Changed crankset, chainline now off and FD will not work with new crank
Bikes: Easy Racers Fold Rush 1987 Miyata 215 ST Rans Dynamik 1987 Schwinn Sierra Burley Duet
Quoted: 30 Post(s)
Liked 18 Times
We have a 2003? Burley Duet, 9 speed triple. I replaced the Shimano FC-1057 crankset with 53-42-30 chainrings to a Sugino SD 600 with 46-36-26 chainrings. Chainline was 50 mm at the crank. Now it is 55 mm. When I held up the original Shimano to the new Sugino I could see that the spider on the Shimano sets the chainrings in further than what the Sugino does. Now the original Shimano FD-5503 (105) is not able to move the chain over far enough to engage the chain to the outer chainring. It also seems like it may not be the best choice for the smaller chainrings.
Chainline for the left side cranks both front and rear is 55 mm. Bottom brackets are square taper.
My idea is to purchase two bottom brackets that are 10 mm shorter than current BB's to move the new crankset inward 5 mm. And I think it would also move the left side cranksets inward 5 mm. There appears to be room to allow this.
I am also open to purchasing a new front derailleur if another would work better with the new chainring sizes.
Would love to hear about your experience and thoughts on this. I would really like to make the new crankset with the smaller chainrings work. We loved riding the tandem last year but are no longer young and could benefit from the smaller gearing.
Thanks for your help!
Quoted: 2495 Post(s)
Liked 738 Times
5mm diff in chainline. Hmmm. Have you tried backing out the high limit screw on the FD all the way? Yes, a shorter BB spindle will help, but 10mm sounds like a lot. We had a Shimano 105 equipped Raleigh Coupe and I changed the 30T granny to a 24T and the FD handled the difference just fine. I changed the 42T middle ring to a 39T which actually makes more of a difference to a FD, and there is also not much of an issue. Before I spend money changing any more variables I would be looking at those limit screws. A new FD might work and you only need one. And you could make sure it is optimized for a compact crank gear range but you will spend who knows what. Last would be new BB's because you would probably want two (you don't 'need' two but its what I would do). The new unit BB's are common as salt and just as cheap, but you can spend more, much more, sky's the limit with those things. Something in the $25 ish range each should do you fine but I'm not sure you need to go 10mm shorter. 5 should do it.
Quoted: 30 Post(s)
Liked 18 Times
Yes, I backed out the limit screw to allow the FD to move outbound as far as it would go. It was not enough. I am willing to spend for a FD and two bb's if that would make for the best setup. My aim is to have a setup that is reliable and trouble free.
A FD I recently purchased for another project specifically said it required a 50 mm chainline. How many derailleurs have that requirement, I don't know? So I would be concerned with just bringing the crank set in 2.5 mm and then having to go and purchase yet another bb. Wouldn't it be wise to just purchase the bb's that would accomplish that the first time?
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Put the old crankset back in with an inner 26T, middle 39T 10-speed, and outer 53T B-type 10-speed ring The inner ring will be plain, no ramps etc. All problems solved.
Results matter
Results matter
Quoted: 30 Post(s)
Liked 18 Times
Besides, I purchased the new crank set just for this project so there is no going back now.
Liked 1,938 Times
Thanks for your input. But one of the reasons for going with the new crank set was that I wanted to get away from the 53t chainring. When going downhill I get a tap on the back and a voice in my ear when we reach 30 mph. We are getting older and slowing down.
Results matter
Results matter
Quoted: 7 Post(s)
Hi
Would something like this help? https://www.jensonusa.com/Problem-So...SABEgIrg_D_BwE
or this https://www.ebay.com/itm/Santana-Tri...2038391?_ul=SV
Good luck, we ride smaller chainrings too
Quoted: 30 Post(s)
Liked 18 Times
Hi
Quoted: 30 Post(s)
Liked 18 Times
I just ordered a pair of 113 mm bb's to replace the existing 122 mm bb's. I will deal with the FD after if necessary
Thanks everyone for your input so far.
Will keep everyone posted with the progress.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
If you have a barcon or grip shifter with a steady ratcheting action then you can simply replace the FD with any old mountain bike FD. But with a brifter the pull per shift won’t match.
Any trouble with the timing chain line?
Quoted: 30 Post(s)
Liked 18 Times
No trouble with the timing chain line.
Quoted: 30 Post(s)
Liked 18 Times
Finally had a chance today to install the two new 113 mm bb's. It brought the chainline back to it's original measurement of 50 mm or very close to it. As Leisureturn mentioned I only had to change the one bb but decided to change both to keep the timing chain running in a straight line.
I was able to keep the original front derailleur. It works fine. No road test yet, it has been snowing here all day with more to come in a couple of days.
Many thanks to everyone for their help!
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
Quoted: 169 Post(s)
Liked 84 Times
When I upgraded components on our Girodanno "Cheap Chinese" tandem, I had to toy with different square taper BBs when I replaced the crankset. After measuring the POS one that was in the frame originally, I got the right size and it worked fine. You should be good to go if you get a narrower set.
Quoted: 30 Post(s)
Liked 18 Times
Update: Wife and I are loving the new Sugino SD 600 with 46-36-26 chainrings. It is a much more practical sized chain ring set for us.
Likes For cyclehealth:
Quoted: 1856 Post(s)
Liked 664 Times
I don't have much tandem wrenching or riding experience, but decades with my singles and those of my wife. She's going to be Rear Admiral, with me as Pilot.
Liked 664 Times
estasnyc
Touring
5
01-10-17 01:29 PM
Charlie Whiskey
Bicycle Mechanics
5
09-01-15 05:26 PM
