Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 03-06-15, 04:55 PM
  #2076
SBUndefeated201
Originally Posted by carleton
Look at photos and you can see it all.
Also, specific questions get specific answers.
Simply enough haha. Thanks!
SBUndefeated201 is offline
Old 03-06-15, 04:56 PM
  #2077
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
Originally Posted by nspace
.............. The frame definitely as asymmetrical chainstays as well. .........................
You could check the half q (distance from centerline of seat tube to crank at the pedal hole) for each crank. If the same then you are fine.
700wheel is offline
Old 03-06-15, 05:55 PM
  #2078
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
Originally Posted by SBUndefeated201
I'm always interested in seeing what other people use component-wise in their setups. What do olympic/national tend to use? I've tried looking online but haven't found certain components. I know Mavic iO + Comete is the standard for wheels, but what do most athletes use for cranks, handlebars (integrated bar and stem I suppose), pedals, saddles? I also assume parts and specs are fairly consistent across the board due to regulations.
Not that I am ever going to have a bike setup like this, but I am always curious when watching clips.
Here's stuff that's pretty consistent:
iO/Comete (though Dutchies use PRO disc/5spoke, FFWD has a foothold, and some enduros use spoked carbon wheels).
in the sprint field, almost everyone is on 3T Scattos.
some national teams use custom suppliers - GB, Germany, and to a lesser extent Australia.
Everthing else is a mishmash. For cranks, it always looks like Dura-Ace are the most widely used. Some Campag Record, some Sugino 75, and a few Omnium. Frames - a very wide variety. There aren't that many integrated bar/stems out there. There also aren't many regulations that cover stems, seatposts, bars, saddles, or pedals. So people just use whatever they like.
queerpunk is offline
Old 03-06-15, 07:49 PM
  #2079
Dalai
Quoted: 89 Post(s)
Liked 8 Times in 6 Posts
Have a look through these photos to see what the elite are using Canadian Cyclist - Photo Galleries
Dalai is offline
Old 03-06-15, 08:30 PM
  #2080
nspace
Originally Posted by Quinn8it
Maybe swap them out for ones that say Dura Ace on them?
Thanks for your help...
@700wheel: Sorry I meant to write symmetrical!
Here are couple photos. Maybe this all looks normal, but it would be good to get a second set of eyes! I might be worrying over nothing.
nspace is offline
Old 03-06-15, 10:35 PM
  #2081
gtrob
Bikes: T1, S2, P3
Quoted: 5 Post(s)
There are also several teams running on a budget smaller than what I spend on lunch in a week, so they tend to be using 'whatever the heck they can'.
Ive always been curious how a country like Cuba performs at the level they do. Ive heard stories that things as simple as a bike pump are hard to come by there.
gtrob is offline
Old 03-06-15, 11:57 PM
  #2082
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
42mm chainline? Seems right. 40.5-42 is normal. Also, you can line up the crank with the seat tube. Measure center of crank to edge of seat tube. Repeat on other side. If your BB is adjustable, then you can shift it over in the direction it needs to go. 42mm is standard for 120mm track spacing.
taras0000 is offline
Old 03-07-15, 12:16 AM
  #2083
SBUndefeated201
Thanks QueerPunk and Dalai!
Old 03-07-15, 09:23 AM
  #2084
nspace
Thank you! I'm not sure how adjustable it is, but depending on the measurement I could always try flipping the BB to see what chainline it produces.
nspace is offline
Old 03-07-15, 11:26 AM
  #2085
700wheel
Quoted: 144 Post(s)
If nothing else solves your problem you could shim one of the pedals to center the pedals relative to the seat tube.
700wheel is offline
Old 03-07-15, 05:09 PM
  #2086
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
You can't flip the BB as the cups are threaded differently (lefthand/righthand). Flipping the spindle won't work unless it's asymmetrical, which it usually isn't (it's rare if it is, this is usually only done when the BB/rear wheel are offset, like on fatbikes). If it's not exactly 42mm, but your cog is 42mm, then it's near enough that it doesn't make a difference. You can measure this by measuring the flanges on your track hubs, divide by 2 to get flange spacing from the centerline, then add the difference from the cog to the DS flange. Spoke flanges on track wheels are symmetrical. Then if you're the anal type, you can measure the centerline to trackend on each side and see if your wheels are centered, lol.
