SRAM invents rotating 3 FD system
Old 06-17-20, 11:09 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
It sounds like this would give the bike a slightly cleaner look, and still not work. Next year, there will be a rotating 1x system.
All of the design’s front shifting mechanisms are built into the crankset. There’s nothing – zero – mounted to the frame. The system includes a wireless receiver, battery, and one motor, all of which enable three separate derailleurs. It’s all tied together with linkages and cams and pivots and springs and sensors in a symphony of electro-mechanical action. I’ll skip over most of the internal fiddly bits, and focus on how shifting actually works.
SRAM engineers found a way around this, but it adds significant complexity to the system. Sensors know the rotational position of the cranks, so the downshifting elements only move into shift position when they’re between about 6:30 and 11 o’clock. When one downshift element approaches 11 o’clock, it encounters the side of the chain, and pushes the chain inward and down to the small ring. That’s why there are two downshifting elements: press a shift button, and the system waits until one of them is in the right spot. That means two shift periods per pedal stroke.
https://cyclingtips.com/2020/06/radi...g-derailleurs/
Seattle Forrest is offline
Likes For Seattle Forrest:
Old 06-17-20, 12:05 PM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times in 266 Posts
Interesting the wireless technology allows it. But Looks like it may add expense to the chain rings or a more complex replacement procedure.
biker128pedal is offline
Old 06-17-20, 12:44 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,630 Times in 934 Posts
OMG.
What's wrong with a Schlumpf drive? They work great. They have more range than what a standard 2x can offer. They are all sealed up & have none of this confounding complexity.
I bet this high maintenance proprietary monstrosity will cost well into 4 digits after market maturity...& still won't be supported in 10 years.
Replacement rings, anyone?
SRAM: Do you even bicycle, Bro?
base2 is offline
Likes For base2:
Old 06-17-20, 01:10 PM
spelger
spelger's Avatar
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times in 687 Posts
wonder how it handles with a dead battery. i'll stick with mechanics.
spelger is offline
Old 06-17-20, 01:43 PM
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
For a company that thinks 1x is the future, this sure seems like a lot of investment into 2x.
I’ll bet $1.00 that even if SRAM came out with this, which is questionable, people would still prefer di2.
smashndash is offline
Old 06-17-20, 02:08 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,434 Times in 1,187 Posts
I have one word... 1X. Problem solved
GlennR is offline
Old 06-17-20, 02:15 PM
RiceAWay
Quoted: 325 Post(s)
Liked 112 Times in 81 Posts
This is silly. There's NO WAY you can get it to work without dragging unless it is part of an electronic shifting group and there is a lot of built-in programming to force it into the correct position on top to bottom cog shifts. That would take THREE motors on the front. SRAM does not have good engineering and most of their components are cheap junk that you pay premium prices for.
RiceAWay is offline
Old 06-17-20, 02:19 PM
RiceAWay
Quoted: 325 Post(s)
I did too until I happened to get a Ultegra Di2 group with hydraulic disks on the cheap. After I got it working I was sold on it.
My DuraAce manual group is noisy and very hard to set up properly and I've been working on my bikes for 40 years.
RiceAWay is offline
Likes For RiceAWay:
Old 06-17-20, 02:23 PM
RiceAWay
Quoted: 325 Post(s)
Seattle Forest = If they are using a single motor imagine the linkage and the number of rotational points. And SRAM cannot even make a bearing that doesn't wear out in a couple of months.
RiceAWay is offline
Likes For RiceAWay:
Old 06-17-20, 03:02 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times in 560 Posts
I've said it many times and I stand by it - we will see the return of triples.
Also this is just a patent. I wouldn't hold your breath.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Likes For Psimet2001:
Old 06-17-20, 04:30 PM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
+1 on the return of triples.
