Recommend tires?
Recommend tires?
Old 05-16-20, 04:07 PM
CanadianBiker32
CanadianBiker32's Avatar
Bikes: Maxim, Rocky Mountain, Argon 18, Cervelo S2 Team
Quoted: 160 Post(s)
Recommend tires?
Looking to get a new rear tire for my mt bike. full suspension
what do u all recommend
right now I have a Kendra on the back, what brands and types you recommend, a half decent one for mud and dirt, just something good for in between.
CanadianBiker32 is offline
Old 05-16-20, 07:32 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
Not enough info
what's the bike brand/model and what's on front now?
what type of riding do you do?
What's wrong with the Kenda tire you have now?
qclabrat is offline
Likes For qclabrat:
Old 05-18-20, 11:49 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 414 Post(s)
Liked 201 Times in 160 Posts
It's a highly competitive market and most manufacturers build pretty good products within their price brackets. I like a lot of Kenda products, for example. To even start giving a recommendation I'd need at least the tire size your bike uses, what kind of bike it is --XC? Short travel trail? Long travel trail/Enduro? FS, or hardtail? How do you ride and what are your priorities? Things like that.
cpach is offline
Old 05-19-20, 04:37 PM
davei1980
Very Slow Rider
davei1980's Avatar
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 499 Post(s)
Liked 129 Times in 101 Posts
I recommend getting the max width you can fit and set them up tubeless if your rims will allow. Higher TPI counts are better than lower ones, but, in my limited understanding, are not as important in wider MTB tires than they are in road tires.
Beyond that, just read the blurbs for the tread that fits your use and budget. I heard on what was basically a "tire TED Talk" from representatives from WTB, Schwalbe, and Ultradynamico, that tread patterns are more of a marketing gimmick than anything else, that is, people tend to buy tires that look cool. They also said that tires tend to handle about how they look so, that's a good thing. Their words, not mine.
I have had several tires and I enjoy Panaracer products, they're made in Japan and very high quality. I am currently running Vee Tire Co T-Fattys and I do not enjoy them. They are quality tires and they have good wear but underwhelming performance. Other manufacturers make great tires as well, with Maxxis being maybe the king of the hill in the MTB game right now. Figure out what you want then choose the tire, don't target a specific brand.
davei1980 is offline
Old 05-19-20, 06:29 PM
Steve B.
Quoted: 1886 Post(s)
Liked 569 Times in 377 Posts
I inquired and searched on my local mt. bike website and FaceBook page as to what tires folks were using for our local conditions. Turned out Nobby Nics were a popular tire, went with that and have been happy. But everyplace is different, soil, rocks, skill level, etc.....
Steve B. is offline
Old 05-24-20, 12:00 AM
jrhoneOC
Bikes: 2021 Specialized Chisel
Quoted: 60 Post(s)
Liked 53 Times in 39 Posts
OK...I will jump in and hijack the thread with my specs...I am looking for a new rear tire. The bike is a 2020 Rockhopper Comp 1x hardtail. I ride mostly XC and some pavement. Rides are usually 10-20 miles. My current tires are Specialized Fast Track Sport 29x2.3 in the rear and Specialized Ground Control Sport 29x2.3 in the front. These are not tubeless, wheels are not tubeless ready and I dont plan on going tubeless yet.
Easy thing is replace with the same tire. Wondering if there is a better option...lighter...more durable..better traction?
jrhoneOC is offline
Old 05-25-20, 01:54 PM
davei1980
Very Slow Rider
davei1980's Avatar
Quoted: 499 Post(s)
Panaracer CG XC or Panaracer DriverPro - The DriverPro's have awesome tread for your use and the option to go tubeless down the road if you so wish. Panaracer tires are excellent quality (in my experience) and made in Japan. Your LBS should be able to order. I would run exclusively Panaracer tires based on my experience with them but they have limited options in the PLUS/FAT range of casing sizing so my next tires would likely be Maxxis or WTB.
I have had a few sets of Specialized tires, not the ones you're running, and I find them to be excellent compared to others as well so can't go wrong with direct replacement either!
Old 05-25-20, 07:38 PM
Damar
neubie ​​​​​​​
Hola Im a Neubie
Damar is offline
Old 05-27-20, 09:56 PM
WannaGetGood
B*ck From Th* D**d
WannaGetGood's Avatar
Bikes: 2015 Kona Process 153
Quoted: 22 Post(s)
Liked 8 Times in 6 Posts
1) What bike do you have?
2) What kind of riding do you do?
3) Where are you riding in Canada, or what region?
WannaGetGood is offline
Old 05-29-20, 07:28 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Buy some tubeless tires now, why have another set which you don't want? Maxxis Recon and Continental x-king are good next options
qclabrat is offline
Old 05-29-20, 09:02 PM
Ryder1
Bikes: Evil Following MB, D'back Haanjo, Kona Unit SS
Quoted: 57 Post(s)
You didn't mention anything different you want in your next rear tire, so getting another isn't a bad idea. Lighter/faster is nice, but you're not going to find a mountain bike tire that's too much lighter/faster, the Fast Track is designed to go fast. The usual spec on that bike, per Spesh website, has a Ground Control 2.3 in back instead, which is a bit grippier, a bit slower. If you like the Fast Track 2.3, stick with it. I wouldn't go wider. 25mm rims like you have (a good spec for that bike) match well to 2.2-2.3 tires, no wider. If you don't have the GRID version, then you probably want to avoid it next time around, since it doesn't sound like you need it (rocks aren't destroying your tires like they do here in rocky Arizona), and it will slow you down a bit.
Ryder1 is offline