Old 03-07-15, 06:14 PM
  #2087
nspace
I was thinking just the spindle, not the cups—but I think it is close enough. I would expect it to be symmetrical but Campagnolo lists it as asymmetrical. Chainline on rear cog is about 42/42.5mm. I rode it for an hour and a half today and things seemed to hum along smoothly. I will stop worrying about things now
nspace is offline
Old 03-09-15, 08:49 AM
  #2088
Velocirapture
Velocirapture's Avatar
Bikes: S-1 :-D
Quoted: 17 Post(s)
I'm waaay overdue for a bike-'computer' upgrade, and after looking around it seems that the Garmin edge 500/ 510 looks the way to go. I'm leaning towards the 500 at the moment due to price difference, but my concern is redundancy now that that unit has been on the market since 2009. Anyone have any insights at all?
thanks
Velocirapture is offline
Old 03-09-15, 10:06 AM
  #2089
700wheel
Quoted: 144 Post(s)
Track standing is not the only, or the best way to get yourself in to the trailing position...
Unless you are competing in a Longest Lap competition
https://www.youtube.com/watch?v=sUjg...ature=youtu.be
700wheel is offline
Old 03-09-15, 11:07 AM
  #2090
Quinn8it
Quinn8it's Avatar
Bikes: Bianchi Pista, Bianchi Vigorelli
yeh I get it.. Everybody is going to jump all over me with Proof that Track Stands are the cornerstone of succeeding as a track racer..
I never said I never do them, the OP asked about practicingTrack stands on the track- which sounds like a pretty lousy use of track time, especially for the OP who has done little to no match sprinting or racing..
Sorry if I think that learning how to make a bike go really fast is basically the only way to win bike races- don't forget, after your track stand you will still have to race to the line..
Quinn8it is offline
Old 03-09-15, 12:31 PM
  #2091
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
thanks
I think it's fine for track. The SRM PowerControl V is older than that and is still in use.
The main features of the 510 are:
- Connected features such as live tracking, send/receive courses, social media sharing and weather
- Compatible with GPS and GLONASS satellites for faster satellite acquisition
- Distance, speed, ascent/descent and GPS position
- Wireless data transfers to Garmin Connect
- Activity profiles store preferences for different cycling activities
None of which matter for track.
carleton is offline
Old 03-09-15, 12:57 PM
  #2092
Quinn8it
Quinn8it's Avatar
510 is also quite a bit bigger...
ive got 2 500's. There are some improvements I'd like to see, but it's basically the best head unit for the money.
Quinn8it is offline
Old 03-09-15, 02:14 PM
  #2093
Yellowgiant
I am struggling with my warm up before my 200m sprint qualifications. Ive been warming up on my road bike on the rollers so I can increase resistance and put a bit of a load on my legs beforehand. But I'm not sure if that's the right formula?
I hoping I can get some more advice on how to be fully warmed before my heat.
Yellowgiant is offline
Old 03-09-15, 02:16 PM
  #2094
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
are there times in training when you've felt really perfectly warmed up and ready to go?
Old 03-09-15, 02:20 PM
  #2095
Yellowgiant
Ya but it was after a 20-30 lap paceline with a burnout to finish it off.
Old 03-09-15, 02:48 PM
  #2096
rensho3
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
thanks
I use the 500 on the track and the road, and it works quite well. The 510 is, however, easier to switch between bikes; I plan to get one when my 500 dies.
rensho3 is offline
Old 03-09-15, 02:52 PM
  #2097
Quinn8it
Quinn8it's Avatar
Are we assuming zero track time?
i replicate the 20-30 laps by doing 20min on the rollers in my normal warm-up gear.
8min@100rpm/8min@110rpm/4min@120rpm.. A couple of 15" max-revs are good after that, but I'll then need to do jumps on the track..
If i have zero track time, which I find rarely happens before the 200m- but often happens before the kilo, then I'll use an Adjustable Resistance Mag Trainer with my Track Bike.
Quinn8it is offline
Old 03-09-15, 03:00 PM
  #2098
Yellowgiant
This is helpful.
I am referring to zero track time. But I like the 20 mins on the rollers you listed.
I had a feeling the the trainer was the only real way to go to get the right load.
Old 03-09-15, 05:17 PM
  #2099
carleton
Elitist
carleton's Avatar
+1
It's common for elites (like quinn) to get little to no track time before an event. It's totally possible to get ready using rollers...even before big strength efforts like a kilo.
carleton is offline
Old 03-10-15, 02:45 AM
  #2100
Velocirapture
Bikes: S-1 :-D
Quoted: 17 Post(s)
Thanks for the input, folk.
@rensho3, can you explain a little more about this?
