Handle Bar Bag
Quoted: 358 Post(s)
Liked 136 Times
Handle Bar Bag
I've been thinking about getting a handle bar bag for commuting. (To carry all the small/light stuff I some times need to carry.) Does anyone else use them for their commute and if so, what is the best?
Quoted: 19 Post(s)
You can get them at Walmart, a simple bag need not be expensive.
I have a Bontrager bar bag from my LBS and It was not expensive, works just fine.
Has a bottom strap for stability, goes around the frame/neck under the top tube.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
I now use panniers on my commuting bike. Sometimes you need to carry a lot of stuff. Previously I used a trunk bag, which worked well but had limits. I had never considered a bar bag until I bought one for my trike (which does not have handlebars, go figure!). I especially liked the availability while riding. I ended up buying another bar bag for my all-around bike. For both trike and bike I am using Altura bags that use the Rixen-Kaul KlickFix attachment system. The clear advantage of the bar bag is being able to get to your stuff when riding. There are definite limits to how much you can carry, though. Also, if you have other equipment attached to the bars, the bag may interfere a bit.
The more inexpensive bags attach to the handlebars with velcro straps. I find that with a flat bar they work fine. On drop bar bikes I prefer one that has an attachment system like Hoopdriver's above that holds the bag in front of the bars so my hands aren't rubbing on the bag when I am holding onto the bar tops.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Best, (By Numbers Seen Here) is Ortlieb, its the cycle tourist's favorite.. you may not need all that volume or like the boxy shape,
the company makes other products that use the same QR handle bar mount..
Klick Fix is another German company making brackets and bags, quite a diverse assortment. excellent designs..
Now with the Ultimate 6 Ortlieb bar bag mount you can use KF bags, and visa versa, KF mounts, on Ortlieb Bags..
Well, yes, Opinions differ.. there is the Modernist, vs the Vintage Bike Quarterly reader's clique.
And 'Best' is after all , an Opinion .
It has a very sturdy clip-on system that stops it bouncing around, but the actual velcro top fastening can come undone if you hit a big bump and have something heavy inside the bag. For lightweight items it would be fine.
The downside I found is that the mounting bracket uses quite of bit of your bar real-estate, and a normal light mounted on the bar will be too high to illuminate the road in front of you (although probably high enough for traffic to see). My solution was to get a Topeak Bar Extender (https://www.chainreactioncycles.com/a...-bar-x-tender/) and put this *under* the bars so that my light shines below the bar bag. It looks low, but it illuminates the road well, and is still visible to cars.
I personally like the bar bag compared to other options for smallish items - especially if you don't want to be bothered with rack & panniers, or can't fit one on a carbon frame (my case). I also have an Apidura seat bag (17 litre), but it's a bit of a hassle to fit & remove it from the bike, and packing and unpacking it requires some attention to packing order if you want to find your smaller items (it's basically just a big bag without any internal pockets). In the summer, the bar bag is a lot less sweaty and uncomfortable than a back-pack.
HTH.
Quoted: 4559 Post(s)
Liked 2,802 Times
Ditto, the KlickFix compatible bags. Secure even on rough roads and gravel, quick and easy to attach and detach. The KlickFix mount itself stays on the bike. It's secured by screws and a strong braided metal cable so it's less likely to be stolen.
Mine is an AGU Qyoto, made in Holland. Weather resistant, with map pouch that doubles as a rainproof pouch for touch sensitive phones or tablets. I've used it with my own padded compartments for carrying camera gear, and without extra padding for a winter rain coat and extra winter gear that I need only early in the morning or late at night, but which are too warm for daytime use in winter.
AGU bags are affordable ordered through European dealers that are already accustomed to handling currency exchange and shipping for US customers. Favorable exchange rates too. Not fancy but functional.
Decades ago I commuted with a Kirtland Tour Pak. Good bag but fussy compared with the KlickFix. It required a large metal mount that hooked across the handlebar and stem. The mount had to be threaded through small diameter loops stitched into the bag, and wasn't secured to the bike so it was easy to steal and a bulky hassle to carry off the bike. It was good for that era but outdated. The AGU bag and KlickFix mount do everything better.
