Rear derailer replacement.
Quoted: 5 Post(s)
Short of it. Wife picked up junk bike someone threw out, wants me to fix it for son-in-law.
Please note, I'm not assuming any quality here, she just wants to give him a bike to ride with his son.
It is a GT Agreessor Pro, Chinese made bike. It has a Shimano Acera derailer missing
the top small sprocket. The other one has 13 teeth.
I'm not knowledgeable about bikes but handy enough to do a replacement. If I had the sprocket and bolt,
I'd install that. Are those parts sold separately?
If I found another junk bike with a Shimano 13 T derailer any reason that wouldn't work.
If not, are derailers standard? Meaning, can I just order any derailer from Ebay or Amazon and it would fit?
Can I assume the GT Agreessor Chain is Standard?
EDIT to add,
This is a part I'm thinking about ordering, (if I need to order), I picked it because it has 13 T others don't.
Ah, need to give Ebay description, I don't have enough posts for to post URLs.
So here is an Ebay search term that brings up the derailer
SHIMANO RD-M360-SGS ACERA 7/8 SPEED BLACK DIRECT MOUNT REAR DERAILLEUR-NO PACKAG
Thanks for any enlightenment you can add, Mikek
EDIT to add,
Last edited by Qmavam; 09-01-19 at 01:00 PM. Reason: Add part I'm contemplating ordering.
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Any long cage shimano derailleur from the 6-9 speed era will index correctly with the shifters.
Plan on replacing the cables (inner & housing) and likely flushing old, hard grease out of the shifters with WD40.
Yes you can replace the pulley, but it needs to be a "G" pulley that has some side to side movement to allow smooth running. Bolt might be harder to find if it's missing.
The one you linked is fine.
Another Shimano from a junk bike would work (correct mount, cage length) 11T - 13t really doesn't matter.
If you have a bike coop nearby you can probably buy a good used one for cheap.
Any 6/7/8 speed chain is fine KMC, SRAM etc.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Yes -- the RD-M360 is the exact derailleur, but any derailler that advertises compatibility with 6/7/8/9 speeds will work. It's definitely a bike worth making right again. They were and are sold by Dick's Sporting Goods and are decent entry level MTBs. They have a freehub rear wheel (vs. freewheel) and disc brakes that could be upgraded to any type of hydraulic brake. Get it running, and it can grow and evolve with the rider's desire and skill level.
Quoted: 5 Post(s)
Thanks all,
I ordered the sprocket, hopefully I'll find a bolt locally that I can make work.
If it doesn't work after that, I'll order the whole unit.
Mikek
Mikek
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
I hope you are not in a rush, that part is coming from china.
PM me your address and I'll send you a bolt that should work
Quoted: 2026 Post(s)
Liked 1,096 Times
You need the correct bolt. OEM bolts are "shoulder bolts" meaning they are threaded only part way so they screw in a specific distance and then stop thus maintaining the correct gap for the pulley to fit in. The threading is M5x0.8.
Quoted: 4201 Post(s)
Liked 3,857 Times
If the OP is talking about a der pulley bolt then they are not shoulder bolts at all but have a smooth shaft where the pulley will be located. The pulley has a sleeve/bushing that gets trapped by the bolt and the pulley freely rotates on that sleeve/bushing. The bolt could be any one of the correct length and threading and doesn't need any "shoulder" aspect to work.
Now if the OP is meaning some other bolt... we can't say much from the lacking description. The OP might be meaning the der hanger mounting bolt, which is a "shoulder" type but typically having 10x1 threads. Or the OP might be meaning the der mounting plate's (poorly called a "claw" by some) nut and bolt that keeps the plate attached to the drop out slot, these bolts could be a M5 thread but don't use a "shoulder" design. Andy
AndrewRStewart
AndrewRStewart
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Liked 1,096 Times
Quoted: 5 Post(s)
I see the sprocket comes with two bushings that look to be different ID, so I think we're covered on that.
I'm a newbie without enough posts to PM. :-)
Thanks, Mikek
Quoted: 5 Post(s)
Someone sent me a PM.
I am unable to retrieve it because I don't have 10 posts, and the software won't allow me to look.
You can send me an email at lamontcranton17@yahoo.com
Thanks, Mikek
Thanks, Mikek
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Thanks, Mikek
Thanks, Mikek
Try my email
JoeTheBikeManFlagler@gmail.com
Quoted: 5 Post(s)
Hi guys,
I have a new development, I've never seen this style Shrader? Valve. How do I put air in the tires?
Is there an adapter?
Ah! I can't post the image, I'm not up to 10 posts.
Thanks, Mikek
Thanks, Mikek
Quoted: 5 Post(s)
Hi guys,
I wanted to air the tires and found a non standard Schrader Valve.
How do I use that?
I can't post images, but you probably know what I have, but maybe the moderator will let my link in,
but I have to get past the software, so try this.
Add that HT... and 3 W thing to the front,
dropbox.com/s/psfq39b4v181ld5/
and put this on as the last half of the link.
schrader%20valve%20not.jpg?dl=0
To see an image of the valves.
Thanks, Mikek.
How do I use that?
Thanks, Mikek.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Hi guys,
How do I use that?
Thanks, Mikek.
How do I use that?
Thanks, Mikek.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
Your bike shop will have a "presta valve adapter", it will cost a buck or two.
Get a couple, they do get lost.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
+1 Presta valve, just need an adapter Some bicycle pumps have them built into the head (reverse the fitting) or the adapter is attached to the pump lever.
https://www.ebay.com/itm/10pcs-Prest...4f39762f50bd82
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Thanks, Mikek
Thanks, Mikek
Did it fit?
Quoted: 5 Post(s)
Sorry Joe, I haven't attempted repair yet, I'm still waiting for a couple of other parts that needed replacement,
and I have delivered the bike to my son-in-law. I won't be able to finish until I return to their home again.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
@Qmavam - a big shout out to you.
You are a stand-up guy. I truly hope the part I sent you helped you and was were able to resolve the issue with the rear DER.
Thank you for the donation to my shop, it is really appreciated.
The Bike Men of Flagler County
JoeTheBikeManFlager@gmail.com
Likes For JoeTBM:
