Getting tubeless tyre beads onto rim
Old 06-23-20, 09:00 AM
bishop130771
hi guys and girls, I'm having all sorts of problems trying to get my tyres onto my rims. At one point I even double checked I wasnt trying to fit a 27.5 inch tyre on a 29 inch rim!!! I managed to get one bead on one wheel and got to within about 6 inches of getting second bead on but even with very large and sturdy tyre levers it seems impossible..
Has anyone got any black magic or secret trick not on the internet to help me!!!
bishop130771 is offline
Old 06-23-20, 11:17 AM
SilverRubicon
Quoted: 14 Post(s)
Liked 4 Times in 4 Posts
I have no magic advice to offer other than to make sure that the bead of the tire is sitting in the center channel of the rim. That can help as it should add a small amount of maneuverability to the tire.
SilverRubicon is offline
Likes For SilverRubicon:
Old 06-23-20, 11:44 AM
dsaul
Quoted: 452 Post(s)
Liked 202 Times in 152 Posts
This ^^^ You have to make sure the tire bead is down in the center channel all the way around and the tire will usually go on without tire levers. I've had people bring them to me because they couldn't get them on and they are amazed that I get them on immediately with no tools.
dsaul is offline
Old 06-23-20, 02:03 PM
prj71
Quoted: 1062 Post(s)
Liked 53 Times in 43 Posts
This.
If you can't get it on by hand you are doing it wrong.
prj71 is offline
Old 06-23-20, 02:51 PM
bishop130771
i am doing something wrong then. The bead is in the centre channel of rim (narrowest part) and there is no way it will go on even with tyre levers
Old 06-23-20, 03:37 PM
davei1980
davei1980's Avatar
Bikes: Jones Plus LWB
Quoted: 433 Post(s)
Liked 103 Times in 82 Posts
get the bead and the levers soapy. that will add some lubrication to keep them from binding as you work the bead on to the rim. I have had trouble breaking a stubborn bead and getting them started to get off but never getting them on the rim, like you describe.
Also, some sealant will work as a bead/lever lubricant if you don't have soapy water handy.
davei1980 is offline
Old 06-24-20, 09:16 AM
Wooderson
Quoted: 23 Post(s)
Liked 18 Times in 16 Posts
Originally Posted by prj71 View Post
This.
Eh, some tire + rim combinations are much harder than others. The WH-6800 rims don't have a channel, the rim bed is flat and shallow. Mounting most tubeless tires requires a bead jack or at least tire levers. I've had other rim tire combos where the tire will literally fall off the rim (when deflated).
Wooderson is offline
Likes For Wooderson:
Old 06-24-20, 01:10 PM
qclabrat
qclabrat's Avatar
Quoted: 252 Post(s)
Liked 68 Times in 61 Posts
which rim tire combo are you trying? I've have trouble with tubeless tires on on tubeless rims, especially with rim brake versions. There are even combos wider rims can also be difficult for some tires.
Also Pedro's are my go to levers, only broken one out of the 8 I have. Other levers are like noodles compared to them
qclabrat is offline
Old 07-03-20, 09:48 AM
commo_soulja
commo_soulja's Avatar
Bikes: are fun to ride
Quoted: 19 Post(s)
Liked 8 Times in 8 Posts
I've never had to use tire levers installing a tubeless tire onto a tubeless rim. Using the rim inner channel to drop the opposite tire bead while you flip the tire onto the last bit is key knowledge. Unless you're using Stans rubber rim strips?
commo_soulja is offline
Old 07-06-20, 06:39 AM
Wooderson
Quoted: 23 Post(s)
That works for many wheel/tire combos, but not for all.
Old 07-06-20, 10:37 AM
prj71
It works for all.
prj71 is offline
