new bibs
Quoted: 10 Post(s)
new bibs
I am looking for bib shorts that truly are snug. The last two I have been not so snug in the crotch area. One has a chamois that tends to bunch; the other just is a little saggy and thus gets caught on the nose of the saddle. Any suggestions? I would rather not spend more than $100.
Kit doesn't match
I think I'd classify all of my bibs as truly snug, so you'll probably need to try some on to know for sure. For what's it worth, I've found Castelli and POC bibs to be crazy snug (for me, at least), so at least some of their models are cut for slimmer builds.
SuperGimp
Yeah, you just need to try them on until you find what you're looking for.. Better bibs tend to fit better but they typically also cost more.
Saggy is right out though.
Quoted: 1743 Post(s)
Liked 1,281 Times
Assos. But, you're not going to get them for $100. Maybe $ 130. if you find a good sale.
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
I think what you are looking for is compression gear. That is, the emphasis is on compression. The proponents claim their studies show it helps in performance. But you're not looking for that. You're looking for a proper fit.
2XU has it but I see the product line is specifically for tri wear.
Administrator
Quoted: 11971 Post(s)
Liked 6,652 Times
It's a pleasure to meet you, clearly one of the pioneering members of the forum. Cheers!
member
I have two pairs of Castelli's and they are very snug (compared to my other bibs).
Bikes: 2013 Cannondale Synapse 6 Tiagra + 2016 Cannondale CAAD 12 Dura Ace
Quoted: 231 Post(s)
I'm usually a cheap SOB, but I've learned that bibs are one thing you can't cheap out on. My buttcrack doesn't like cheap bibs. I get specialized rbx comp from my lbs for $120, but I've found my favorite chamois are the x2 from castelli. I like the very sung fit of castelli. Most people say to size up, but I'm M in both specialized and castelli. I'd definitely try them on first, or make sure you buy them from somewhere that will let you return or exchange if the size isn't right. I just stash money away until I have enough to buy nice bibs.
Quoted: 10 Post(s)
Rather not? That means to me you just might spend over 100 bucks.
