a very bad idea, it is this mudflap that mostly protect the rider.
#2214
Schwinnasaur
It may not work out in practice. The next time I need a tire I will buy one and try and post. Right now I don't need one. If it does not work in rear I can use it in the front where cushion is needed more.
#2218
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
I just received an email offering December 2019 delivery. Prices are $3500-4k. Contents here for those who did not receive it:
Helix is a revolutionary folding bike. Never before has there been a bike that rides and folds equally well. Helix has the most compact fold possible with the wheels folding beside the frame and between the crank arms. With 24” wheels, an all titanium frame, disc brakes, standard drivetrains and an industry leading locking mechanism, Helix rides every bit as well as it folds.
https://www.helix.ca/shop/ <<<<order link
The Future of Folding Bikes is Here: Helix is Now Accepting Orders Worldwide
The folding bike you have been waiting for is now available for December delivery.Helix is a revolutionary folding bike. Never before has there been a bike that rides and folds equally well. Helix has the most compact fold possible with the wheels folding beside the frame and between the crank arms. With 24” wheels, an all titanium frame, disc brakes, standard drivetrains and an industry leading locking mechanism, Helix rides every bit as well as it folds.
Helix is made in Canada. We are the first company in the world to robotically weld bicycle frames in an inert argon chamber. This results in the highest quality welds possible, where each frame has been manufactured to last a lifetime. In addition to this, Helix is made up of more than 30 titanium parts that are machined on our precision multi-axis CNC machines.
Helix was designed around modern bicycle standards. It uses premium components including TRP Spyke dual piston disc brakes, Shimano XT rotors, Wolf Tooth Components narrow wide chainring, Shimano SLX derailleur, Formula hubs and more. We have also designed a titanium seatpost that accommodates a large range of riding positions and allows Helix to fold even smaller.
Helix will take you where other bikes cannot. It folds so compact that it can fit in a suitcase that is within maximum airline dimensions. It has large wheels that can accept tires up to 1.5” wide and is suitable for on road and trail use. Helix is easy to fold, can stand on its own when folded and can be rolled on its front wheel so it does not have to be carried.
Helix is a complete bike. It can accommodate mudguards and racks, a trailer hitch and a child carrier. It can be converted to electric assist with a rear hub motor. It can also accept a wide range of standard bicycle components. A complete line of accessories will be available spring 2020.
Because of the extremely specialized design and manufacturing we can only accept a very limited number of orders as we work towards scaling production. Take this opportunity to be among the first in the world to own a state of the art titanium folding bike.
Order NowHelix is a complete bike. It can accommodate mudguards and racks, a trailer hitch and a child carrier. It can be converted to electric assist with a rear hub motor. It can also accept a wide range of standard bicycle components. A complete line of accessories will be available spring 2020.
#2225
$3500-4000. Somebody in this thread predicted this years ago...