Bikes: 2015 Jamis Aurora
Quoted: 20 Post(s)
I just started using a Jandd Touring Handle Bar Pack that I got from Ebay and I love it. Having ones that you can easily take off is nice. That's been the biggest thing about the Jandd that I appreciated. Much easier than any pannier I've had.
I had a saddle bag stolen so I keep all of my on-the-road gear in the small pocket.
GATC
I have an arkel and an ortlieb. Ortlieb is bombproof. The connector for the arkel (where bag mounts to the handlebar mount) basically gave out after about a year, started launching the bag any time I hit a bump. I bent the leaf-spring things on the bag with pliers and no more launching. Doubt it is readily removable (or at least reattachable without pliers if I do remove it) anymore, though.
Use both with dropbars. I prefer the more rigid kind of mount these have vs what one would get w/ velcro loops.
Quoted: 20 Post(s)
To me, when it's fully loaded it feels stiffer, but I like appreciate that feeling. Its rated for 10 lbs (so imagine two sacks of flour) and I don't think I've gotten that high yet. There's no pull when I'm going into turns or anything, but it does stiffen it up. I have 420mm bars and a 105mm stem FWIW.
These also don't automatically come with straps, so I bought a cool looking one for a camera for $6 off ebay.
I use a cheapo one I got on fleabay for like $12 USD. I toss it on my cross race bike when I use it to commute. Drop bars, attaches with three Velcro straps. It's not large, but can fit a wind jacket, wallet, phone, and a few others small things. (I'm lucky, can keep all that I need at my office - clothes, food, eyeglasses, etc.)
I'd say go cheapo first, see if you like it, then upgrade over time. I love mine. When I want to change things up and not ride one of my commuter bikes, I toss the bag on my road or cross bike and I'm good to ride!
Bad example
Quoted: 825 Post(s)
Liked 209 Times
I have an Ortlieb on one of my touring bikes, and it works well enough. On my travel bike (which has S&S couplers) I use a Swift Industries bag that mounts with a KlickFix. I really like the Swift bag, which is made in Seattle. It looks rather like a smaller version of the Berthoud bag shown above.
On my in-town bikes I use a couple of bags from Dill Pickle. These are a bit smaller but are still big enough to hold all my tools, spare tube, patch kit, and other items I might need. They also come in a wide range of colors!
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I like a handlebar bag for commuting and any rides where I might want to access the bag while riding. I drank deeply from the BQ kool-aid and upgraded to a low-trail fork to complete the package.
Quoted: 1034 Post(s)
Liked 1,290 Times
I use one of these on the fork. I was hesitant at first since it lowered the light, but I like it. https://paulcomp.com/shop/components/gino-light-mount/ They also have a stem cap mount.
Before I used this mount, I used a bar extension. I used the Topeak. https://www.amazon.com/Topeak-600010...unt+extensions
There are many more options for extensions now. Search Amazon.
I like large bags for commuting, but not spending much money on them. My current favorites are made from ~$30 duffel bags typically labeled trauma, response, first responder, or EMS. I have one in service as a handlebar bag and one as a saddlebag.
The handlebar bag modification is pretty simple. Mine uses a dowel, two toe straps, and a few cable ties. 1) fit a dowel/tube/stick in the rear/upper corner of the bag. 2) cut holes in the bag for straps that'll go around the dowel and your handlebar. 3) strap to handlebar. 4) check your tire-to-bag clearance. add a reflector bracket or similar to keep the bag off your tire if necessary.
Sorry I don't have pictures of the handlebar bag version. Here's the saddlebag version:
Quoted: 2604 Post(s)
Liked 1,931 Times
IME a loaded bar bag does a lot more to normal bike handling than panniers with twice or three times the weight. But my bikes are not French randonneurs with low trail forks, so they must be inferior. (Except that they're really superior, since they're MINE!) And of course, with normal trail, there's something bad wrong when it starts to shimmy; if you drink the BQ kool-ade, that's a problem with the headset bearings.
