Winter Cycling Questions
Quoted: 72 Post(s)
Liked 19 Times
I'm new to winter cycling as I have lived in Miami and Phoenix most of my life. I'm now living in Northern Arizona where it snows a little in the winter . We don't get a lot of snow and if we do most of it will melt in a few days . What were looking at is patches of snow and ice under the canopy and mud in the open. I don't want to buy a fat bike as I don't have room for another bike. I'm going to use a carbon 29er hardtail as I want to keep my 27.5 fs as is. I'm going to have to buy 4 tires as my wife rides with me and also has a 29er fs. I've looked at most if not all the snow tires but would like a little advice on which to purchase for winter riding . This is not Minnesota so it can snow 15 inches and 2 days later be 60 degrees. Like I said patches of snow and mud. If someone could give me a recommendation and point me in the right direction that would be helpful. We're looking at 400 to 500 dollars here so I'd like to get it right the first time.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 190 Times
Buy a cheap wheelset, studded tires, and wash your bike. Or just ride, and wash your bike. Lots of folks here in Ottawa just use normal knobbies, I like having the studs.
Clothing, esp. mitts or gloves, are probably further outside your experience.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I see snow infrequently, but quite a bit of ice in some years. As for the snow, if it's a couple of inches or less, mostly fresh (since it melts) just ride through it. No special tires, regular road bike, no problem.
Where it has been a problem is when there was a lot of ice, snow on top ankle deep or more, and it begins to melt during the day and re-freezes overnight. Treacherous hidden ruts and slippery, that's where I'd want your wide "snow tires" but more for the ice underneath.
Quoted: 539 Post(s)
Liked 44 Times
https://www.schwalbetires.com/bike_t...d_tires/winter
They make another version called the "Schwalbe Marathon Winter" that I use on my bike that has 4 rows of studs, but it might be overkill for your situation.
If you don't want studs Continenal makes a tire called the Top Contact Winter:
https://www.continental-tires.com/bi...inter2-premium
I personally will not ride in the winter where there's any chance of ice with no studs so I don't really recommend it.
Quoted: 590 Post(s)
Liked 445 Times
+1 Schwalbe Marathon Winter They roll over black ice like it isn't even there, but you need to slow your roll around corners on dry pavement, since friction is reduced by the studs. There's videos of people doing tight turns on ice rinks while using these.
Quoted: 1074 Post(s)
Liked 295 Times
I’ve used SMWs on my commuter and was less than impressed.
It’s a good tire for mostly bare roads with icy patches, but mine failed FAST.
The studs wore through the carcass, chafed the tire and caused flats.
Schwalbe did good though, and sent me some new ones.
Suomityres W240 has more rolling resistance, but far greater longevity.
Better traction in soft stuff too.
Bikes: Nashbar Road
Liked 341 Times
Would you really want studded tires for occasional ice patches in the shade, that usually melts off in a few days?
Quoted: 5224 Post(s)
Liked 3,581 Times
you might just see how it goes with what you have
there are (non studded) "winter" tires I've seen (but not used) with an interesting tread (Michelin Star Grip Winter Tire) & I have bought tires several times happily from BikeTiresDirect
I'm a fan of fenders in general, but especially for melty snow & mud
If you encounter any ice at all, get studded tires. Don't risk a wipe out even if you're riding on trails only and especially on roads.
When you get home, make sure you wipe and dry your bike and get rid of the slush under your bottom bracket. I just spent $180 replacing a rusted bottom bracket for neglecting this over a three year period.
Quoted: 800 Post(s)
Liked 218 Times
I'm new to winter cycling as I have lived in Miami and Phoenix most of my life. I'm now living in Northern Arizona where it snows a little in the winter ...
(of Toronto) If you encounter any ice at all, get studded tires. Don't risk a wipe out even if you're riding on trails only and especially on roads.
I dunno, maybe it's my age showing Here in Rochester, at least along my commute, there's always ice that miraculously didn't get salted away. I figure gunk washes off quickly and easily. Broken bones would keep me off the bike for weeks while they mend.