If a computer takes over the FD shifting duties that will be the direction the industry goes.
seypat is offline
Old 06-17-20, 08:07 PM
spelger
spelger's Avatar
agree with the triple, i love mine.
a computer can still shift the FD if done right but this just seems like a cockamamie idea with a lot of moving parts. so many things to go wrong.
spelger is offline
Old 06-17-20, 08:10 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
Is today April 1st?
noodle soup is offline
Likes For noodle soup:
Old 06-19-20, 05:52 PM
kansukee
Quoted: 122 Post(s)
Liked 51 Times in 27 Posts
What could possibly go wrong?
kansukee is offline
Old 06-19-20, 06:37 PM
Dean V
Quoted: 1067 Post(s)
Liked 259 Times in 153 Posts
If it looks good and works well people will buy it.
Simplicity is not a factor for the majority of consumers.
Dean V is offline
Old 06-19-20, 07:24 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 178 Post(s)
Liked 177 Times in 101 Posts
Chances are SRAM never intends to produce this, but is only doing so to file the patents. One of the reasons SRAM went wireless when they developed E-tap was because so many patents already filed was a big hinderance.
Rogerogeroge is offline
Old 06-19-20, 08:23 PM
grizzly59
Quoted: 283 Post(s)
Liked 262 Times in 164 Posts
No batteries, no bluetooth, no cables, no brifter, and it's French:
grizzly59 is offline
Old 06-19-20, 10:55 PM
Seattle Forrest
I bet that works better than a yaw DR.
Old 06-19-20, 11:30 PM
justonwo
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times in 34 Posts
Technology companies often file all sorts of patents for things that may or may not materialize. Sometimes oddball ideas lead to breakthroughs. It’s healthy and normal for parents like this to get filed. Not sure why you guys are getting out the pitchforks and torches.
justonwo is offline
Likes For justonwo:
Old 06-19-20, 11:53 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
My rather cynical observation is that SRAM has been burned rather badly by at least one very famous FD mishap. The very public chain jam that cost Tour de France racer Andy Schleck the race, SRAM FDs are widely talked os as inferior to their competitors. I'm inclined to agree after picking up a collection of SRAM, Campy, Shimano and SunTour FDs to see if I can get a low Q-factor triple working well.
If you cannot make an FD work, well, try something else.
Ben
79pmooney is offline
Likes For 79pmooney:
Old 06-20-20, 12:58 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
This reminds me of that C&V expanding chain ring.
Genesis 49:16-17
Darth Lefty is offline
Dean V
I am just constantly amazed that people still keep going on about Sram front mechs not working well.
I have had several and the shifting is excellent and comparable to the other brands.
Dean V is offline
Old 06-20-20, 10:42 AM
base2
I am potato.
base2's Avatar
I've never known a SRAM front derailleur, of any vintage to work well. My wife hates hers. And although it should work, it doesn't. It's not adjustment of the limit screws. It's not cable tension. It's not alignment. It's not height above the rings. The performance is just spotty, inconsistant, & terrible. Over the years I've made every attempt to address whatver the concern is "this ride" but there is just nothing more to do & she is begging for a swap to anything else from SRAM Red.
You can now add rear derailleur to the list of garbage SRAM turns out as well...A friend & I took out our mountain bikes the other day. Hers had never been crashed, knocked over etc. & had only been on 1 other ride. A hollow pin of rolled steel in the derailleur bent (& then sheared) from what we can only figure was vibration of riding or just simply the force of the long lever of the derailleur cage necessary to extend up to the 50 tooth cog. To cap it off, while sorting out the derailleur situation, we learned the shifter has enough room internally for the head of the shift cable to turn around & jam up the guts of the shifter. It's just sloppy design. It was a long, slow 7 mile ride/coast down off the mountain.
$125 for a better derailleur with a solid pin, plus labor on a twice riden bike.
I'd send my money elsewhere. Over-priced, poorly engineered & cheaply executed.
Car dependency is a tax.
base2 is offline
Old 06-20-20, 01:02 PM
Seattle Forrest
If this becomes a thing in reality, they can call it triple tap.
Old 06-21-20, 06:17 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
So, the strategy is to convince us all that we don't need FDs, wait for us to buy frames with no provisions for FDs, let us realize we still want FDs, then sell an incredibly overengineered system to give us an FD back?
Bah Humbug is offline
