So if aero trumps weight....how deep on the wheels???
Flo wheels says so, so I'm goin all the way.
So 30mm deep? 50mm? 30 front, 50 back?
How 'bout these?
1275G Wheel Set 38mm Clincher Carbon Cycle Wheel 700c Bitex Hub Light Aero Spoke | eBay
(Yes, there's a little sarcasm spread throughout and then a moment of "wtf, maybe I should" sprinkled in there too)
How 'bout these?
50mm is very standard for pro riders. Aggressive would be 80mm.
Quoted: 1186 Post(s)
Liked 289 Times
How 'bout these?
How 'bout these?
Well, despite Flo's recent test results, plenty will still go to the grave with their 1,100gram alloy wheels.
Also, I linked to a set of $400 complete w/ pads & skewers....carbon clinchers. Assuredly I say to you.....they will asplode, if not spontaneously combust.....or both.
And then I'd otherwise think that 50 deep carries a little penalty (although Flo's tests went up to 90's and even flat disc in the back proving otherwise) so my honest armchair opinion is probably somewhere between 30 & 40 for efficient all-around depth.
And all this to stoke the fire cuz it's Friday, just got paid & am shopping wheels.
Liked 289 Times
Quoted: 6556 Post(s)
Liked 58 Times
Say what you will, and Flo can too, I will never again use rims that are CF and 38 mm or more deep. Too noisy, too unstable in the wind, too unreliable braking in the wet, etc., etc. I don't need and can't make use of the speed advantage so I won't put up with the BS for no good reason. I ride light, shallow aluminum rims, because I like how they sound, stop, ride and feel. I go as fast as I feel like whatever that may be. That is good enough even when it isn't terribly good.
Liked 289 Times
If you are a light rider sub 130 pounds, 38 all around should be pretty nice. 38 and 50 is a pretty popular combo, even for some windy situations. I am 140 and I ride 50's, they are noticeable in the wind, but definitely not enough for me to crash. 60's can be a little hairy for the light riders, I would probably not go over 60.
My experience with deep wheels, and others that I rarely ride with in some groups.
Bikes: Roubaix SL4 Expert , Cervelo S2
Quoted: 85 Post(s)
I just got some new Zipp 404's. They aren't noisy and braking seems just as good as my AL rims with the supplied Zipp pads. They can be a handful in gusty crosswinds but I've heard 303's aren't that much better. I've also heard that 808's can bog you down in a paceline.
Should Be More Popular
Quoted: 22572 Post(s)
Liked 8,918 Times
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Interesting to watch pro races, and on flat events, many riders are using low profile rims. You would think they'd all be riding 50+ mm rims based on the hype.
Personally, I used 50mm carbon tubulars for racing, and everything else is some basic low profile aluminum rim.
In a group??
Solo??
And curious as to what alu rims you had before the 404's.
TIA
Quoted: 85 Post(s)
I only ride solo. With my aero bike + 404's I notice the reduced drag compared to my 'standard' road bike especially riding along the coast with a direct crosswind (higher yaw angles are where deep wheels really shine.) Speed is not a great metric because it depends on the wind that day. My other wheels are Kinlin XC279's. FYI, keep checking PBK if you're interested in 404's. They had a set for $1835 up yesterday (figure another ~$125 in import duties.)
And your Kinlins are my other go to. My conscience keeps telling me that 27 is plenty deep, there's plenty of everything I want in a wheel like that and Bdop's kit is perfect. $300 and I'm out. I can learn to build up my own wheels. It'll justify me buying a few new tools (spoke tensioner, maybe even truing stand, etc.) and I'll have tons of money left over vs buying a $2K set of wheels which the wife would certainly hate me for.
Quoted: 85 Post(s)
Yes, wheels get sent tracked with PBK which means you pay duties. Smaller parts under $200 probably won't get hit. I don't know if you've seen the recent Tour magazine test but deep wheels definitely make a difference at higher yaw angles. By comparing the Shimano RS 010 vs the RS 32 you can see that a deeper AL rim like the new Kinlin 31T will reduce the aero penalty vs. deeper CF wheels.
https://forum.slowtwitch.com/gforum.c...;so=ASC;mh=25;
Bikes: Fuji roubaix 1.1
Quoted: 20 Post(s)
i could get a carbon wheelset but nah plus i have some rough roads i think carbon wheelsets are for very smooth roads wich i dont have here where i live
Nice!! Although I don't follow where they talked AL rims. Looks like the clear winner in that price/performance graphing was the Hadrons. Though they also don't say which Hadrons. Being honest, I can't say I've ever even heard of Hadrons (SwissSide?) before. Even converting from pounds to dollars, looks like they're a great deal if those graphs are accurate.
And looks like HOOPS has some nice Kinlin 31T based wheelsets ready to go. (Not that Bdop couldn't do them too)
(shrug?)
Thanks again! Great info.
(shrug?)
New Tour tests of 2015 aero road bikes: Triathlon Forum: Slowtwitch Forums
Quoted: 85 Post(s)
They tested the stock wheels that came on the bikes, some of which were AL wheelsets, and compared them to the Swiss Side Hadron in the wind tunnel. I'm pretty sure it was the Swiss Side Hadron 625 since the 485 wasn't out yet at that time. It is an AL rim with a CF fairing but they are hard to beat for weight/performance at that price. Bike Hub Store sells their own branded version of the Kinlin 31T rim if you wanted to build them yourself.
Bikes: Wheelbarrow
Quoted: 19 Post(s)
404's are 58mm deep. Up front that's just a bit much more often than not if there's any sort of wind.
