Chain Tool Replacement Pin
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
I broke TWO chain tools this weekend. On my cheaper one, I bent the handle, and on the expensive one the pin just sheared off. I think it's this tool, although Park has a couple that look very similar. They sell replacement pins but they don't look exactly the same either - on my tool, there are threads between that little nut thing and the pusher-pin and on the replacement versions the threads are on the other side.
So, the question is, has anyone done this and what are my chances of success and what do I need to watch out for?
Quoted: 336 Post(s)
Liked 309 Times
I'm not sure which tool you are using, but I have had good luck with the park 3 series (I'm not exactly sure which one I have).
I have broken a pin, but since then I have been very careful to align the tool before I really crank down on the spindle. I have probably broken 50 chains since then without breaking a pin.
It's MY mountain
Liked 2,980 Times
And all three versions say they use the same replacement pin, the CTP... I'm just not finding good instructions on changing it and I think my tool may be messed up inside (more than just the pin).
I think how I broke it was trying to push the pin out the wrong direction - it seems new chains have one-way pins with one end too big to pass through the link... I've never seen anything about that. For my Shimano 10s chain, I tried to push from the inside out... like we used to do it in the 6-speed days for easy re-insertion.
So what I want is a story of success or failure from someone who's changed a pin in their CT3.x
Señor Blues
Likes For on the path:
Really Old Senior Member
I don't understand your question, but-
If it helps, the pin on my CT-3 is threaded 10-24
Quoted: 1572 Post(s)
Liked 643 Times
1. Get two. Then tape the other to your tool. You'll likely never need the second one but it's insurance against breaking another. Also, no second shipping cost so it'll probably be half price.
2. How closely can you hold your thumb and forefinger together without touching? That's roughly the odds of the replacement pin not working.
It's MY mountain
Liked 2,980 Times
Took it to the LBS and the mechanic said the threads in the tool were damaged and a new pin wouldn't go in properly.
So I got a cheap one - if I'm going to break a tool, might as well be expendable.
Quoted: 6193 Post(s)
Liked 4,808 Times
I'd bought a cheap one at Academy Sports a couple years ago. It worked for about three chains before it's pin broke. So being the cheap SOB I am and not willing to pay for a decent one, I went back to what I used for at 48 plus years prior to that.
A punch and a piece of one inch steel plate with a hole I drilled in it a tad bigger than the pin diameter. I have to lay the bike down on it's side to line everything up. The very few times I have to break a chain I don't see why I'd spend money on a truly well built one. If I had to remove pins weekly, I'd probably spend the bucks.
Can you chase the threads? Epoxy?
All you really need to do is retain the pin in the tool since all the forces are "pushing".
