Zertz inserts
Zertz inserts
yHi all, my first post. I have a 2009 specialized tricross carbon bike. Nice bike. It has the zertz inserts in the seat stays. Does anyone know if those rubber silicone thingys can be serviced or replaced? I'm concerned that as they get old, they lose their elasticity. Any information on those things appreciated.
Quoted: 942 Post(s)
Liked 527 Times
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
The general consensus is that Zertz did minimal road dampening, even by Specialized dealers. As far as losing elasticity, the Zertz are a very firm elastomer that should last as long as the frame. So, like the above poster said, just keep the bike clean and ride.
Do you know if they were ever sold as a separate part? I contacted Specialized and they didn't tell me much. Just that they don't have them anymore. Can they be removed from the frame? I assume during the manufacturing process, they were inserted in the seat stays after the frame was built. But maybe I'm wrong. Maybe the seat stays were molded around them. Is there any risk of riding without them? Thanks much.
Zertz inserts do have a design effect on frame dampening. Some are replaceable some are not. Problem is availability. Even Specialized has left zertz behind with their newer frames. How effective zertz are really depends on how and where you ride and total rider/bike weight. Elastomer does harden with age and weather, so it’s possible under the wrong conditions that they will have little to no dampening effect. A dealer is unlikely to be of much help. Best idea is probably to contact Specialized directly with your concerns. Be prepared for a possible marketing runaround as you try to find real assistance. Good luck!
Quoted: 18378 Post(s)
Liked 4,512 Times
As far as I can tell, the seatpost Zertz just slips in, and can be pushed out.
I don't know about other Zertz.
However, I'm not sure replacement parts are available. You can ask Specialized. I have seen them yellow with age.
As a former Specialized dealer at the time the Zertz were in voque, they were not available as replacement parts. Cannot imagine they are available now. You can remove them and ride without and find that there is little to no difference in vibrations being transmitted through the frame.
According to a Specialized designer back in the day, Zertz are not a structural component.
Bikes: trek 720 multitrack hybred, 92 trek 2300, 2010 specialized roubaix, 2014 specialized roubaix
Quoted: 14 Post(s)
Liked 17 Times
on my 2015 specialized roubaix expert with a sl4 frame. the zertz are held in by screws on the frame. you can remove then pretty easily.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
I don't know that you will find any replacement inserts, I have not seem them offered that I can tell. Then again I don't really get much call for them even as a Specialized dealer. However I like most other folks didn't find Zertz to be anything of use. Maybe it did something but it would probably be tough to quantify. You can see the newer Specialized stuff has moved away from the Zertz so likely it was a marketing thing which they didn't really need.
What ol' Mikey needs to do is give a bigger budget to Erik Nohlin and co. let them design some awesome steel and maybe ti bikes (and other adventure/all road whatever in crabons) and let the Swiss division rock the e-bikes and fire whoever came up with the Alibi (I know rock hard solid tires aren't a new thing they are quite ancient and were handily replaced by that new fangled Dunlop invention called pneumatic tubes and tires) Also find a legal department that knows when to hold 'em, when to fold 'em, when to walk away and when to hide.
