Clunky downshifting after switching to double crankset (Ultegra 6800)
Peugeot PSV10 or somethin
I recently switched from a single speed crankset with a 39 tooth ring to Ultegra 6800 52/36 cranks. Everything else is Ultegra 6800 except for the cassette which is Sram.
Now I'm getting "clunky" downshifting on a few of the cogs, with both chainrings. What I mean by clunky is it takes a split second longer to shift and seems like it hang on the cogs for just a tiny bit too long and then when it shifts and then when it does there's a big chunk of crank rotation before it engages. No amount of indexing seems to have any effect on this problem.
I'm confused about it because the only things that have changed are the chain length and the chainline, which I can't really imagine causing this problem... chainline maybe, but I have the problem in both chainrings. I lubed my chain and I have a new one on the way to try.
Any ideas?
Any ideas?
Quoted: 1975 Post(s)
Liked 232 Times
did you change the b-screw setting? If you turn in the tension screw a significant amount such that upshifts become a problem and it still has problems on downshifts then cable friction or a kink would be my next guess, possibly a frayed cable head
Liked 2,969 Times
Is the chain alignment good?
-Oh Hey!
-Oh Hey!
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I'm going with chain line and cable drag for these reasons: Chain alignment might have shifted just a smidgen from adding the new dual front sprockets and Cable drag usually is associated with clunky down shifting as the poor DR spring is being overworked. It still manages to do the job, but it's struggling against the drag created by either dirt, grunge, or splayed cable. 'B' screw setting might be a factor, but I kinda doubt it. They have so little effect on things, at least on my bikes. Good luck and keep us posted, that's how we all learn. Thanks
Liked 2,969 Times
how many links were added to support the dual containing more teeth count?
-Oh Hey!
-Oh Hey!
No cable drag, I just got new cables.
Didn't add any links to the chain. Do I really need to? With the b screw unscrewed, it actually has a little bit of slack if I shift to 36x11 which would imply its a little bit big?
Chainline is good and problem isn't affected much by which chainring I'm in...
Liked 2,969 Times
You cant base the chain length off the small small cross chaining. You need to measure the big big for length.
-Oh Hey!
-Oh Hey!
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Try this formulae and double check it against the big-big sprockets for chain length. I always do the math first, mark the link, and then dry run it over the big to big sprockets before sizing the chain.
Chain Length= 2(C) + (F/4 + R/4 + 1)
C=axle to BB distance (inches)
F= Front Chainring (#teeth) largest
R= Rear sprocket (#teeth) largest
Double check all that and see what you come up with. Let us know, please.
Quoted: 2338 Post(s)
Liked 2,822 Times
Mechanic/Tourist
New cables does not mean there is not a friction problem, which can be caused by excess cable length, ferrule problems or cable stop issues. Also, it might be helpful if you specified shifting to larger or smaller cogs being the problem. Some people mistakenly call shifting to smaller cogs in the rear as "downshifting".
I checked my chain yesterday, it's sized correctly. There are 2 bends in the chain on each deraileur pulley while going big to big.
OK, I mean upshifting. God is such confusing lingo. I checked the cables by pulling it through without the cable clamped down on the derailleur.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
Downshifting problem is almost always cable drag. Re-do the cables making sure everything is smooth. 6800 is wonderful it should downshift flawlessly. Personally i would go Shimano cassettes too but sram should work fine.
Mechanic/Tourist
The OP has clarified that the problem is shifting to the smaller cogs (upshifting). That is what is typically caused by cable drag, and the easiest way to diagnose is to disconnect the cable completely and then see if the derailleur shifts to the small cog (outer limit correctly set) when you push it in manually to the next cog and then release.
I'm 99.999% sure cable drag is not the problem.... already checked cables. Also, there was a bit of cable drag before I got new cables, and I didn't have this problem??? With my 39t single chainring? And now the new ones have like zero drag.
I need more ideas.
I need more ideas.
Mechanic/Tourist
Mechanic/Tourist
If you have not tried the procedure I listed above you have not eliminated cable/housing as the issue. Actually, there is a small chance that the shifter could cause lag as well. You'd have to check that by holding onto the cable at the shifter to check that. There is absolutely no reason that a chainwheel change would in itself lead to slower shifts to the smaller cogs, especially when your small chainring is not that different from the original and in fact is smaller. That leaves out a "chain too short" cause.
Liked 2,822 Times
If problem is shifting from a smaller cog to larger cog (using the combined brake/shift lever) it is probably an adjustment issue, very likely not enough tension, try turning the barrel adjuster counter clockwise to increase tension.
If problem is shifting from a larger cog to a smaller cog then it is very likely too much friction some place or again an adjustment issue.....which I would start from scratch on
I had this issue on a 9 speed ultegra set up and loosened everything and then followed the park instructions to adjust the rear derailler. B screw setting can also make a difference.
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 64 Post(s)
Liked 29 Times
This test will help determine whether the cables are causing any drag when shifting to smaller cogs (upshifting). If the chain drops down to the smallest cog without any clunkiness or hanging with the cable disconnected, then it's a pretty good indicator that cable drag (which would have been eliminated by disconnecting it) is causing the shifting issues. As he mentioned, you'll want to make sure the limit screw is adjusted correctly so the chain doesn't jump of the small cog and get wedged between it and your frame.
I'd also second redlude97's suggestion of checking the hanger alignment. Sometimes an misaligned derailleur hanger can cause the bike to shift gears perfectly in one direction, but shift poorly in the other. I had symptoms like this on an old bike and after having the derailleur aligned it shifted correctly in both directions.
Liked 2,969 Times
detached the main cable goin to the der. take a small section of spare cable & set the der with the small section of cable to a fixed tension. You will need to loop the what was the adjustment end over & around to the pinching plate in order to "fix" the tension.
If the ghost shifting persists, then you have an issue unrelated to the cabling. If this is not what you're experiencing, then it's likely a component within the hub or possibly the shifter mech or even still the cable/housing.
-Oh Hey!
-Oh Hey!
zenona
Road Cycling
11
11-24-15 05:44 PM
Svennis1982
Bicycle Mechanics
5
06-19-13 03:24 AM
