1984 Centurion Turbo...just brought it home
Old 07-07-19, 10:42 AM
oldbikenewbike
Quoted: 41 Post(s)
Liked 51 Times in 33 Posts
As far as I know from looking online, 1983 and 1984 were the only two years this model was made...and this color scheme 1984 only.
As far as I can see, with the exception of maybe the saddle, it looks all original (sans tires, of course). And this is the condition I got it in! So, is anythinbg is not original, please let me know. I'm curious!
oldbikenewbike is offline
Old 07-07-19, 10:43 AM
oldbikenewbike
Quoted: 41 Post(s)
Old 07-07-19, 10:45 AM
oldbikenewbike
Quoted: 41 Post(s)
Old 07-07-19, 10:48 AM
oldbikenewbike
Quoted: 41 Post(s)
Whoops! Without realizing it, I downloaded the photos in reverse order of when I had taken them. Sorry! Here are two against my garage door for contrast (but I do like taking all the shots in my driveway against the textured background...
Old 07-07-19, 10:51 AM
AngryFrankie
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times in 55 Posts
Awesome! Find a Turbo saddle, lose the mirror, all original early 80's Japanese race bike.
AngryFrankie is offline
Likes For AngryFrankie:
Old 07-07-19, 11:03 AM
oldbikenewbike
Quoted: 41 Post(s)
Lol...mirror is already off, as is the saddle bag. This is going to be one of my easiest detailing jobs in a while.
Not bad for $125...
Old 07-07-19, 11:04 AM
verktyg
verktyg
verktyg's Avatar
Quoted: 1036 Post(s)
Liked 1,238 Times in 654 Posts
Top End 1974 Centurion
Very nice example of the precursor to the IM (Ironman) series.
The brake calipers and large chainring where probably anodized black. Colors in anodized aluminum are created using light stable chemical dyes which soak into the porous anodized surface. There are several processes for creating the black color and some of them are fade resistant but apparently these components weren't made that way. The hubs have faded a little too.
There were several wall thickness specs published for Tange # 1 tubing. The correct dimensions were top and down tubes .8mm x .5mm x .8mm thick while the seat tube was .9mm x .6mm x .9mm. Tange # 2 tubing was a few grams heavier and had .9mm x .6mm x .9mm top and down tubes which made it about the same specs as Columbus SL tubing.
BTW, $125 is Grand Theft Bike!
verktyg
Chas. ;-)
verktyg is offline
Old 07-07-19, 11:32 AM
markwesti
markwesti's Avatar
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times in 175 Posts
For grupo bits check here , site is by @fleslider . And nice score .
Vintage Centurion Bicycles
Your bike https://www.vintage-centurion.com/mod...on/turbo.shtml
markwesti is offline
Likes For markwesti:
Old 07-07-19, 12:09 PM
T-Mar
Quoted: 4722 Post(s)
Liked 3,036 Times in 1,874 Posts
+1, this is definitely a 1984 version. Besides the different colour option, the 1984 version added a 2nd set of bottle bosses and switched from a flat to curved brake bridge.
Regarding the anodizing, Dia-Compe did offer a bronze colour. These may not have faded. It's easy enough to tell by examining areas where the sun don't shine. For instance, you can remove the pads and examine the surfaces where the pad carriers mate with the calipers.
Personally, I think people get too carried away with Tange #1 . Tange #1 through #5 all used the same fork steerer, fork blades, seat stays and chain stays. So, the only difference was in the main triangle and even then #1 through #3 used the same seat tube, so for the commonly seen #1 and #2 framesets, the only difference were the top and down down tubes.
However, WSI did not spec standard tubesets for their Tange #1 frames. Centurion Ironman, Comp TA and Turbo owners regularly report 27.0 - 27.2mm seat posts, which would be far too large for the standard double butted seat tube used with Tange #1 . The post sizes suggest a custom, single butted version of the seat tube or possibly the standard Tange #4 seat tube, which was single butted 0.9mm/0.7mm.
T-Mar is offline
Likes For T-Mar:
Old 07-07-19, 12:39 PM
Classtime
Classtime's Avatar
Quoted: 1947 Post(s)
Liked 2,010 Times in 1,109 Posts
Very nice Turbo. Mine was complete except for the rear derailleur. You will want the Bernard Hinault Turbo and I am pretty sure black cable housing. I've seen pictures of bronze brake pad holders but mine are clear like yours. If you need to touch up (doesn't look like it), I found that Audi black mink works fantastically. When you get a chance, I'd like to know the top tube center to center measurement.
