Rain / Commuting / Maintenance
Old 06-30-19, 06:58 AM
YepIRide
I am a full-time bike commuter this summer. Inevitably, rain happens on the ride. What type of maintenance do other commuters do after getting occasionally poured on while riding home?
thanks!
YepIRide is offline
Old 06-30-19, 07:09 AM
BobbyG
BobbyG's Avatar
Quoted: 1364 Post(s)
Liked 1,677 Times in 827 Posts
I run the chain through a rag, and use dollar-store brush scrubbers to clean the gunk from the gears and deraillieur. I re-lube the chain, then wipe down the frame. I usually wait until the next ride to do this (if it's not raining again).
BobbyG is offline
Likes For BobbyG:
Old 06-30-19, 10:35 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
... occasionally poured on while riding home?
if only ...
it's October thru Junuary, here .. bikes with IGH, and mudguards, disc or drum* brakes ..
* most reliable needing least service..
fietsbob is offline
Old 06-30-19, 03:46 PM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
If it is just occasional showers, I don't worry about it much. Especially if it is hot enough that everything dries off quickly. Brush the dirt off?
You will have to lube the chain more frequently, and perhaps chain replacements. Watch for stretching.
Also, watch for grime embedded in the brake pads.
CliffordK is offline
Old 06-30-19, 08:11 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
I put on dry clothes and have a beer.
But seriously, bikes are a lot less delicate than people tend to think, and clean rain does minimal damage if the bike is allowed to drip dry. I might get a tiny amount of surface rust on the chain, since I use a dry lube, but it's purely cosmetic.
Far worse is salt spray if you live near the sea, or road salt in hard winter areas.
Gresp15C is offline
Likes For Gresp15C:
Old 07-01-19, 08:03 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
I don't commute regularly, but I did on Friday & left my bike under a wooden covering but it got a little wet anyway. my leather saddle was covered w plastic, so no harm there. but Saturday morning I decided to take advantage of the "wetness" & gave it a cleaning & lube. discovered I should change the front derailer cable soon. there is some fraying ...
soapy bucket & soft long handled brush. wiped everything down. some wd40 here & there as needed for further cleaning & water displacement. wiped everything down. lubed the chain & derailers. wiped them down
I think bike commuting can add a lot of road grime cuz you are riding on general use roads with lots of cars & all the junk that comes off cars like rubber, grease, oil & road kill parts & fluids. riding those same conditions with some rain mixed in can make a gooey, sticky spray that is worth removing from the bike. also cleaning a bike helps promote inspecting the bike
rumrunn6 is offline
Old 07-01-19, 02:40 PM
Kevin R
Bikes: Raleigh Militis 3 Custom Build
Quoted: 8 Post(s)
Liked 8 Times in 7 Posts
wd40 on a rag to wipe down the bike including wheels.......remember wd40 is a degreaser so i dont spray in on the deraileurs chain or calipers......
definitely make sure your chain is clean, as grit will expedite wear...
Kevin R is offline
Old 07-01-19, 04:50 PM
Gresp15C
Gresp15C's Avatar
With road grime, eventually you reach an equilibrium where the new grime displaces the old grime.
This might be the place to put in a PSA for fenders and chainguard. Fenders help keep your bike cleaner in wet weather. Chainguard lets you use a heavier chain lube without it getting on your pants. I've been riding my all-weather bike in all weather for about 20 years, and it has shown minimal deterioration except for where the low quality chrome plating on some parts rusted. Oddly enough the Sturmey Archer hub leaks just enough oil to keep itself covered in a protective coating which also oils the chain. Clever design.
In my locale, summer storms are hard to predict, so it's a coin toss whether my bike will get wet on any given trip.
Gresp15C is offline
Old 07-01-19, 08:23 PM
randallr
Bikes: 2017 Gunnar CrossHairs Rohloff, 2022 Detroit Bikes Cortello
Quoted: 132 Post(s)
Liked 155 Times in 89 Posts
I pack newspapers into my bike shoes before dinner, pull them out after dinner. That greatly speeds up the process of drying the shoes out.
randallr is offline
Old 08-08-19, 07:31 PM
SylvainG
Bikes: Schwinn Miranda 1990, Giant TCX 2 2012
Quoted: 486 Post(s)
Liked 10 Times in 7 Posts
If you know it's going to rain and don't want your shoes wet, that's a great alternative (also useful when it's really hot)
https://www.biketiresdirect.com/prod...cycling-sandal
SylvainG is offline
Old 08-08-19, 08:04 PM
Archwhorides
Archwhorides's Avatar
Bikes: Death machines all
Quoted: 297 Post(s)
Liked 86 Times in 63 Posts
Belt drive with IGH works for me all year
Archwhorides is offline
Old 08-08-19, 08:43 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
I have two winter/rain/city bikes that live for the rainy day rides. I do very little for them. Hose them off with a garden hose and attachment that does both powerful jet and fine spray. Both sides get hosed from both front and back, mist except jet through the brake pads and inside the fenders. Drop it a few times from about a foot to shed most of the water, then carry in into the garage (so I don't bring in the bark of my path). Leave it standing against the workbench. Once fenders are drained, I hang it up from its hook.
