How should I clean my tires?
HELP! I've just installed a new set of tires and realized I left lots of black fingerprints all over it. How can I clean them without damaging the rubber? Thanks!
Depends what the black spots are. A clean rag and 90% IPA or straight acetone will work fine for short-term exposure
That said, gum-walls get dirty from braking dust fairly quickly, so I would just deal with the dirty spots. Clean tires are for show bikes.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Fantastic
Quoted: 5787 Post(s)
Liked 2,580 Times
Dish soap and water rinsed well, or simply pass on it entirely. They're tires and will get dirty in use. It's their Karma, and you might as well accept that.
FB
Chain-L site
FB
Chain-L site
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Once I tried an auto tire white wall cleaner and it was too harsh for the michelin pro tires. The tire was grey and it ruined the color.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 337 Post(s)
Liked 228 Times
I clean almost everything on my bikes with a household cleaner like Fantastik or Greased Lightning.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Believe it or not. When I was a kid back in the 60's I used to work at a local gas station. A coworker used to rub a brake fluid soaked rag on tires in order to shine them up. Really. I've never seen anybody do it since. Brake fluid is pretty toxic stuff.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Cleaning dirty tires, is a line that I just refuse to cross.
Bikes: 2017 Giant Defy Advanced 2
Quoted: 15 Post(s)
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I enjoy riding "Show bikes" and found Westley's Bleche-Wite works great when used properly.
Never spray it directly on dry tires, and never allow it to dry on the tire.
I spray the tires liberally with water and then give 'em a quick, light spray of WBW. Brush with nylon bristle brush and immediately rinse clean.
Product can also be sprayed on the wet brush instead of the tires, but tires still must be watered first.
Works better than a charm, and never caused any problems for me... other than having to occasionally defend comments that I must never ride my bikes, which I'm ok with!
Bikes: Schwinn
Quoted: 17 Post(s)
My cruiser is no showgirl so since it has fenders I've been known to ride through puddles after a rain. There are brite black products for cars that work but not on white sidewalls.
The Left Coast, USA
Frankly, I found cleaning used tires to be kinda smart. I've spotted some cracks, thorns and slices in tires that I couldn't see when they were grungy, especially with MTB tires. I use rubbing alcohol or Simple Green.
Tires
I use a brush on my tires after each ride. Then I wipe the sidewalls with 30 sunscreen, but not any part of the tire that touches the ground. No more sidewall cracks and looks great. Only takes a tiny bit.
So confused by this post. Are toxins not toxic when they are not being ingested?
To the OP: You can't clean those tires. They have been exposed to the filthy corrupt world. You must throw them away and buy new ones and never take them out of the packaging.
Quoted: 1186 Post(s)
Liked 289 Times
I've never cleaned tires but wd-40 works well on rubber hoses in an engine bay. It would probably clean off the yellow part and makes the black part shinier. That said I wouldn't bother on a bike.
Glycol ether based brake fluid is non-toxic but it makes a poor cleaner. WD-40 is a good degreaser, great for chains for example, but you shouldn't use petroleum-based products on rubber.
I highly recommend Tub O Towels for cleaning bikes and tires.
Quoted: 478 Post(s)
Liked 87 Times
