Home Lube Formula?
Home Lube Formula?
Old 12-09-07, 11:50 AM
JRIDERNY
Bikes: Specialized Crossroads/ Colnago racer(can no linger ride it due to physical limitations
Home Lube Formula?
Upon deciding to try a home-made chain lube(somewhat like Pro-Gold,which I"ve been using), I"m still unsure of the correct,or best, proportion of motor oil to mineral spirits.. Any help,please.
JRIDERNY is offline
Old 12-09-07, 01:30 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Liked 162 Times in 89 Posts
I've mixed Pennzoil 30 wt motor oil with mineral spirits, I played around with the proportions, starting with 1:1, then 2:1, and finally 3:1 (larger numbers are mineral spirits). I found 1:1 to be too much like motor oil to penetrate the chain well, 2:1 seemed okay but still noticeably thicker than Pro Link Gold, and 3:1 seemed to look like and have about the same consistency as Pro Link Gold.
I was mixing this up in very small quanties, and in the end I mixed up a few ounces of it in the 3:1 ratio and used it for awhile on a couple of my bikes. It seemed to lube quite well, keeping the chain quiet for a long time between applications.
I wipe my chains off with a rag as needed, but I did find one very noticeable difference between the homeade lube and the "real" stuff, however: the mineral spirits/motor oil mix will turn black on your chain in a very short time, much quicker than something like Pro Link or Tri Flo.
I really don't know why: is it because dirt from the outside world is sticking to the mineral spirits/oil mixture that much more than the "real" chain lube, or is it because the motor oil mix is bringing dirt from the inside of the chain to the outside and holding it in suspension more than the "real" lube? Again I don't know, but the bottom line for me, once I used up the small container of homeade lube, is that I don't like a black chain so I switched back to regular chain lube. There may be others with a different experience, but that was the way it worked out for me.
well biked is offline
Old 12-09-07, 01:32 PM
Cyclist0383
If you must, it's 3:1 in favor of oil.
Cyclist0383 is offline
Old 12-09-07, 01:57 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times in 18 Posts
Rock'n'roll lube
operator is offline
Old 12-09-07, 02:13 PM
mantis
Don't Bug Me
mantis's Avatar
Bikes: Canyon Aeroad CF SL 8.0 Disc, Cervelo S2, Look 585, Specialized Rockhopper
Quoted: 19 Post(s)
Liked 27 Times in 16 Posts
I probably spend $4.00 every two years for a bottle of Road Rage. That's one expense in my cycling budget that isn't breaking me.
mantis is offline
Old 12-09-07, 02:33 PM
kenhill3
use your best eye
kenhill3's Avatar
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
If you want to compare or get an idea of what is in chain lubes, Google on the product and add MSDS (material safety data sheet).
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
kenhill3 is offline
Old 12-09-07, 02:42 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
That's not right, the ratio is the other way around.
My formula is 3 parts OMS (odorless mineral spirits) to 1 part Mobil 1 synthetic oil. I use 10W-30 grade of Mobile 1 but that doesn't matter much. I make the mix up one quart at a time and repack it into the 4-0z bottles left over from Pro-Link.
I use it rather lavishly. First I wipe the chain with a dry rag, then apply the lube freely to clean the chain, wipe off the excess then apply more and let the solvent evaporate. My chains stay reasonably clean and last a long time.
HillRider is offline
Old 12-09-07, 05:37 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
Originally Posted by operator
Rock'n'roll lube
I sure hope that you're right. That's the last chain lube that I've bought but I haven't used it yet.
Retro Grouch is offline
Old 12-09-07, 08:59 PM
Al1943
Liked 7 Times in 6 Posts
+1
I use about 3 parts mineral spirits to 1 part Mobil 1 synthetic. If you get it too thick you'll have a gooey chain. The ingredients are always in my garage anyway, for other purposes. As for bike specific lubes I like Purple Extreme.
Al
Al1943 is offline
Old 12-10-07, 11:06 AM
JRIDERNY
Thanks, the 3 to 1 spirits to syn.oil sounds worth trying. Later
JRIDERNY is offline
Old 12-10-07, 11:19 AM
rmfnla
rmfnla's Avatar
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times in 9 Posts
Local chapter of the "Too much time on our hands" crowd, no doubt.
Today, I believe my jurisdiction ends here...
rmfnla is offline
Old 12-10-07, 12:31 PM
Stacey
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
Stacey's Avatar
Hoppe's gun oil straight.
Stacey is offline
Old 12-10-07, 04:23 PM
HillRider
Nope, too many bikes to want to pay $6 for 4-oz when I can pay $10 for more than a gallon. I use it on all 5 of my bikes and supply my family and a couple of friends so I go through a fair bit of lube.
BTW, It doesn't take me any longer to buy OMS and Mobile 1 that it does to go to the LBS for the "right" lube and mixing the two takes maybe 5 minutes. It is not a big time consumer.
Old 12-10-07, 04:29 PM
WNG
Spin Forest! Spin!
WNG's Avatar
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times in 10 Posts
+1
Good stuff! Great for guns, and was great for mechs, cables and chains on my bikes years ago.
WNG is offline
Old 12-10-07, 11:15 PM
ollo_ollo
ollo_ollo's Avatar
Bikes: Still have a few left!
Quoted: 465 Post(s)
Liked 526 Times in 265 Posts
After trying most of the commercial bike lubes & experimenting with other lubricants, I began using my large supply of military spec "light weapons oil" on my bikes. The results are very good, similar to Hoppe's. I bought mine at swap meet, but have seen it on sale at surplus stores & gun shops. Don
ollo_ollo is offline
Old 12-11-07, 11:38 AM
rmfnla
rmfnla's Avatar
Quoted: 273 Post(s)
Makes sense.
rmfnla is offline
Old 12-11-07, 01:09 PM
tellyho
Your mom
P:E:R:O:S. Bought it 10 years ago and have many bikes. Not worth the home-cookery, IMHO.
tellyho is offline
