First bike - is a 2001 trek 2000 a good choice?
Old 08-09-10, 05:57 AM
doctorbonez
noob
Bikes: 2006 Trek 1000, 2001 Gary Fisher Tassajara, 2006 Citizen Gotham folder (her)
Hi everyone,
I'm considering getting a gently used 2001 trek 2000 (https://www.bikepedia.com/quickbike/B...2000&Type=bike). I'm coming from mtn biking, so I don't know all that much about road bikes, is there anything to look for when buying a used road bike? Any thoughts on this particular model? Is $350 a fair price for it?
Thanks!
doctorbonez is offline
Old 08-09-10, 07:17 AM
Spire
山馬鹿
Spire's Avatar
Bikes: Nakagawa
I have a 2002 Trek 1000 (I think it has the same SL frame) and it certainly has kept up over the years.
Sometimes though I think the similarly priced Specialized Allez would have been a better choice though... Check that one out too and see which one fits better.
Entirely depends on the condition, can we have more details like mileage, wear etc...
Become King of the Square! https://kingofthesquares.com
Plan or Find your next ride on Sporra!
Spire is offline
Old 08-09-10, 07:37 AM
rollin
Sua Ku
rollin's Avatar
Bikes: Trek 5200, BMC SLC01, BMC SSX, Specialized FSR, Holdsworth Criterium
Gently used, less than 500 miles ridden downhill only and only in the dry...
In all honesty many bikes sit propped up against the garage wall so the age might not be an issue. Components wear and tear will tell you more than the frame.
rollin is offline
Old 08-09-10, 07:39 AM
Spire
山馬鹿
Spire's Avatar
Bikes: Nakagawa
500 miles after 9 years?
Spire is offline
Old 08-09-10, 08:04 AM
doctorbonez
noob
i havent gone to look at the bike yet, but the seller says its 9/10 and been used maybe 200 miles. Anything a newbie can look for in terms of wear and tear?
Old 08-09-10, 08:09 AM
musicmaster
Quoted: 62 Post(s)
Condition of the rear cogs, scratches / dents in the frame. Brake wear
musicmaster is offline
Old 08-09-10, 08:12 AM
Spire
山馬鹿
Spire's Avatar
Bikes: Nakagawa
If its only had 300km in 9 years, I would be wary for rust and that the components of the bike still work.
at 300km there should be pretty much no wear on the bike itself so look for any indications that this may not be the case.
Spire is offline
Old 08-09-10, 08:32 AM
doctorbonez
noob
Ok, I'll take a look at this bike tonight and hopefully itll be as advertised without rust. Thanks for everyone's input so far!
Any thoughts on this bike vs. a newer used allez (if i can find one around the same price point?) Any difference between the older tiagra vs. newer sora components?
Old 08-09-10, 09:04 AM
Spire
山馬鹿
Spire's Avatar
Bikes: Nakagawa
Good Luck!
Spire is offline
Old 08-09-10, 07:57 PM
doctorbonez
noob
Took a look at it tonight. The bike doesnt look like there was too much wear, but it doesnt look like it was well cared for.. little nicks and scratches on it, probably from putting the bike down roughly.
Also, there was some play where the fork mates to the headset, it almost seemed as if there was something loose, but i didnt have the appropriate equipment to mess around with it and a quick call to a road bike friend told me to be wary since it could mean something expensive to fix. so I declined to purchase, however, after they got home, they said they used a wrench to tighten it and its fixed.
If its fixed i may consider buying it. Everything else seemed up to par, shifters worked flawlessly and brakes were fine. No real cable rub. Nicks and scratches here and there, but nothing big enough to indicate a big accident. Not sure what worn cogs look like, but these looked pretty good.
Old 08-09-10, 09:18 PM
roccobike
Bike Junkie
roccobike's Avatar
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times in 27 Posts
Did you ride it? That's an aluminum fork on an aluminum frame. It's going to transmit every bump and pebble to you. If you rode it and you like that kind of ride, go for it. Me, I'd pass. BTW, the price is pretty good but just tightening the head may or may not "fix" the problem. Check the bearings in the steering by moving back and forth off the ground. As you turn the bars, try to feel if there are any flat spots in the bearings. If there's a problem, it's hard to hide it. Also check for play in the head by rolling the bike forward then jam the front brake (front only) and watch to see is excessive steerer/fork movement.