…Carbide studs are reputed to last a long time. I ride studded tires all winter from December to March, nearly entirely on bare, wet, and/or salted pavement. However, now my beater bike is an aluminum Diverge Elite road bike and I have 30 C Schwalbe Marathon studded tires, the narrowest I know of.
I've not had a significant snow challenge with them since I ride well-plowed roads, but the previous (?) 35 C tires were good up to about 3 inches of new snow.
I really like the Schwalbe tires because I don't seem to feel the increased rolling resistance many claim for more aggressively treaded studded tires.
(of Minnesota)…If you might run into ice the Schwable Winter tire is the lightest studded tire I recommend. 2 rows of studs:
https://www.schwalbetires.com/bike_tires/road_tires/winter
https://www.continental-tires.com/bicycle/tires/city-trekking-tires/top-contact-winter2-premium
...I have been an avid cyclist, as a lifestyle since about 1972 [tourist, road and year-round cycle commuter in Boston]…I happened serendipitously on Bike Forums in 2008, and it was frankly incredible to find a community that shared so many concerns I had kept to myself as a lone cyclist.
This enthusiasm has definitely increased my enjoyment of cycling. As far as improving it, what I have gotten directly from BF [include]
- the motivation and tips to ride in rain, and wintry roads, i.e. studded tires
- the Fifty-Plus Annual rides that motivate me to train in the nice weather
- the safety tip to watch the front wheels of a car rather than the body or hood to anticipate what the driver is going to do
- the opportunity to post and literally "journal" my thoughts and activities about cycling and lifestyle (even if nobody else reads them), but which I wouldn't write down otherwise.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Quoted: 238 Post(s)
Just run regular tires and slow down.
Many (most?) Winter commuters here in the upper midwest I see riding around don't even bother with studded tires. Granted our roads are generally plowed but plowing doesn't catch everything, especially those freeze/thaw puddles or freshly dropped snow.
Studded tires are not a cure-all for slippery, deeply rutted, and/or poor road conditions.
Studs are meant to work best on ice. Unless you encounter frequent patches of freeze/thaw puddles that you simply cannot just ride around or get a lot of fresh powder coatings on top of a slick road surface I wouldn't bother for the amount of cash outlay and number of times they would actually be useful.
They really don't add much in deep(er) snow. A wet, slushy rutted road is better served with either a really thin tire or a really fat tire. Heavily rutted, frozen road? Walk. Even with studs. Frozen muddy stuff is not bad, free traction particles!
YMMV given the different experience, expectations and different climates we ride in. I'd try it with regular tires before dropping $500 on studded tires though.
Quoted: 800 Post(s)
Liked 218 Times
(from Toronto)If you encounter any ice at all, get studded tires. Don't risk a wipe out even if you're riding on trails only and especially on roads....
https://www.schwalbetires.com/bike_tires/road_tires/winter...
Just run regular tires and slow down..
Studs are meant to work best on ice…YMMV given the different experience, expectations and different climates we ride in. I'd try it with regular tires before dropping $500 on studded tires though.
…As I mentioned previously, all my winter riding is on well-tended pavement (major car commuting routes), and my most adverse conditions are smooth black ice or hard packed snow. If I’m out early in a storm then I might have to contend with new-fallen snow, and very rarely do I encounter frozen rutted snow. So I have found fully inflated studded tires to be suitable.
Furthermore, as I previously cited, even on dry pavement I keep the studs on in the case of sporadic icy patches, especially black ice.
I inquired about testing the studs, because unlike a frozen pond, which I never pass, it’s unusual to have significantly long stretches of slippery road to test the studs. If the surface is that slippery continuously, then I’ll soon find out. …
On the worst slippery day, I rode confidently, but had two near falls while walking.
Bikes: Stromer ST-1; Gary Fisher SAAB edition; Dahon Speed D7; Motobecane Grand Touring 1972
Quoted: 38 Post(s)
Yes, it only takes a little "black ice" to put a rider out of commission. I commute nearly daily, and the extra cost/slightly degraded ride is well worth it for me.