Now, this is a luxury of owning a house. Those cleaning didn't happen in my apartment days and that (I only had one then) rain bike got filthy. And they still don't get cleaned over the months of freeze with the faucets shut down.
Those bikes have - all possible bearing packed in marine grease and Finish Line MTB wet lube on the chain. Nice seats with plastic fabric. All threads greased with that same grease. Powdercoat paint jobs. Fenders and good rain tires. Being wet doesn't phase them at all.
Ben
79pmooney is offline
Old 08-08-19, 08:44 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
I wish I had converted to sandals YEARS ago. No more wet socks, they breathe better, are lighter, and are easily adjusted for the foot-swelling that happens on really long, hot rides.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-08-19, 09:31 PM
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times in 166 Posts
I ride in my SPD sandals, and quite enjoy the summer shower commutes. I run a KMC rustbuster chain on my rain bike with full fenders and low slung front mudflap, so my drivetrain might get wet from above, but not dirty from below. I always run a dry lube, so if it is washed off by the rain, i dont worry too much if the bike was soaked on the way to work, as the chain wont rust. After i ride home in the evening, I will clean the drivetrain if needed, and relube the chain. With the rain bike sporting full cable housings, disc brakes, aluminum frame, carbon fork, and cambium saddle, i dont have any other wet-weather concerns other than chain lube, which is a minor concern at that!
SalsaShark is offline
Old 08-09-19, 09:38 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
Wipe the chain off (I use paper towels), and re-lube if necessary. Bounce the bike on its wheels to knock the worst of the water off, put it someplace it can dry.
After a few rains, I'll wash the bike (mostly so the brakes won't squeal, partly so I don't get filthy touching it). Re-lube all the pivot points on the brakes and derailers, wipe exposed cables with oily fingers, maybe drop some oil on the cable adjusters to try to keep them from rusting any more.
pdlamb is offline
Old 08-09-19, 09:53 AM
zowie
Quoted: 32 Post(s)
Liked 7 Times in 6 Posts
My commuter has belt drive and drum brakes so I don't do anything.
But on my other bikes, like most have said.
Wipe off and re-lube chain. Maybe a couple drops on other pivot points.
Wipe the brake stuff off the edges of the rims
Maybe take any clumps off the jockey wheels
Usually clean off under the bottom bracket area cause that gets the most shmutz and the cables run down there
If the bike is still wet I might give the frame a real quick wipe to get about 75% of the dirt with minimal effort
zowie is offline
Old 08-09-19, 10:02 AM
justsaymint
Quoted: 5 Post(s)
Liked 3 Times in 2 Posts
If you can't "hear" the chain, then nothing. If you can hear it, a drop of lube on each link
justsaymint is offline
Old 08-09-19, 10:19 AM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1481 Post(s)
Liked 639 Times in 437 Posts
I don't do a lot for my bike except cover the seat with a plastic grocery bag.
I wear a thin fabric baseball cap under my helmet so the visor to keep the rain from my glasses. For my feet, I wear close toed croc sandals with neoprene diving socks. My feet are going to get wet no matter what, so they might as well be quick drying footwear that drains.
https://www.theshoecompany.ca/en/ca/product/crocs-swiftwater-fisherman-sandal/276201040?gclid=EAIaIQobChMI3OSWjpn24wIVCdbACh0-OgOEEAQYBiABEgKlM_D_BwE
As for clothing, not much more because I'll be sweating under the poncho, rain jacket or cut-out garbage bag anyways.
Daniel4 is offline
alias5000
Commuting
15
06-24-19 06:51 PM
reggieray
Bicycle Mechanics
10
12-05-14 09:53 AM
TromboneAl
Fifty Plus (50+)
23
09-28-13 10:08 PM
onyxcurrent
Commuting
57
10-30-12 10:47 AM
Phydiox
Bicycle Mechanics
5
07-13-10 06:56 AM
