Wolverine Build: Tiagra + XT
Old 02-06-19, 04:52 PM
bobin
Quoted: 30 Post(s)
Liked 2 Times in 1 Post
Looking to build a Wolverine Soma on the cheap. Can I put together Tiagra shifters + XT drive train? What brakes should I get? I need shopping links!
Or maybe this older Ultegra kit?
bobin is offline
Old 02-06-19, 04:58 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
I think with the old Shimano 9 speed stuff road/mountain shifters/derailleurs work together.
tyrion is offline
Old 02-06-19, 08:25 PM
wheelsmcgee
Quoted: 101 Post(s)
Liked 41 Times in 33 Posts
Which tiagra? I believe Tiagra 4700 uses a different pull ratio than earlier shimano 10 speed stuff. In any case, Check out the Wolf Tooth Tanpan. It’s a pulley adapter that changes a pull ratio so road shifters work with MTB derailers. I believe they make one that converts 4700 tiagra shifters to the pull needed for newer XT derailers, check Wolf Tooth’s site.
wheelsmcgee is offline
Old 02-06-19, 10:01 PM
gus6464
Quoted: 353 Post(s)
Liked 92 Times in 67 Posts
Well tiagra is 10 speed so unless you have a very old xt rd it's not going to work.
gus6464 is offline
Old 02-07-19, 11:03 AM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
Liked 145 Times in 78 Posts
Just use a Tiagra rear derailleur and a Wolftooth roadlink. It's good for up to a 42t rear cog. HG-500 11-42 shimano 10spd cassette is around $35.
Bryan C. is offline
Old 02-07-19, 10:22 PM
sienarot
Quoted: 5 Post(s)
What are you trying to achieve by mixing Tiagra with XT parts? Road shifters have a different pull ratio than MTB derailleurs. Like wheelsmcgee suggested, Wolf Tooth Tanpan will adjust for the difference.
If you want to make a 1x setup, Tiagra derailleurs also come in medium cages if you want a use a wide range cassette.
sienarot is offline
Old 02-10-19, 10:15 PM
09box
Quoted: 113 Post(s)
Go with Gevenalle for shifters. The Tanpan will probably give you the ability to run a larger cassette.
09box is offline
Old 02-11-19, 11:58 AM
Barrettscv
Have bike, will travel
Barrettscv's Avatar
Quoted: 910 Post(s)
Liked 288 Times in 158 Posts
Shimano 9 speed Deore derailleurs can be mixed with most Shimano 10 speed STI brifters except Tiagra 4700 ten speed. Any 105 or Ultegra 10 speed shifters will work with the Deore RD-M591 rear derailleur. The M591 can take a 36 tooth cog on a cassette and works great on 10 speed systems.
Deore 10 speed is not compatible with Shimano road shifters, including any Tiagra, 105, Ultegra...
Going with mechanical disc brakes will save you money. Also consider the TRP HY/DR hybrid mechanical/hydraulic brakes if you want the benefits of hydraulic disc brakes without the cost and installation headaches.
Be sure to invest in tubeless rims and tires. You will regret using tubes on gravel.
Barrettscv is offline
Old 04-26-20, 02:59 AM
felipe.gonzalez
Good bike
felipe.gonzalez is offline
agenkin
Bicycle Mechanics
14
06-23-17 11:37 AM
DGULL
Touring
39
01-24-17 12:21 AM
AndrewLeow
Bicycle Mechanics
6
10-25-14 10:51 PM
vonfilm
Classic & Vintage
12
08-28-14 01:57 PM
siddartha
Bicycle Mechanics
27
01-05-12 09:12 PM
