Bike Hand headset press issue
Anyone run into a problem where the length of the headtube is too long to adequately use the Bike Hand headset press? I am having this issue. There is not enough length on the tool to secure the bottom press to it. Any ideas? Headtube is 158mm in length.
thanks!
thanks!
Quoted: 7348 Post(s)
Liked 2,470 Times
This sounds horrible but I have pressed headset cups in using a crude method. Put a board of wood on the bench. Press the cups in partially by hand. Rest the bottom part of the head tube on the wood on the bench. Put a second board of wood on the top cup. Bang with a hammer. Of course, be as parallel as you can but don't worry, because as you finish, it should seat properly. You might want to measure alignment with a caliper.
Generally, the softness of the wood prevents damage to the frame and cups.
Industry guy
Are you trying to install both cups at the same time?
Quoted: 1324 Post(s)
Liked 927 Times
I use a thick, long threaded bolt with some fender washers and nuts as a home made headset press. I make sure the cups are parallel to the headtube before tightening the nuts much to press the cups in. If the cups are not parallel to the headtube at the start it can be quite difficult to get them to go on.
Cheers
Cheers
Quoted: 714 Post(s)
Liked 800 Times
158mm is not a long head tube, so there should be no reason why it won't work. The two different versions of Bikehand headset presses, that I found, both appear to have plenty of length to press in a headset in a head tube of that size. Maybe a picture of your setup would help.
Quoted: 837 Post(s)
Liked 1,061 Times
Just watched their video on how to use this and they used a bike with a very short head tube which did not leave much more length to use on a bike like the OP's. I'd contact BikeHand for some guidance or a return. I can't understand why a mfr. would make a headset press with such a limited range. A 158mm head tube is not especially long or a rarity.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...except for the length of the rod problem, that looks identical to the one Nashbar used to sell (probably from the same manufacturer.)
It's a mystery to me, because the old Nashbar one works fine on head tubes longer than yours, and I can press both cups simultaneously..
That company also advertises a 107B for pressing BB cups, but yours is marked clearly 107. I would send it back on the assumption that maybe they screwed up in what they sent you (107 head with a 107B rod ?)
Quoted: 4205 Post(s)
Liked 3,864 Times
As long as enough install pressure is applied to seat the cups onto the HT faces the method (excepting those that deform the cups) have little bearing (bad pun) to the rest of the job. So bench vices, wood blocks with a hammer, all thread rod and huge washers, or a proper bike specific tool can all do the same job. Andy
AndrewRStewart
AndrewRStewart
Cheers
Cheers
Liked 927 Times
Cheers
Non omnino gravis
Quite the bummer. It has pretty good reviews. I contacted Bike Hand. Will report back what they respond
Liked 3,864 Times
Could the cocked cup deformed the HT? Sure. But is it likely, no. Steel has a fair amount of spring back, this quality makes it a wonderful frame material BTW. Starting cups straight and flat to the faces and keeping them so the goal.
When using a "tool" without snug fitting sleeves (into the cups' skirts) the cups will follow the path of least resistance. Since the facing, the slight counter sinking or the race, the ID control and the skirt's initial beveling are all across the board the cups can, and will, go crooked. The trick is as you did. Initially set the cups in the HT and then "work" the cups with some method to square them up with the HT (like a hammer tapped on the high points or repositioning the press to better push on those high points).
The slight HT expansion and all should not be an issue if the cups are straightened and pressed in fairly straight after the start. Of course there's the cup's deformation aspect too...Andy
AndrewRStewart
AndrewRStewart
Liked 927 Times
Cheers
Quoted: 4806 Post(s)
Liked 3,928 Times
Ben
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Could the cocked cup deformed the HT? Sure. But is it likely, no. Steel has a fair amount of spring back, this quality makes it a wonderful frame material BTW. Starting cups straight and flat to the faces and keeping them so the goal...The trick is as you did. Initially set the cups in the HT and then "work" the cups with some method to square them up with the HT (like a hammer tapped on the high points or repositioning the press to better push on those high points).
Likes For robertorolfo:
Liked 2,470 Times
@robertorolfo, that sounds better. Now that I think of it, I might have done it one cup at a time. I just can't remember.
Likes For noglider:
& along the home brew line, rather than a carriage bolt a length of Allthread rod works too , just another nut or 2..
Likes For fietsbob:
I have this same tool and love it. This might sound obvious, but have you unthreaded the handle as far as it can go? That got me early on.