Bikes: Nashbar Road
Liked 341 Times
How occasional is it where you are? We'll get basically no snow, but some ice now and again, but dealing with patches here and there only maybe 10 or 15 days, I don't really even consider studded tires.
Quoted: 38 Post(s)
Even when there isn't snow, on my commute paths I frequently find some bits where there's ice ... at least in the morning.
Liked 3,581 Times
for example, maybe not from ice, but my Wife & several BF members recently had falls breaking wrists. so that's 6-8 weeks with a cast for a simple fracture, more if you get screws installed. then there's recovery after the cast is removed. not like new. weird shooting pains, weakness & other assorted discomforts. maybe a rider is good at falling, maybe he/she isn't so good at falling. reminds me, I took a ride last year, hit some ice with my gravel bike, almost fell. so I rode back home to get my studded bike. we get lingering ice on shaded trails when the rest of the town is dry & clear
Bikes: Nashbar Road
Liked 341 Times
Northern Arizona gets colder on average than here and a lot more snow, so maybe, but when he said patches and freezing overnight but melting daily I'm very familiar with that. Since I've commuted every day, every winter, I get that a lot. You can watch for shaded areas, or where it's been shaded earlier in the day, mud, drainage etc, and mostly avoid the patches. Where you can't avoid it, if you know it's there you can get across patches of ice without that much problem. I think that we tend to project from our own climate, and of course people in more frigid climates dealing with ice all the time are going to chime in more. They have more experience with it after all.
But I really believe that it can be overkill sometimes. I'd actually like an excuse to get studded tires but unless you're on ice more consistently and can't avoid it, it's a stretch. They're great for ice but for everything else, they're pretty horrible.
Liked 3,581 Times
Quoted: 539 Post(s)
Liked 44 Times
In contrast though, Flagstaff Az has a ski resort called the Arizona Snowbowl which is big enough to provide "200 full-time jobs and $12.08 million in economic output for the city of Flagstaff":
https://en.wikipedia.org/wiki/Arizona_Snowbowl
1,000 feet elevation - phoenix
7,000 feet elevation - flagstaff
12,633 feet elevation - humphreys peak (highest elevation in the state)
The state of arizona has both hot-desert weather, and minnesota-level cold and snow, depending on where you are and what the elevation is.
Liked 3,581 Times
You're probably thinking of Phoenix, Az which is a hot desert where it only dips (just barely) below freezing on the absolutely coldest days of the year/decade. In contrast though, Flagstaff Az has a ski resort & The state of arizona has both hot-desert weather, and Minnesota-level cold and snow, depending on where you are and what the elevation is.
Quoted: 539 Post(s)
Liked 44 Times
P.S. I ran across this graphic of the difference between the highest and lowest elevation point in the state. There's only 1 state with significantly more elevation difference (alaska) than arizona. Arizona is #6 :
Liked 3,581 Times
experimenting w the car my kids share/drive this year. put on some aggressive all-year tires. when the weather is really bad they don't drive. & if they do, they take my Cherokee w snow tires. having to changeover 3 cars is no fun. even Wifey stays home when the weather is bad. but when she was 1st pregnant 22+ years ago, her front wheel drive car slid off the road as she was coming home from work. so that clinched it for me, seasonal snow tires for her ...
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Winter in northern Arizona sounds somewhat similar to the Denver area, with fast and heavy snowfall followed by quick melting. When I commuted there I had one bike with studded tires, but only used it a few times a year.
I wonder if it would be an easier (and more efficient) option to pick up a (cheap) front wheel for both bikes and keep it studded. That way, you could quickly swap out the wheel on days when there's a threat of ice, gaining traction from a studded front tire, but go back to regular the next day when it melts.
Clothing guide when cycling
Like windproof jacket, Cycling kit, Cycling Mask, Gloves, Sunglasses and so on.
Here are hot now!
Here are hot now!
