Endurance vs Climbing Bikes
I picked up a Trek Domane a few years ago and have really enjoyed it. I'm considering picking up another bike and wondered about the point at which someone should be looking into a different style of bike, especially with respect to climbing. Where I ride in the Texas Hill Country, I generally cover roughly 500-1000 feet of elevation each hour. It's certainly not the mountains by any stretch, but I've wondered if the next bike should be something like an Emonda. Obviously, there are a lot of other variables in play, but at least with the style of bike, is there any general wisdom on when a lighter machine becomes better?
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I
Likes For GlennR:
Good thought! Unfortunately, I don't have easy access to a place where gravel is practical for me. Road is pretty much the only option, so my choices are more limited there.
No disrespect but that’s hardly any climbing.
I would go Madone all the way !
The domane is an excellent bike. Madone is a good total package for the roads out in Texas. Emonda SLR is a light climbing bike but before you lose lbs off the bike , make sure the ride lost all the necessary lbs first
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times
Around here, you get about 100 feet of climbing per mile if you stick to the hills. During our mountain biking practices, that could get up to 200 feet per mile on trails.
Anyway, it’s enough climbing that it would be fun to have a climbing bike. At least in my opinion. I have a 14.5 lb Canyon (with disc brakes) and it’s a ton of fun in the hills. Really light weight wheels will make the biggest difference in the feel of the bike when climbing, in my experience.
The difference in weight between the Domane and the Emonda are negligible. I don't think that you'll be able to feel you are climbing any easier on the Emonda than on the Domane. For a second bike I would recommend going with a different brand, something that has a slightly different geometry. It will bring more variety and fun to your cycling, and may prove which bike is faster.
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
I've also thought about the Madone, but haven't ever ridden a bike with that kind of geometry. It might be worth a look.
I figure I'm 5 lbs or so from getting rid of the necessary weight, so I'm feeling good about that!
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
What year and model is your Domane? I had a 2014 Domane 5.2 with Aeolus 5 carbon clinchers and a few other carbon parts and quite frankly, there was no need for another bike as it was light and comfortable. Maybe not Emonda light, but close enough considering I don't live in the mountains either... just hills.
Quoted: 389 Post(s)
Liked 255 Times
According to Trek, the Domane Sl6 weighs 20lbs. and the Emonda Sl6 weighs 18. That seems like a significant difference to me. Besides, I'm a firm believer in N+1.
Likes For Jack Tone:
Quoted: 8287 Post(s)
Liked 9,061 Times
Nah, no disrespect taken at all! This is exactly the kind of answer I was looking for. If the elevation I'm working with really isn't that much climbing, then there's no need to consider something that isn't a whole lot lighter. It's helpful to hear this reply to help cut through the marketing-speak!
On Your Left
Liked 2,434 Times
Liked 9,456 Times
Likes For WhyFi:
On Your Left
Liked 2,434 Times
Non omnino gravis
No matter how steep the hill, you will never notice a difference of a few pounds between two bikes. I don't notice the difference between two bikes that are almost 10lbs apart.
If you wanna N+1, go for it. No one really needs an excuse to buy another bike. But it seems odd to buy another Trek that is overwhelmingly similar to the Trek you already have.
Quoted: 1067 Post(s)
Liked 259 Times
I am not saying they will be noticeably faster, just that it will feel different.
Likes For Dean V:
Non omnino gravis
Ten pounds takes about 8% more effort to get to the top of the hill at the same speed. But if I don't worry about the speed, it's exactly the same.
Heavy wheels can feel significantly different compared to light ones. But a 6lb frame doesn't not feel appreciably different from a 2.2lb frame-- once it has a 200lb meatsack suspended over it. IME.
Bikes: 2021 Trek Domane SLR 7, 2012 Giant Defy 0, 2012 Trek Domane 6.2 P1, Bianchi Infinito CV disc Di2
Quoted: 212 Post(s)
Liked 1,000 Times
Get something like a Giant Defy or Bianchi Infinito. I have the Domane 6.2, a super bike and a real comfortable road killer. But in the mtns. of VA, the stiff frame and light weight of the Giant are a real benefit. I ride it exclusively there.
The Bianchi is arriving next week, and I suspect that will be in between in terms of its riding characteristics.
FL is flat, as you can surmise, but VA is really mountainous. I do about 2,000 feet every ride, and some of the grades are insane!
Ride hard and ride on......
Bikes: 2021 Trek Checkpoint SL (GRX Di2), 2020 Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 85 Post(s)
Liked 143 Times
I am fortunate to have both a Domane and an Emonda. Both have superlight wheels. The Emonda is snappier on short sharp climbs and a wee bit quicker. Slogging up a mountain pass, the 2.5 pounds I give up with the Domane makes virtually no difference on the clock or in my perception of effort. With the slight aero on the new Domane frame, it is marginally faster on flatter rides and significantly faster on rougher roads.
With approved clearance up to a 38s - I am actually running 40s on a second wheel set - Glenn is right: the Domane chews up gravel like it was made for it. Having the option is cool. When I put on the aero carbon wheels with 28s, it is a super fun and smooth road machine. I'm thinking the Emonda is going to see less and less action as time goes on, not because it is lacking at all, but because the latest generation Domane is so good and so versatile.
Quoted: 74 Post(s)
Liked 74 Times
For what it’s worth, I really enjoy my Canyon Ultimate EVO for climbing. The DT Swiss PRC 1100 wheels are very light (1280 grams or so).
Quoted: 167 Post(s)
Liked 291 Times
The Domane geometry and whole reason for being is greater comfort vs Emonda and Madone. In terms of speed, it is relatively fine margins in general use in my experience of similar bike comparisons. The Emonda, like my Wilier Zero.6, will accelerate a bit quicker and pushing for every second, will be faster on steeper gradients, say 10% average, thanks to its lighter weight - the difference however depends upon how much value you place in the time advantage the lighter bike can help you achieve. It depends upon how you ride, the more leisurely you ride, the less you would notice any real difference. Chasing KOM's and/or racing? Emonda,
The Madone is my personal preference for a stablemate to a climbing bike and is the one I have made because speed is my goal and while I live in a very hilly area, it is not mountainous and a Madone will serve me very well when not doing climbing days.
If you aren't all that interested in marginal faster times at all and only after the occasional bit of fun on a club ride, the Domane is perfectly suited I think. If you do want some more speed but not living in a steep gradient zone, then Madone in my opinion as a +1 to the Domane but it is a far more aggressive riding position, so test ride first to see if you get along with it.
Liked 259 Times
I have had Domane, Emonda, and Madone all with H2 geometry and I set them all up with the same riding position.
I would still have the same position with H1.5, just need a few spacers under the stem.
Quoted: 167 Post(s)
Liked 291 Times
To add, this review I found seems to agree with my experience:
https://cyclingtips.com/2019/07/2020...t-ride-review/
