73mm square taper bottom bracket into 68mm shell
So, I installed a 73mm square taper bottom bracket into a 68mm shell. The drive side is fully in and good. But on the left side, it has a 2mm thread space outside. Is there a solution for this or simply let it go and it will not have any effect?
Quoted: 714 Post(s)
Liked 800 Times
In order to install a 73mm bottom bracket in a 68mm shell, you need a 2.5mm spacer on the drive side. Without the spacer, the spindle will be off center
Quoted: 6963 Post(s)
Liked 10,963 Times
Likes For Koyote:
Industry guy
You could source a spindle with the correct spacing for a 68mm.
That would be the only difference, unless this is a cartridge bb,
rusty
rusty
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Quoted: 1324 Post(s)
Liked 927 Times
If the chainline is problematic, it's possible that a 2.5mm spacer would "correct" the situation. Although given that the OP just shoved a 73mm bracket into a 68mm frame, I'd want to know more details before assuming that the spindle length is "correct" for the drivetrain in the first place.
Liked 10,963 Times
Given that a Shimano square taper BB is about fifteen bucks, I can't really fathom how this is even a question.
Likes For Koyote:
Advanced Slacker
Liked 2,537 Times
Liked 10,963 Times
Advanced Slacker
Liked 2,537 Times
Still 3 times the cost of a spacer.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
So a kludge rather than the correct part? I would rather spend the tiny bit extra and get the correct part. I could probably sell the 73mm BB and recoup some of the money I spent on the correct part. We aren't talking $100s here then I might say try a spacer but when you can do it correctly for not a whole ton of money and it will probably be a better more long lasting and reliable solution.
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
73mm BB in 68mm shell. Is there any legitimate reason someone would want to do this? Move the chainline maybe? Can't figure it....
Advanced Slacker
Liked 2,537 Times
Advanced Slacker
Liked 2,537 Times
Clark W. Griswold
Liked 3,993 Times
My Phil Wood,SKF and IRD Defiant bottom brackets didn't come with spacers. I just ordered the correct sizes for the correct shell width. Of course I am talking square taper as you are talking probably external BBs which do sometimes come with spacers but I have never needed to use those, sometimes for the cranks yes but never on the actual threaded part.
Advanced Slacker
Liked 2,537 Times
OK, well the OP now has choices. He can go to his LBS today and pick up a spacer for $5 or he can order a new BB from Jenson for $22 shipped and wait 5 days for it to accomplish the same thing.
I know what I would do, but that's just me.
FWIW, I've run into the exact same situation as the OP (had a 73mm ST BB and a 68mm shell, and I used a spacer. Worked fine for years until I got rid of the frame.
