FD for an old MTB
Quoted: 5888 Post(s)
Liked 3,471 Times
FD for an old MTB
I'm rebuilding my 1993 Trek 950. The front derailleur won't shift to the smallest chain ring as the spring is too weak. So its time to replace it. The cables run along the top tube and I had a few questions about a replacement FD. The tubes are oversized and measure out to 33 mm on my calipers. The chainrings are 46/36/24 and I'm using thumbshifters.
The bike came stock (pics below) by routing the derailleur cable to a stop along the bottom bracket and then back up to the FD. There is a stainless plate attached to the FD which provides both a stop for the cable housing (as the cable snakes down the frame) and the stop for the cable at it comes back up the FD. I could find a bottom pull FD and simply transfer the stainless plate over. I think that's the easiest solution.
(1) Frankly it's a bit of a kludge. I'd like to use a top pull FD but there is no stop on the frame for the cable housing. Does someone make a stop I can use or is there a way to make one?
(2) It might be hard to find a top pull that would work with this right, as I think most of those are MTB FDs and the new ones might not work right with my chainrings (46/36/24)? Or am I wrong about this?
The first pic shows the long run of cable housing from the top tube down to the plate on the FD; the second is a close up of the plate on the FD.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12774 Post(s)
Liked 7,692 Times
Looks like it's actually a 92 according to vintage trek. Have you tried unscrewing the inner limit screw to see if that lets it shift to little ring?
If no joy, have you tried disconnecting the cable from the FD to see if it then shifts to little ring?
It looks like an awfully small radius run-around at the bottom. Is it perhaps missing a pulley down there? What exactly is the cable wrapped around at the bottom of the run?
Liked 3,471 Times
Yeah likely a '92 based on the LX derailleurs; looks like the '93 had an XT RD.
No joy with the FD as it will not shift down even with the cable disconnected.
Yeah there probably was a pulley there at one time but now all I have is the cable wrapped around a screw. I bought the bike around 2 years ago and this is how the bike came to me.
Maybe I need to try to track down a pulley. I guess I'll visit the local hardware store to see if I can find something that will work. Any idea of something that might work?
That will be a non-issue though if I can figure out a way to mount a top pull FD.
Bikes: everywhere
Liked 7,692 Times
Liked 3,471 Times
You also need to unscrew the inner (low) limit screw. Yours looks like it's screwed almost all the way in. With cable off, you should be able to watch the FD move inward as you unscrew the limit screw. With the chain on big cog in back, and little ring in front, unscrew it until the chain no longer rubs on the inner plate of FD. You may want to go a quarter turn past where it stops rubbing. Then screw the barrel adjuster on the shifter all the way in, then back out about a half turn, then attach cable. Don't pull the cable overly taught if you pull it really taught upon attachment, FD won't shift into small ring. If cable is too loose upon attachment, unscrew the shifter barrel adjuster as needed.
The limit screw and cable tension are fine and not the source of the problem.
I'm not sure where to find a pulley though but maybe the local hardware store has something that could work.
Bikes: everywhere
Liked 7,692 Times
Is the bolt right between the chain stays? How much room is in there?
Here are a couple of pulley options:
https://www.jensonusa.com/Problem-So...m-Cable-Pulley
https://www.ebay.com/i/273139871279?...hoCnvgQAvD_BwE
Liked 3,471 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
You might also look at the alignment of your derailer. The picture may be distorted but it looks like the tail of the cage is slightly inboard. This could cause your problem.
Yes, you need that pulley at the bottom. Alternatively, you could add a cable stop on the seat tube using this from Problem Solvers. You’d need a top pull derailer but the routing would be better especially since you seem to be missing the pulley.
