Totally Tubular
#1326
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Had something similar about a year ago with a Schwalbe S-One. When I stopped for the flat there was no adhesive at all between carcass of tire and base tape. Tire had hunched up a little in front of valve and that area of tire had many small cuts. On an otherwise totally uncut tire. There was no thump thunp before the flat. Or I didn't feel it because it was a 30mm tire. Mondiale is a basic tire, mine was top of the line and two failures sound about the same.
My tire was well worn and punctured near valve so I just let it go. You could glue the carcass of tire direct to rim. All you lose is the ability to re-stitch and patch the next flat. For a while I was manic about checking that my tires were glued and glued. It could happen. We both lived to tell tale.
Never try to teach a pig to sing...
#1327
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
I've wondered if there is an incompatibility between certain tire and rim adhesive brands. I've had the base tape on certain tires pucker badly and come loose from the tire edges in the past. I suspected that the solvent in the rim glue dissolved the base tape's adhesive?
#1328
Quoted: 1361 Post(s)
Liked 423 Times
Vittoriayoyo. Out of the wrapper I had to re-bond parts of the outer layer. That done and now using, I also noted the comical information on the sidewall. This IS ONE tubular.
Poochee just might get his wish as a chew toy.
#1329
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
You referring to the "clincher" pressures? I've seen that before, and similar notices "when used on a <whatever> rim". It looks like they use one mold for the tread rubber for both tire types. I guess it saves tooling costs.
Real cyclists use toe clips.
jimmuller
jimmuller
#1332
only here for the "LIKES"
Quoted: 1642 Post(s)
Liked 2,235 Times
#1333
Quoted: 1163 Post(s)
Liked 442 Times
My old Vittoria “Pro-L” slick tubulars could have benefitted from some of this. I retired those tires merely because the base tape had perished.
This prompts a logical follow follow up question: is it possible to purchase replacement base tapes anywhere?
If you could just rip the old one off and contact cement a crisp, clean new one on - that would give new life to some of our questionable used tubulars that are laying around.
#1335
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Tufo's can't be repaired in a traditional sense, because as you say, the tube and tire is a "unibody"
That said, the concept is that the "unibody" makes them more durable and "designed" to work with sealant to seal small leaks.
In both types of tire, a large slice largely makes the tire toast.
For smaller punctures, sealant can be added after or before, as a preventative measure.
Sealant in a traditional tubular has varied results, and the sealant will be squirting from the tube into the casing before it seals.
I had some luck a month or so ago on one of my Vittoria Pave with sealant, held enough to get home, but was not a permanent fix - once I pumped it back up to 80 it held until half way through the next ride, then flatted again.
With the Tufo, the sealant makes more of a permanent fix (except for large cuts).
#1337
smelling the roses
Liked 901 Times
Something to do when it's too hot to ride?
If you do try sewups, make sure they have removable valve coreser so you can squirt some Stan's Tire Seal in them. Also check out TireAlert.com. Or consider that patching sewups is something else to do when it's too hot to ride.
Rambling enough for you?
#1338
Quoted: 140 Post(s)
Liked 13 Times
Can use a traditional car tire-type plug patch like they use for patching larger holes on tubeless tires (see photo)
I see no issue patching old-school way, it is just time consuming.
Also depends on what type of flats you get. If you have thorns around, sometimes it is hard to get the thorn all the way out and then you get another flat.
If you don't get alot of flats on clinchers, I would expect similar performance on the tubulars.
Nice rims BTW - they are begging for Tubasti!
#1339
Liked 645 Times
I do physical patches for flats in clincher tubes. Eventually I replace the tube but only after it has proven itself to be untrustworthy or has leaks at the patches, or patches at the patches. If I'm on the road, especially commuting, finding a small leak in a tube can be tough so I'll swap in a different tube and patch the leaky one when I get to work or home. I've done some physical patches of sew-ups but I'm not especially good at it and I don't have much free time to do it anyway. Stan's Tire Seal works well enough for small leaks and is especially good because it works fast. On a commute it lets me keep going without spending 10 minutes installing a spare tire (or 20 minutes swapping/patching a clincher tube). When I've collected at least two sew-ups that didn't seal well with Stan's or that have sealed but won't hold much pressure without blowing out again, I'll send them to Tire Alert. My time is worth more than it costs to pay Tire Alert to fix them for me, and he does a FAR better job! I've got one Vittoria that I'm thinking of just pitching because the tread shows so many small cuts that it is probably vulnerable to more.
jimmuller
jimmuller
#1340
smelling the roses
Liked 901 Times
#1341
Quoted: 1949 Post(s)
Liked 2,010 Times
I haven't had to patch one in a while so I'd thought I'd share. One step that was always difficult for me was glueing the base tape back on securely and smoothly. I've settled on this latex adhesive from the local hardware store and painters tape to keep the base tape on while the latex dries. This was my first time sewing the casing back together around the stem. It seems ok.
