First FG, Pedaling Through Turns?
Old 10-05-19, 12:19 PM
Maslin
Quoted: 17 Post(s)
Liked 11 Times in 6 Posts
Recently put together my first fixed gear, a LeMond Spine frame custom spec’d by someone around 2005. Had a paddywagon 10 years ago or so, never got up the gumption to switch the wheel.
I commute a Salsa Journeyman 650b, 18 miles a day. Recently switched over from spd-sl to eggbeaters for a little extra give and walk-ability.
So my issue... had a good slide across the pavement on the way home Thursday on the Salsa. Pedaling through a right turn I clipped a pedal and immediately went sideways. Easy solution, don’t pedal through turns.
What’s the solution with a fixed gear? Slow down? Eggbeater clearance sucks switch back to spd-sl? Rock the single speed forget about it?
Both bikes have 170mm cranks. Specs say 72mm bb drop on the Salsa, 70mm on the LeMond.
I’m not young enough to bounce and rally too many more times
Maslin is offline
Old 10-05-19, 01:20 PM
REDMASTA
REDMASTA's Avatar
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times in 64 Posts
get a frame designed to be ridden fixed. they have less bb drop for a reason.
REDMASTA is offline
Old 10-05-19, 01:25 PM
ryan_rides
ryan_rides's Avatar
Bikes: 2018 Aventon Cordoba 2021 Specialized Allez
Quoted: 145 Post(s)
Liked 33 Times in 23 Posts
Yeah
ryan_rides is offline
Old 10-05-19, 01:38 PM
Maslin
Quoted: 17 Post(s)
Didn’t think of that, 12-18mm is significant.
As popular as fixed gears are in Portland, they haven’t found their way down I5 yet.
I have to imagine that a 55mm bb drop frame with platform and straps is fairly close to a 70mm bb drop frame with clipless pedals. So then what? Does slowing down come with experience? I’ve been riding bikes for 30 years, you know when you can pedal through or need to coast without thinking about it.
Maslin is offline
Old 10-05-19, 02:11 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
Take it easy until you've learned how fast/hard you can corner without pedal strike. Just about everybody dumps it a couple times when they're first starting out. Take it easy on unfamiliar corners as well. Road conditions and camber can make pedal strike more likely.
Is this a road frame conversion to fixed gear? If so, how long are the crank arms? Road frames tend to have lower bottom brackets (and thus less ground clearance) than true track frames. Shorter crank arms will lessen the likelihood of pedal strike.
JohnDThompson is offline
Old 10-05-19, 02:17 PM
Maslin
Quoted: 17 Post(s)
Yes, it’s a road frame. 170mm cranks now, it had 175’s when I bought it. Couldn’t make it around the block without digging a pedal in.
The track frames I’ve found are all 52-58mm bb drop compared to the LeMond’s 70mm. Hoping clipless and my carbon soled road shoes would make up that ~15mm compared to straps and Vans.
Maslin is offline
Old 10-05-19, 02:37 PM
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Definitely have to watch your lean. Slow down and take corners a little more upright while you get a feel for how much you can lean it without striking a pedal.
seau grateau is offline
Old 10-05-19, 03:00 PM
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times in 56 Posts
Again, a bicycle with a high bottom bracket is the ticket. That 12 to 15 mm is significant due to the angles, it matters and cannot be rationalized away. Or, install a free wheel.
Loose Chain is offline
Old 10-05-19, 05:00 PM
JohnDThompson
Old fart
I use 165mm arms on my fixed gear bikes; one is a road conversion, the other dedicated fixed gear.
Old 10-05-19, 06:29 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
+1, that's the big thing for now. Whether you're going fast or slow, you can't bank into corners with a FG like you can a road bike.
A high bottom bracket makes up for a lot of issues, but since you can't change that on this frame, there are other things to look at:
- Are you using the correct (short) bottom bracket for this crank? I've seen a number of poorly-thought-out conversions where they just stuck a SS crank on their old bottom bracket, or took the small ring off their road double and wrapped the chain around the big ring. Either way, the cranks are out too far, increasing the risk of pedal strike.
- A crankset with a low Q-factor would help. Some cheap generic SS cranks have a wide Q-factor in order to clear the chainstays on any frame.
- Shorter cranks are a good idea, regardless. See if you can exchange your 170's for 165's.
What crankset and BB are you running now, @Maslin?
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-05-19, 06:54 PM
ryan_rides
ryan_rides's Avatar
Quoted: 145 Post(s)
This is the same bike with different cranks but the same length 165 but with BMX platform pedals and straps and I did sometimes have pedal strike but rarely.
This is my track bike currently with look road pedals and I've never had pedal strike with them.
Likes For ryan_rides:
Old 10-05-19, 07:08 PM
Maslin
Quoted: 17 Post(s)
170mm Sram Red Carbon 10sp crankset. Chain ring is mounted on the inside of the arm.
looks like it could lose 4-5mm toward the chain stay, although my heels are closer on this than any other bike I’ve had.
It’s definitely a combination of parts that aren’t ideal. I’ll keep an eye out for a 165mm single speed crankset.
It would obviously work better as a single speed, but where’s the fun in that.
