Dahon Curve's Sturmey Archer X-RF8(w) won't engage into 2nd gear from 1st
Bikes: Dahon Curve D8 (Sturmey Archer X-RF8), Crius Smart 3.0 5 speed
Quoted: 113 Post(s)
Hi folks.
I figure I've put about 5,000 km's on the Sturmey Archer X-RF8(w) over the last 1.5 years. In the last few weeks when shifting from 1st into 2nd, 2nd gear won't engage. If I shift down from 3rd to 2nd, 2nd engages without a problem. When shifting up from 1st into 2nd, I can feel it grabbing as it tries to engages, but it doesn't. All other gears shift perfectly both up and down.
I've adjusted the hub so that yellow line is exactly in the centre of the window. This didn't work. I've even put the hub slightly out of adjustment (both higher and lower) as some have suggested, and this did not work. Thinking that the cable might be a bit slack, I put the anchor nut a bit further up the cable then adjusted the hub again, but this didn't work either.
Just another note, it may be completely unrelated or irrelevant. Just before this shifting issue happened, I noticed that the hub got a bit less noisy in all gears. My riding buddy even noticed this.
Any thoughts as what can be done to solve this shifting problem?
One thing that may help is exchanging the shifter cable for a fresh one - sometimes it gets worn near the hub for not to obvious reasons and this may affect the shifting. Probably easier and cheaper than looking into the hub. Maybe it helps (it did for me more than once).
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
Did you tighten the chain tension recently?
Thanks
Yan
Thanks
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
Quoted: 282 Post(s)
Liked 24 Times
If it was overtightened I would think that could be a cause.
Thanks
Yan
Thanks
Yan
Palmer
Quoted: 1668 Post(s)
Liked 1,821 Times
Couple of users have 'fixed' shifting problems on the XRF8(W) by pulling, cleaning and oiling the inner works.
Quoted: 321 Post(s)
Liked 7 Times
I would first pull out the cable inner, squirt WD-40 into the outer, blow out with compressor, thoroughly wipe inner down, lube with Boeshield T9, and re-insert. Majority of shifting problems originate with dirty cables used for couple of years. Cable inner becomes very sluggish to move. Once you got the cable working smoothly, move on to other, more onerous possibilities.
Bikes: Muddyfox Evolve 200, Bicycles4u Paris Explorer, Raleigh Twenty Stowaway, Bickerton California, Saracen Xile, Kona Hoss Deluxe, Vertigo Carnaby, Exodus Havoc, Kona Lanai, Revolution Cuillin Sport, Dawes Kingpin, Bickerton, NSU & Elswick Cosmopolitan
Quoted: 297 Post(s)
Liked 33 Times
Internal hubs as a general rule get less reliable the more gears they have. The exception being the rohloff but that's built like a tank, very expensive and the maintenance schedule is important but still you can probably get 50-100,000 miles out of one of those. Some hubs have been unreliable like the 11 speed alpine and the earlier 8 speed nexus. I think as a general rule for the hubs above 3 speed something like 5,000 - 20,000 miles would be normal depending on luck, rider weight/strength, chainring size and the frequency of servicing. 3 speed hubs from any brand seem to be much more reliable because of the simpler mechanism no doubt and many bikes with early 3 speed hubs maybe 50 years old still work great.
If you have built up the strength in your legs to cope with hills better a switch from 8 to a 3 speed hub is not a bad option. I.e. both cheaper and more reliable.
Also the other option is become a gear skipper. You accept one of the gears is worn and simply avoid that gear. Best to service the hub first but if the problem remains in only one gear and parts are either not economic or unavailable just skip that gear. Another possibility is change the sprocket size on the rear wheel or chainring at the front to make your favourite gear ratio move to a different gear position in the hub. This is still a good option if a service recovers functionality because hopefully you will move which gear is wearing fastest. If the hub is getting old and worn better to make your gearing lower by either increasing the size of the rear sprocket or reducing the size of the front chainring and spinning more.
Quoted: 113 Post(s)
I have two X-RF8w hubs and both are very picky regarding adjustment. Also, both are very british in the sense that they sometimes do what they want instead of what they are supposed to despite being properly adjusted and behaving completely innocent a couple of days later. And those hubs are not famous for their reliability (though the "w"-Version may suffer from the bad reputation that early variants of it's older brother w/o the "w" earned).
Quoted: 113 Post(s)
Quoted: 113 Post(s)
The good news is that a cable and housing replacement fixed the issue.
I generally like the Sturmey Archer X-RF8(w), but there are two things dislike about it
1) the noise
2) the amount of friction
I bought a bike this year with Sturmey Archer S-RF5 (w) and it has overcome both of these issues. I hope that they incorporate whatever technology that is into the 8 speed.
Neither hub has been unreliable but I have had to adjust the X-RF8(w) more than an Nexus 8 I had.
1) the noise
1) the noise
Source: https://fahrradzukunft.de/17/wirkung...schaltungen-2/
The noise of the XRF8w is something a lot of people complain about but with my two I am totally fine with that. Maybe I am deaf, maybe I am lucky. Or I am lucky to be deaf.
I have put around 2500 miles on my Raleigh Twenty equipped XRF8W. When it dies, I'm buying a pontoon boat, I already have the anchor!
Quoted: 573 Post(s)
Liked 118 Times
Indeed, most problems with internal gear hubs are simply due to wear, either in cable/housing or shifter. Actually, it's not the cable itself that's necessarily to blame, but rather the housing that's getting old/dirty and prevents the cable from sliding as well as it used to. The more gears in the hub, the more sensitive it is to misconfiguration.
Other possible causes are…
- the rear wheel is a bit misaligned: It happened to me after the first puncture I got on a bike with an Alfine 11. Make sure the rear wheel isn't skew
- the nuts are overtightened: Check the torque (Alfine 11 : 35-40Nm)
Quoted: 113 Post(s)
Quoted: 113 Post(s)
I agree with you on your observations but not so much on the possible solution. The XRF8-w has it's direct gear in the first gear, any other gear is in transmission with a lot of planetary gears involved. Therefor there's more drag involved than in the XRF5w (which is close to a classical 3-speed in terms of transmission and therefor much simpler and has it's direct gear in the third). The 8-speed nexus/alfine on the other hand has it's direct gear in the fifth gear, where it has it's best efficiency, whereas the forth gear is the worst in regards of efficiency due to the planetary gears involved:
If the hub were to ever malfunction, I would crack it open and replace the grease with automatic transmission fluid oil. Just to see how this would change the friction and noise. Wouldn't do that to the hub while it is still working though.
Hey All, Sorry to bump and old thread, just found it! My experience with my X-RF8(w) agrees with everyone else, finicky on the adjustments. What I've noticed as I ride from 36C down to -5C (as long as there's no ice!) is that this hub is very British.... It's happiest shifting between 5C and 20C, anything outside of that range and I have to use the barrel select to make minute adjustments. Either the inner cable or the outer cable sheath expansion/contraction messes my switch in and out of 2nd horribly. I've just taken it apart and am going to de-grease it and switch it over to oil.... wish me luck!
mg
mg
Quoted: 113 Post(s)
mg
mg
I have a spare X-RF8 with one broken part on it. If you conversion works, I'll do the same.
If you have the time, please start a new thread when the conversion is underway or done.
edelay
Bicycle Mechanics
3
09-14-17 08:58 AM
Brian Mc
Classic & Vintage
25
04-03-16 08:30 PM