Likes For Classtime:
#1342
Quoted: 834 Post(s)
Liked 2,125 Times
@Classtime, That looks good, I have a few extra pieces of hardwood flooring strips with grooves/channels on the bottom. They are a good fit for the base tape side of the tubulars. After repairing a tubular, I press the tire between the hardwood flooring strip and a flat strip of wood on the rubber side in a vice overnight. One could easily drill a hole through the flooring strip to accommodate for the valve.
#1343
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
Finally, trying the tubulars again. Back in 2017, just before my LBS retired, I got a pair of Conti Giro's. Had my old wheels trued, cleaned and mounted the tubs, with Tufo tape. After hanging on the rack, for the winter, I put them on my Concorde, only to discover, the rear had developed a flat spot(over tensioned in one area). So, I hung them back up. Now with 7 bikes and spare wheel sets, it was time to buy an truing stand, rather than paying another LBS $15 a pop to tru my wheels, After 1.5 hrs. playing with that rear wheel, I got the flat spot out. Re-taped the rim, mounted the tub, and added some Stans sealant for good luck. Found a good spare tub, and like the olden days, strapped it under my saddle and away I went. Sixteen, sweet miles and one 40mph down hill run, it was totally , pure fun. Although, 22mm tubs, aired to 120lbs. was a little bone jarring, after todays rain, I'll work on lowering the pressure a little. All my bikes have been converted to 25/28mm tires and found the lower pressures, nice.
And yes, the Conti's do not have a removable valve core. Installed the Stan's at 10 o'clock, inflated the tubs, bounced them around a bit, rechecked the valves for any sticking. Checked again today, nope, no sticking valves and aired up just fine.
Now, if I can find a good air pressure, I'll ride the tubs, the remainder of the season. Was inspired by this thread. KB.
#1344
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Some good prices at MerlinCycles.com
https://www.merlincycles.com/road-bi...e_type=tubular
the Vittoria line seems discounted the most.
#1345
“Senior” Member
I have patched patched using the open up traditional method twice on one with good results. Found it fun in same manner as building wheels.
A friend who I bought my Bruce Gordon from found this in his garage and gave it to me. Kind of a blast from the past. Did not have a good place to share, so this thread seemed a good place.
Likes For obuckler:
#1346
#1347
Quoted: 1324 Post(s)
Liked 927 Times
I have a number of tubular wheelsets with Shimano Uniglide freehubs. A couple of them are Dura Ace 6 or 7-speed ones. I also have a set that's Campagnolo Triomphe with a freewheel. Plus I have one orphan rear wheel that's a MICHE 8-speed cassette. I don't recall whether it's a MICHE hub or a Campagnolo one.
I recently mounted Hutchinson tubular tires on my Triomphe hub tubulars. I'm still trying to get a bit of a high spot out of the rear wheel.
What I'd really like to do is get a couple of pairs of rims that i could simply swap with the tubular rims on two of those wheelsets. I mean by taping the clincher rim to to the existing tubular rim and then transferring the spokes to the new rims.
Btw, one day due to absolute necessity I discovered that you CAN use a tubular tire on a clincher rim in an emergency. Just pump the tubular tire up until it's hard. I rode it to a bike shop the day after I did that and the guys there were astounded.
Cheers
Cheers
#1348
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Hmm... Maybe get accurate spoke length and hub dimensions on the front wheel then back into the necessary ERD? If you can do that I think it will tell you what rims will swap.
#1349
Liked 927 Times
Cheers
#1350
Cheers
Cheers
Be careful with the tubular on a clincher rim. Use high pressure to keep it on. Don't expect it to last long. The tubular will squirm a lot and the sidewalls wear against edge of rim. Base tape is all inside well of rim and load is sidewall of tire to lip of rim.