Roccobike BF Official Thread Terminator
roccobike is offline
Old 08-09-10, 09:52 PM
doctorbonez
noob
I did get to ride the bike, but it was just around the parking lot. I haven't been on a road bike in 10+ years (back when i was a kid riding my dads road bike) so i dont really know how its supposed to feel, but on the parking lot for the 10 min i rode it felt fine. I did note that once in a while when i braked (maybe it was into a turn?) i noticed a clicking from the fork, which was probably that fork/headset play. I can actually see maybe 2mm of space between the fork and the headset.. with some grease peaking out when i touched it. fwiw, the play in the fork seemed to be a lateral movement,and not an up an down movement (if that helps at all in figuring why it was loose).
I'll be sure to get a feel for the bearings if i go pick it up.
Old 06-22-19, 06:26 AM
danco
A short while ago, in I bought a distressed 2001 model of the Trek 2000 Alpha SL.
It needed a bit of TLC and I replaced front derailleur, but it has become a favorite in my bike stable.
Do insist upon repair of the headset which was mentioned as suspiciously "loose."
otherwise, it becomes your problem so it can help negotiated a further reduction in seller's asking/accepting price.
They are solid bikes, and easily up-gradable when and if you should desire to do so.
Good luck.
danco is offline
Old 06-22-19, 07:44 AM
jlaw
Bikes: 2015 Spec. AWOL Elite,2022 Spec. Diverge, 1984 Trek 620 1985 Trek 620, 1979 Trek 710
Quoted: 394 Post(s)
Liked 194 Times in 110 Posts
Good, used road bikes at reasonable prices are all over Craigslist in your area (NYC, Hudson Valley, Jersey, CT). The value of bicycles drop like a rock once they roll out of the showroom - good for a buyer like you.
If you are not sure what you want/need I suggest that you not rush into buying the first bike you see - tons of options for you out there.
Since you have 12 posts you can post photos of what you are looking at (or Craigslist/Offer Up links) and ask the BF members to advise. State your height, inseam, price range, and style of riding/location you want to do.
jlaw is offline
Old 06-22-19, 10:11 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
I personally wouldn't buy a nearly 20 year old bike. Not even for 100 bucks.
rubiksoval is offline
Old 06-22-19, 12:09 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times in 163 Posts
Fortunately, the bike was only 9 years old when the OP posted
wipekitty is offline
Old 06-22-19, 12:15 PM
MyTi
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times in 31 Posts
Not a big fan of quill stems. In fact I hate them lol. But in the $350 price range it's actually tough to find a good road bike so I think this is a good deal so long as there are no major issues with the bike. That looseness could be the headset bearing but we'll see. Just be advised you will probably want to replace the seat, probably the cassette/crank to suit your riding style, etc. eventually. If you decide this sport isn't for you it shouldn't be hard to sell that bike for what you got it for.
MyTi is offline
Old 06-22-19, 05:04 PM
jlaw
Quoted: 394 Post(s)
So true! I always forget to check the dates on the original posts. But in reality the same questions and issues get re-hashed on BF over and over - so does it really matter that a post is 10 years old?!
jlaw is offline
Likes For jlaw:
Old 06-23-19, 06:47 AM
02Giant
Quoted: 1638 Post(s)
Liked 741 Times in 495 Posts
Maybe. When considering the cost of the bike in question 9 years ago vs. today.
nine mile skid on a ten mile ride
02Giant is offline
tkemp534
Road Cycling
12
12-21-15 04:42 PM
arbinomw
Road Cycling
6
04-24-12 10:50 PM
GordoTrek
6
02-21-12 08:03 AM
princealyy
Road Cycling
7
07-28-11 06:32 AM
jwats
Road Cycling
0
03-31-10 12:03 PM
