Ask your small, random, track-related questions here
#3626
Bikes: Serotta steel track bike, Specialized MTB
Quoted: 99 Post(s)
Good handling is related to the weight balance (the amount of a rider's weight that is over the front wheel, and over the rear wheel) - and that is related to stem length.
Also, good athletes tend to be flexible, and able to ride a long and low position comfortably, while putting out power. And, it's more aerodynamic.
I was just wondering why would they make their top tube shorter(custom frame) to fit long stems.
#3627
Anyone use a Planet X track frame on the street? With the Planet X stealth fork for brake? I love the look of this bike but don't ride velodrome. Thanks.
#3628
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
#3631
I just meant I didn't think it was a big deal to post it here and not there since the bike itself is mainly a dedicated track bike and not very associated with street riding. I'll try over there.
#3632
Lapped 3x
It isn't a big deal. We're happy to field questions from anyone that comes through here. We'll redirect only when we think you'll get a better answer somewhere else. Most guys that come through here don't ride their track bikes on the street, and if they do have a tarck bike for the street, it will be very different from their track steed. It's not that we can't help you with the bike, it's that we don't have any experience with what your end use of it is going to be.
#3633
New member here. Just wondering if anyone had any experience with Planet X pro vs Planet X Kochi-san frames. I was also wondering if any aero testing data was public available for track bikes frames. Thanks!
#3634
Elitist
Liked 92 Times
I used the Planet X Stealth Pro Carbon back in 2009. It's probably different now.
Aero testing data isn't common and is usually only released as part of marketing materials, so should be taken with a grain of salt. Independent aero testing (like you see with many road components) is rare for track components.
#3635
Quoted: 99 Post(s)
Aerodynamic is not a big issue in track world.
Instead Stiffness and geometry is more important than aerodynamic.
Carleton once said "If you are not losing by .01second aero equipments are not going to make a difference"
Also Planet X frames are not that stiff, so I recommend other track bikes such as Hoy track bike and other
#3636
Well, being a small endurance rider, I'm not sure stiffness is too much of an issue for me. Frames at my size tend to be pretty stiff anyway. As for aero, I kind of hoped on aeroing my way to a medal at Masters Nationals. I doubt I can make over 1000w in a sprint finish, so I have to get my speed from somewhere.
#3637
The Planet X frame geometry is fine.
Where you you get the Planet X frames are too flexy? Especially since we don't know the weight or race preference of the person asking. I have both a Planet X Track frame which you say is flexy and an overweight and over engineered BT Stealth and personally can't notice a difference.
#3638
Hi and welcome to the forum.
#3639
Planet X do make some claims about the Kochi San frameset... But as Carleton alludes to, you need to take anything a manufacturer says with a grain of salt.
#3640
I have a converted Zipp Predator (The original Zipp disc) which I got for free and a Zipp 950 I used till a few years ago on my TT bike with an 8 speed screw on cluster I'll convert shortly. The disc is now permanently bolted on the bike which is raced a couple of days a week and the disc has been rock solid. I have heard concerns of the glue holding the hub to the disk failing but mine looks fine and holds up to my skinny enduro leg sprints...
#3641
Particularly note the opus - Aerodynamics of Track Cycling by By Lindsey Underwood in the first post.
#3642
Not comparing frames, but some Interesting journal articles in the following topic -https://www.bikeforums.net/track-cycling-velodrome-racing-training-area/987591-journal-articles.html
#3643
I'm a true believer in aerodynamics. Though on the TT bike, I came out of my windtunnel session ~43 Watts the better. Only 10 Watts was from a faster helmet, the rest positional! No way I could have made that improvement in 2 hours training...
If going out and needing to buy a frame anyway, why not also consider aerodynamics! It's not like focusing on aerodynamic gains is mutually exclusive to all the other necessary things required to be a fast cyclist. It just complements it...
#3644
I haven't seen the Koichi in the flesh, but can comment on the stealth.
The tube shapes such as the down tube are surprisingly not true aerofoils. Appears more 'aero' than the aluminium frame it replaced.
For pursuits - I had to use an adjustable stem to get lower due to the tall head tube.
Since you are in the US, have you considered the Affinity Kissena?
#3645
Well, I'm on a Masi Coltello right now. The version I have is known cracking at the seat collar, and I've had it repaired once. It will probably have to be replaced at some point soon, so I've been thinking about other bikes. I've been out of the latest track developments for a while, so I really don't know what's out there. I'll look at the Affinity.
#3646
Quoted: 27 Post(s)
"A. Lukes et al. [2005] state that an aerodynamic frame is 3% faster than a normal frame, and by shielding the components the drag can be reduced. Kyle and Weaver [2004] also state that by hiding the screws, bolts, fastenings and other external components, covering the under saddle, smoothing the cranks and sprockets, and having long, thin aero elements for the frame, the drag can be reduced by as much as 14%. According to Lukes et al. [2005] the handlebars contribute to 10% of the total drag on the frame and components (excluding the wheels, saddle and seat post) which is equivalent to approximately 3% of the total drag on a cyclist (the frame, wheels and components account for only 30% of the total drag on a cyclist)."
Doesn't this imply that the reduction in total drag of bike+rider that can be expected by optimizing the frame for aerodynamics is less than 0.14*0.03 or about 0.4%?
#3647
Quoted: 27 Post(s)
Does anyone know of a good SRM PC8 stem mount? I use 3T Scatto bars, so the regular mount isn't an option, and I don't want to resort to the so-pro under saddle setup unless and until forced to do so.
#3648
Elitist
Liked 92 Times
I'd ask on slowtwitch. They have a lot of funky setups with aerobars and SRMs are popular. That's where I learned of the stem mount for the SRM that you see in my pics. I think it was made by an engineer working out of his home as a side project. I got it back in 2011, so the details are fuzzy.
#3649
Quoted: 27 Post(s)