Stuart Black
Stuart Black
Liked 3,471 Times
Quoted: 1609 Post(s)
Liked 2,590 Times
The clamp diameter should be stamped on the inside of the clamp.
https://www.ebay.com/itm/1-set-Foldi...edirect=mobile
Liked 3,471 Times
The problem solvers pulley is 27 mm wide which is far too wide for this bike as the space between the chain stays is 20 mm. The ones that @curbtender linked to on eBay look good but they are too wide as well at 23.3 mm (assuming the info on ebay is right). @LesterOfPuppets was right on the money on this.
https://problemsolversbike.com/produ...pulley_-_24765
Solution 1 is to take it down to the bike shop to see if they have a pulley that works.
Solution 2 would be to get a problem solvers clamp with a pulley like this
https://www.modernbike.com/problem-s...ley-31.8-black
Solution 3 would be to follow @cycocommute's suggestion and get a seat tube cable stop. I like this this one because I think it will end up being less of a kludge but I'm not confident that a modern MTB FD with dual pull with handle my chainrings.
Liked 4,218 Times
Good call on the cable stop, thank you. Yeah I agree that a top pull FD is likely to work better but I'm not sure if the MTB FDs which I think are dual pull will work with 46/36/24 rings. I don't believe--and I could be wrong--that the road type triple FDs are top or dual pull.
Stuart Black
Stuart Black
Bikes: everywhere
Liked 7,692 Times
So I think you're right and the lack of a pulley is the source of the problem. The FD doesn't shift down as far as it should with the cable disconnected (I think the spring is weak) but it will shift far enough down to shift to the small chain ring.
Trek may have fitted a pulley on a bracket to get it above the stays, or possibly on a spacer to get it back far enough to fit.
Liked 2,590 Times
This guy has been selling these for years if you are looking for a stop...
https://sfbay.craigslist.org/sby/bop...994558854.html
Misc Bolts and Small Parts - $1 (san jose north)
image 1 of 7
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
can you just run that FD as a bottom pull by rerouting the cable ? the top pull does not look like a smooth shifting set up.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Liked 3,471 Times
I reckon this will work a bit better with a top pull FD as the cable run will be cleaner but either option should work.
Liked 2,590 Times
Not sure on sizes, but maybe you could use a sewing bobbin.
Likes For curbtender:
Quoted: 1438 Post(s)
Liked 1,092 Times
I am shifting a 42/32/22 crankset with an Alivio FD-M410, and it worked fine when had I put on a 46 tooth chainring; I removed it only because I preferred the lower gearing.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
First make sure the existing derailleur is not binding due to corrosion, dirt, etc. -- it's rare for modern FD springs to weaken.
There's a fourth & simpler solution for this setup:
Run housing directly to the anchor on the FD (with some slack from the stop on the top tube -- probably enough slack as-is) and let the inner cable slide past the anchor bolt while the housing ferrule presses on the top of the anchor. Don't tighten the anchor bolt. Then anchor the inner with the lower bolt.
Liked 3,471 Times
Liked 3,471 Times
But a lot of the MTB FDs are rated to 40 teeth, right? This shimano alivio is rated to just 40 teeth:
https://www.amazon.com/Shimano-9-Spe.../dp/B00OZPPC72
I'm not saying it won't work with a 46 tooth chainring; I'm just saying I'd rather not be the guinea pig on this one.
Liked 3,471 Times
Here we go
https://www.bikeforums.net/bicycle-m...o-fd-m591.html
Post 11 talks about how modern MTB FDs are made for 12 tooth jumps and may not work right with a triple with 10 tooth jumps. Some of the reviews of the Deore FD on Amazon make the same point.
So this may be a different reason to stick with a bottom pull road type FD on this set up as I'm running 46/36/26 rings.
Likes For AnkleWork:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
One more option for your pulley if you go that way.
https://www.ebay.com/itm/Sturmey-arc...kAAOSwhL9c6z5c
Liked 4,218 Times
I hear you guys and I think that's the solution I'm going with (top pull FD and a cable stop for the frame). This will make for a cleaner cable run and that should help the FD.
Stuart Black
Stuart Black
Likes For cyccommute:
