Zeus components
Zeus components
Specifically bottom brackets. I am used to Campy, Suntour and others with shell width markings, 68,70. I keep seeing Zeus marked (spindle length) x55? Like 118x55. What is the 55? Shell width for the bearings? Velobase didn't elaborate so trying to figure out what's up. French, Swiss?
Thanks
Tom.
Thanks
Tom.
Quoted: 261 Post(s)
Liked 346 Times
Thanks
Tom.
Thanks
Tom.
Quoted: 3814 Post(s)
Liked 3,345 Times
the 55 marking refers to the distance apart of the bearing centres as measured in mm
it indicates a spindle intended for use with 68mm shells
Quoted: 7351 Post(s)
Liked 2,478 Times
Spanish math!
Likes For noglider:
Liked 3,345 Times
Zeus spindles marked with a 57 are intended for use with 70mm shells
spindles of 109 length marking are intended for use with with single plateau drive trains
spindles of 114 and 118 length markings are intended for use with two plateau drive trains
spindles of 123 length marking are made for use with three plateau drive trains
Likes For juvela:
Thanks. I also ask on a different forum and found out Zeus marks theirs different, the 55 instead of 68, etc. Of course I then measured a couple of spindles I have and amazing! Also, and please correct me if, they mark the cups with a bcs for English, 36x24F for Italian, and just Zeus for French?
This gets tedious sometimes.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Liked 3,345 Times
the set imaged above looks to be a Criterium series example
the marking shown was employed for a fairly long period
later on they went to writing it out in full as on this Italian dimension 2000 serie set -
CH dimension sets were not offered
Old fart
Liked 3,401 Times
I have a couple "2000" model bottom brackets; both marked B.S.C. Curiously, I have "ZEUS 2000" marked crank mounting bolts in both steel and titanium.
Likes For JohnDThompson:
Liked 3,345 Times
the 2000 series components launched in 1974 so one can see how there would be examples with the earlier thread marking format
Those are great examples. I have looked at several on the bay and most seem unmarked, guessing French. Just bought a used BB marked bsc so hoping the races and such are good. Headsets seem a little harder, any markings on those? Once again most sellers don't know what they have concerning threading. Not sure how much I want to gamble.
Tom.
Tom.
Liked 3,345 Times
the most common Zeus steel headset is a model termed the Gran Sport - it is very good
on this model the thread is marked in two places:
a) on one of the spanner flats of the locknut
b) on the "cheek" of the adjustable race
the catalogue states it was offered in metric and in BSC, not in Italian
here are shown the thread markings on models 2000, New Racer and Cosmos:
Old fart
Liked 3,401 Times
The Zeus headset I have is marked "B.S.C." on both the locknut and the threaded cup:
Likes For Roger M:
Old fart
Liked 3,401 Times
Bikes: french Toulouse style, campy style Torrot and Orbea Orduña
Quoted: 7 Post(s)
Do you know which standard Zeus complied with? JIS or ISO?
You seam to know quite a lot about Zeus bikes. I'm trying to bring back to life a Torrot bicycle from late '70s. It has been tweaked up a bit. It came with two different types of cranks, Stronglight on the driveside and Arregui on the left. The left one (Arregui) it leaves a gap of 5mm between the end of the spindle and the crank's outer side square hole ( I suppose the crank is ISO and the spindle JIS) The Stronglight fits deeper and leaves a gap of 3mm. The spindle is 118x55 GS. Do you know which standard Zeus complied with? JIS or ISO? Thanks a lot.
Liked 3,345 Times
Hi,
Arregui designed their cotterless chainsets a good two or three decades prior to the existence of ISO
have no experience of mixing Zeus with other brands so cannot comment there
no one in europe was designing to JIS standard back when Zeus tapered square chainsets were first created
other readers are sure to be able to give a better answer to your very reasonable question
sidenote on Verot-Perrin -
they performed a major reworking of their range in 1977
new models were introduced which employ a 22.0mm puller thread and which have their dentition cut from both sides of the stock rather than one as is found on older models
this new cutting of dentition means lands need to be thinner
mention this as there may have been other changes as well...
Likes For TenGrainBread:
Quoted: 1372 Post(s)
Liked 1,752 Times
This goes up for sale, on the G
For Sale forum, in the Spring, when I get back to Canada...
Quoted: 7 Post(s)
Arregui crank
Thanks!
My Zeus spindle looks more like an ISO type. Zeus is supposed to have copied Campanglo a lot so maybe they tapered their cranks like it. However pre '94 Campy it was closer to JIS than ISO. This would explain the fit gap if Arregui crank is added later and it is ISO. But being Arregui and Torrot both basque companies it appears to me more natural have used originally Arregui cranks and not Stronglight. I tryed upload a few pics but I need to have 10 post done for that.
Liked 3,345 Times
Arregui crank
Thanks!
Thanks!
The forum has had a few threads on Torrot cycles.
If you have not done so already you could use the on-site search function to bring them up.
Torrot marque history is interesting. It issues from what was originally the Terrot agent of Espana. For some reason the manufacturer wished to take it away from them so they responded by creating a new marque one letter away from Terrot.
By this time Terrot may have ceased their manufacture of motorcycles. The marque was acquired by Peugeot in 1958 who kept it alive for several years by manufacturing Peugeot built cycles bearing the Terrot name. AFAIK Peugeot allowed the Terrot name to close by 1965. There is a France based club for the owners of Terrot products; they have a good deal of historical material archived at their web site.
Will look forward to seeing your Torrot whenever you are able to begin a thread on it.
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 123 Post(s)
Liked 240 Times
So typically Zeus. The knuckles are what you would expect to see on a pre-1967 Campy bronze derailleur, the cage and body like restyled copies of the then-current Nuovo Record, drill some holes, slather on some extra (and better) chrome, and give it a futuristic name and you have a winner -- especially when you discount the price,
Likes For sbarner:
Liked 3,345 Times
Old fart
Liked 3,401 Times
Thanks
Tom.
Thanks
Tom.
