Alfine 8 outer receiver unit
Jet Jockey
So here’s the dilemma: apparently the outer receiver unit for the SG-S7001 Alfine 8 is no longer produced. It’s that little noodle looking doofer that the housing end goes into and which slides into the cassette joint arm.
This is a problem, since the cassette joint can’t accept cable housing without that little part. So I can buy the hub, and all the small parts except that piece of rubber, therefore buying a bunch of useless junk.
Anyone know where to source this? I’ve been looking.
Will the Alfine 11 outer receiver unit work?
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Sorry but.... You may get better responses with a picture, I see no part that is called an "outer receiver unit"
https://si.shimano.com/pdfs/ev/EV-SG-S7001-8-4111A.pdf
https://si.shimano.com/pdfs/dm/DM-SG0004-04-ENG.pdf
I believe you called it. The cable installation part of the manual calls it the outer casing holder. Some cassette joints use a "fair weather" version that doesn't include the rubber bellows but either one should function.