Maslin is offline
Old 10-08-19, 07:33 AM
rustystrings61
Quoted: 823 Post(s)
Liked 1,395 Times in 694 Posts
For the life of me I can't find the article or discussion online, but I remember reading about the Walden Turn, named for Mike Walden of the Wolverine Sports Club - essentially you kept your bike more upright and leaned your body into the turn, thus allowing you to continue pedaling through the turn. I've been doing that for maybe 15 years now, to where it's ingrained behavior on a fixed-gear, and so far it has worked nicely. I think that maneuver was also described in Delong's Guide to Bicycles and Bicycling. It's a holdover from the era when almost all U.S. racing, road or track, was on fixed-gears.
rustystrings61 is offline
Likes For rustystrings61:
Old 10-08-19, 08:47 PM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
Maybe this?
https://www.nytimes.com/1991/12/08/t...ain-of-it.html
FiftySix is offline
Old 10-09-19, 05:33 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,057 Times in 631 Posts
European racers use this same technique to get around muddy cobbled turns. I use it lot for turns on pavement where there's sand or gravel and I'm not confident of being able to get good traction.
Lemond1985 is offline
Old 10-09-19, 07:42 AM
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
Yep I’ve definitely used this technique when I need to pedal as fast as possible while leaning as hard as possible. For example, when going through a roundabout. OP, find a roundabout or other long sweeping turn and practice. That’s the best way to get a feel for how much you can lean.
Watch fixed gear crits and see if you can replicate their setups. Those guys lean harder than most normal roadies. It just comes down to high BBs and short cranks. Some guys will time their hardest lean with the moment their pedals are away from the ground. That’s much tougher but it’s high risk, high reward.
smashndash is offline
Old 10-09-19, 11:36 AM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
Hauling ass around corners, carving deep lean angles.
SquidPuppet is offline
Old 10-09-19, 11:45 AM
Maslin
Quoted: 17 Post(s)
Yeah... I flipped the flip flop back to freewheel. I'll give fixed another shot, but I'm really enjoying it either way. The simplicity of a single speed is calming. Even commuted on my 18 mile loop Monday, my wife likes that I'm not leaving her behind on it, 42/16 only spins out so fast.
Thanks for the replies, that article was interesting. I'll try some corners superbike style and see how it goes.
Maslin is offline
Old 10-10-19, 10:04 PM
tashi
Quoted: 75 Post(s)
Liked 36 Times in 23 Posts
I hear ya. I tried a fixed conversion for a while.
Slow down hills and couldn't dive into corners. Boooo. SS instead for me thanks.
tashi is offline
Old 10-10-19, 11:33 PM
BicycleBicycle
BicycleBicycle's Avatar
Quoted: 49 Post(s)
Liked 11 Times in 11 Posts
I had a conversion once.
I guess I got lucky and the BB was already high.
I would notice small pedal strike, but I thought it was normal and just avoided learning too hard (or I would sorta ease into the turn to see if it was possible).
It never put me on my derrier though.
When I bought a proper FG frame, I never had pedal strike, and I had been in some extremely leany turns.
So, I guess like others have said, the BB height matters.
BicycleBicycle is offline
Old 10-18-19, 05:39 PM
takenreasy
takenreasy's Avatar
Bikes: ’83 Bianchi Special ’96 Specialized Stump Jumper Comp ’09 Gary Fisher Paragon ’09 Surly Cross Check ’11 Surly Long Haul Trucker
Quoted: 71 Post(s)
Liked 76 Times in 50 Posts
My fixed gear bike is a Surly Cross Check which has a high BB. I can really "hammer it" through the turns (60 yrs old).
takenreasy is offline
Likes For takenreasy:
Old 10-18-19, 06:26 PM
BicycleBicycle
Quoted: 49 Post(s)
Geeze, that crank arm is practically a kickstand.
Likes For BicycleBicycle:
Old 10-20-19, 08:42 AM
bedtime
bedtime's Avatar
Bikes: Louis Garneau road bike converted to fixie for artistic cycling
Quoted: 57 Post(s)
Liked 34 Times in 24 Posts
My peddles touch, too,and I don't even have to lean in much at all. My bike was initially a road bike. The cranks are 170 mm, ugh. To make matters worse, my peddles are quite long.
Doing tricks, such as steering with feet, can be tricky, as falling from such a position wouldn't be easy to bail from.
I have one ever so partial remedy, but I cannot speak for your safety, unless it is done correctly. Chances are this issue has resulted from using a road bike which has vertical dropouts; so, you could gain a 1/4-1" by using a dropout converter and solve the chain tension problem in one go.
BUT! You must install it correctly, or your bike will be even more dangerous! That may involve welding, so it doesn't move.
I haven't done this yet but am still thinking it over.
Just an idea.
bedtime is offline
Old 10-20-19, 10:11 AM
REDMASTA
REDMASTA's Avatar
Quoted: 278 Post(s)
https://www.bikeforums.net/21151273-post2.html
REDMASTA is offline
Old 10-21-19, 10:51 AM
Maslin
Quoted: 17 Post(s)
The LeMond Fillmore has the same 70mm BB drop. A true 165mm SS crankset that barely clears the frame must be the way to go.
I could lose 4-5mm on each side in width, along with 5mm in length. Some Look Keo's and I'd be as far out of the way as possible.
I'm beginning to think the issue of clipping a pedal has much more to do with the road than the bike. I can lay the bike way way over before the pedal hits in my garage, but I tap it fairly regularly when actually riding.
I'll stop thinking now and go ride a bike, too bad those Fillmore's are so hard to find
Maslin is offline