Classtime is offline
Likes For Classtime:
Old 07-07-19, 01:08 PM
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 582 Times in 379 Posts
Man that's Nice.
texaspandj is offline
Likes For texaspandj:
Old 07-07-19, 01:15 PM
oldbikenewbike
Quoted: 41 Post(s)
Thank you...and top tube is 22'' or 55.88 cm, center to center. Frame is to small for my 6' frame, but I couldn't pass it up at this price. It will be eye candy for a while... But my 1988 Ironman Master fits just fine!
Old 07-07-19, 01:26 PM
oldbikenewbike
Quoted: 41 Post(s)
Old 07-07-19, 02:06 PM
oldbikenewbike
Quoted: 41 Post(s)
@T-Mar...would you know what this model would have listed for back in 1984? I'm guessing around $600...possibly more?
Old 07-07-19, 02:54 PM
horatio
Hump, what hump?
horatio's Avatar
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times in 145 Posts
Nice Turbo. I missed out on buying it's twin about a month ago.
horatio is offline
Likes For horatio:
Old 07-07-19, 03:07 PM
oldbikenewbike
Quoted: 41 Post(s)
I came close to not getting it.
The owner told me that two different people were coming to see it the next day, so I figured it would be gone. When I saw it was still listed this morning, I contacted him and he told me it was still available and that neither of the two guys who were supposed to come and see it showed up.
Pays to be persistent!
Old 07-07-19, 05:58 PM
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
Not bad for $125...
OK, now I hate you.
Super score, and very, very nice. I have the saddle if you need it, for shipping. I have the same frame/fork/headset, with some scuffing on the R side.
Ride it OEM, or hot rod it. Either way, great bike. I've even seen one completely stripped of paint, and it looked pretty good. Stays were polished almost all the way, as was the fork.
RobbieTunes is offline
Likes For RobbieTunes:
Old 07-07-19, 06:03 PM
RobbieTunes
Quoted: 378 Post(s)
verktyg
Many of the bits were bronze-colored, as were the hubs on most I've seen. I think the dork disk was bronze, too. I see the catalog page shows black, as well as the OP's hubs being black. I've never seen one with black bits before. Those hubs are super smooth, and worth an overhaul if you ride it OEM.
Check out the font on his DT decal. First I've seen that one on a Turbo.
I may be wrong, but if I recall, the seat post was 26.8, but I'm old, addled, and could well be remembering something totally different.
Old 07-07-19, 06:08 PM
Slightspeed
Slightspeed's Avatar
Quoted: 741 Post(s)
Liked 818 Times in 421 Posts
I've only ever seen red ones. Nice find. Couple years ago there was a dusty, dirty red one hanging in a local shop. He was asking $175. Not being up to speed on Centurion, and in the middle of a Raleigh project, I mentioned it to a bike club friend, and he grabbed it the next day. I did some research, and discovered what cool bikes these are. My friend is an older gentleman (I'm 70) and is having health problems, and has kind of stopped riding. I hate to pick his bones, but I still wonder about the one that got away. Have fun with yours!
One that got away, sorry for the lousy picture.
Slightspeed is offline
Likes For Slightspeed:
Old 07-07-19, 06:53 PM
Classtime
Classtime's Avatar
Headtube decal differs from mine.
Old 07-07-19, 07:28 PM
oldbikenewbike
Quoted: 41 Post(s)
Originally Posted by RobbieTunes
OK, now I hate you.
Hi Robbie
Thanks for the generous saddle offer, but hang onto it in case you find one like I did, missing it. You'd never forgive yourself, lol.
The paint is smooth to the touch, showing it was kept up and waxed. Like I said, one of the cleanest I've had it quite some time. It will be needing some attention, but not much.
Oh, and the frame is really to small for me (6') to ride. Just my luck I find one in this condition and it's not the right size. I picked it up just to have, knowing how hard they are to come by in any size or condition. Even the Windsor Competition I bought the other day isn't tall enough, but it was priced right in great shape (after I was done with it) and is another hard to come by original bike.
I'll Post shots when I'm done!
fred
Old 07-07-19, 08:05 PM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
Sweet! Even the dork disc is dark/special. I acquired an Iris colored 83 about a month ago. All of the parts for the rebuild have not came in yet. Yours is in great condition.
seypat is online now
Likes For seypat:
Old 07-07-19, 08:27 PM
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
the round headtube decal was 1983, in 1984 they went to the rectangle. but WSI (Centurion/Diamond Back) were notorious for using the previous years graphics into the next year until they ran out. I think.
fleslider is offline
Old 07-08-19, 07:14 AM
T-Mar
MSRP was $659.95 US.
T-Mar is offline
Likes For T-Mar:
Old 07-08-19, 07:49 AM
oldbikenewbike
Quoted: 41 Post(s)
Thank you!! I figured you or Robbie Tunes would know.
fred
