Bike chain grime
Bike chain grime
How bad is grime on a bike chain? I use Finish Line Wet on my chain because I live in a wet are with a lot of road salt but I notice the chain gets a little gunky quickly.
Quoted: 4227 Post(s)
Liked 2,488 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Depends on how often you drop a chain. Or if you have white clothes on. Or if you put the bike in a light colored car. Or if you have a white (or light colored) dog.
Stuart Black
Stuart Black
Likes For cyccommute:
If your question is actually serious, try searching a bit. You’ll find lots of info on drive train maintenance.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,644 Times
From Bike Hike. https://cyclinghikes.com/what-does-a...bike-chain-do/
“How much difference does a clean bike chain make?
It’ll Make You Faster There’s a cheaper, more ethical solution. A clean, properly lubed chain will save about 10 watts over a poorly maintained chain, according to Jason Smith of Friction Facts, a Colorado-based research firm. For the average rider, that accounts for about 4 percent of lost power.”
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 967 Post(s)
Liked 1,631 Times
When I was ridding Roadbikes and Roadbike Routes I did not have to clean my chain as often as now that I am ridding light gravely Dirt Roads and Torn Up Asphalt. My chains are always well lubricated and sometimes my chain is so dirty from dust that it almost drips mud off it by the time I get home. Its no biggy, I just hit it with some used ATF, wipe off the dirt and lub again... Happy Happy, Joy Joy...
I know some young Mountain Bike Studs that would not consider thier ride a good one unless their bikes were covered with dirt and mud chain included... Ha
Bikes: 70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, '11 Shimano Masi Partenza
Quoted: 109 Post(s)
Liked 19 Times
From the previous REALLY vague and simple questions you've asked before this and if I didn't know any better, you sound like a scammer trying to up their post count and legitimize themselves a little before attempting to scam someone... "How do I keep these tires from blowing?" "What chain oil do you use?... The last two scammers I seen here did the same exact thing.
70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, & '11 Shimano Masi Partenza
Likes For buddiiee:
Grupetto Bob
Liked 5,644 Times
Just love the name calling. If you don’t like someone’s post, don’t read it and move on.
Likes For rsbob:
It can work against legitimate posters too.
Likes For wellerchap:
Likes For Pinelander:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
There is a spate of trolling posts going on that get jumped on, but I don't think that was your intention with your post about the freewheel or the OP in this thread.
Likes For Chuck M:
Quoted: 506 Post(s)
Liked 639 Times
Depending on your local conditions, the grime, as you call it, can be a mix of hard materials (like fine sand) that can serve as a grinding compound and accelerate chain wear. If on the other had it is all organic material then it's not much of an issue. For most people in most places, it is the former and so the goal of keeping the chain clean and properly lubricated to gain maximum chain life.
Quoted: 822 Post(s)
Liked 1,961 Times
Grime is just part of being an active cyclist on dusty roads. The more grime the better.
Clean, degrease and re-lube every 150-200 miles depending on my grime level tolerance.
Grupetto Bob
Liked 5,644 Times
Don’t know if I quite agree with the more grime the better since it cuts into watts (see my post above), but since it works for you it works for you.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The grime can be abrasive, and accelerate wear of drivetrain components, particularly soft aluminum chainrings.
Grupetto Bob
Liked 5,644 Times
Likes For rsbob:
Liked 4,220 Times
Grime isn’t a given. I’ve ridden tens of thousands of miles on dirt roads without collecting grime. Grime comes from using the wrong lubricant. As a long term user of White Lightning, I don’t have to clean nor degrease ever! I don’t even have to lubricate that often. It makes life a whole lot easier than when I used oil lubricants 20 to 25 years ago.
Stuart Black
Stuart Black
Quoted: 822 Post(s)
Liked 1,961 Times
Good to know. Tried several wet and dry. I'll give it a try!
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Quoted: 506 Post(s)
Liked 639 Times
Half way there
Quoted: 986 Post(s)
Liked 880 Times
A bit of grime is a given on any wet lubed chain. To minimize grime, wipe your chain often, Wipe it after you lube and frequently thereafter. Wiping reduces the amount of surface oil that picks up the gunk. Wiping will not reduce the amount of lube within the links, i.e. where it counts.
Good luck and welcome to Bike Forums.
Likes For Moe Zhoost:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
I found that high-end KMC or Dura Ace chains work well with White Lightning.
Squeaking seems to occur more frequently when it comes to replacement time.
That happens to me around the 5,000-mile mark. Slap a ruler on it and, sure enough, there's some elongation.
My pal started putting a thick petroleum-based lube on to eliminate his squeaking. In frequent intervals, I might add.
When he bragged that he ran the same chain for three years and over twelve thousand miles, we put a ruler to it.
That sucker stretched more than a quarter inch over a twelve inch span!
Looked at the rest of his drivetrain and everything needed replacement: pulleys, rings, cassette. cha ching!
Likes For roadcrankr:
Liked 4,220 Times
Second, the wax is highly durable but it doesn’t flow like oil does. The “squeak” that some people report is due to the wax being squeezed out of pressure points and not flowing back like oil does. This causes some lubrication starvation of the pressure point and does allow for a little bit of oxidation when water is introduced. But the wax is still on the chain and it does some lubrication. On the other hand, oil doesn’t mix with water but water and oil form emulsions which puts water in contact with those same pressure points where it can do just as much oxidation. You don’t hear a “squeak” because it is drowned out but that doesn’t mean that the oxidation process is stopped. It’s just disquised.
Third, yes, wax doesn’t attract dirt. And wax is solid so it doesn’t flow. This means that grit doesn’t flow into the chain where it does damage at those well lubricated pressure points. Grit that is harder than steel under pressure means accelerated wear. Metal on metal grinding at that pressure points when using wax also means accelerated wear.
I’ll be the first to admit that White Lightning doesn’t result in longer chain life but I also know that oil doesn’t provide longer chain life either (I’ve used oil in the distant past). The only advantage of the White Lightning is a significantly reduced need for constant cleaning…as in never! Chains on my bikes are cleaned once before they are installed and they never get nor, more importantly, need cleaning.
These three bikes are in-service chains that have not been specially cleaned before the pictures were taken. That’s my chain and drivetrain cleanliness on every ride for thousands of miles. If you want to avoid a dirty, grimy drivetrain that constantly needs cleaning, use wax based lubricants (not a fan of hot wax, however). The results are more time for riding and less time cleaning.
Stuart Black
Stuart Black
