Anyone here still on a more race-type bike?
Super Modest
Quoted: 10963 Post(s)
Liked 4,621 Times
My wife and I both own near top end 2022 Émondas. We both turn 72 this year. My “backup” bike is a 2021 Colnago and hers is a Specialized Amira Pro. Granted, we’ve been riding 40+ years and both come from a racing background but we both feel like kids on the bike. Off the bike, we both feel our age.
Seriously, I feel more normal/younger on the bike than off.
Keep the chain tight!
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
With that said, the question your LBS is asking is reasonable. Have you ridden the bikes your interested in? The handling is very different, and you'd be well advised to spend some time test riding as many different race bikes as you can to get a better handle on what you like and don't like.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Likes For bbbean:
Endurance geometry is much like that of bikes built for triathletes in the 1980's with greater fork rake for increased stability. It was assumed that after the long swimming event that the athletes would benefit from a bike that required less attention to keep it going straight. The Centurion Iron Man bike is a good example and one that I owned and loved to ride.
To me the difference in handling is like the difference between a Jeep and a Miata on the highway. The longer the drive and the more twists in the road the more I would want to be driving the Miata.
The opposite are bike frames meant for criterium races on short courses with many sharp turns. This frame geometry dominated road bikes produced for decades. The availability of "endurance" bike frames is to me a very positive bike and probably the better choice for 90% of riders who do not participate in short course races.
The longer top tube also works well to allow the rider to stretch out a bit more and not be scrunched up when riding. I find this helps my breathing when attacking a hill.
Likes For Calsun:
Quoted: 1952 Post(s)
Liked 2,013 Times
What is the difference between the Domane and the ordered TCR? I don't have anything modern CF but racey bikes like a Cannondale 3.0 or a Allez SE are race bikes that ride racey regardless of saddle to bar drop.
Quoted: 6196 Post(s)
Liked 4,811 Times
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Likes For TejanoTrackie:
Veteran Racer
Liked 765 Times
Not an awful lot, really, other than the fact the Domane accommodates wider tires and has lower gearing. The difference in tire size has more impact on handling than the slight differences in geometry.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Quoted: 8286 Post(s)
Liked 9,055 Times
Likes For big john:
Quoted: 4806 Post(s)
Liked 3,932 Times
I picked up an '83 Pro Miyata last summer, narrow tubed steel but pure race and about as good as narrow tubed steel gets. Got it hoping it would be the ride of the '76 Fuji Pro that I raced was. And yes, only a lot better. Tubing came a long ways in those few years. So did Japanese race bike design.
And the ride? Well the position is my old race bike except much longer reach and bars are a little higher. The ride? Like I said, pure race. Doesn't remotely pretend to be anything else. 25c rear tires don't even turn unless you deflate them. Like my old Fuji.
Yes I did compromise on the crankset. 'Bout to hit 70. So it's a Campy Chorus triple. 53-42-30. 13-26 7 speed. (Big step down from the 53-42 x 13-19 5-speed I raced much of New England on but it still feels 100% race. Now the wheels - Tubular with tires that are close to what I raced. Mavic GPs and GEL330s. One step heavier now than then. Same spokes gauge-wise; light! Clipless, not toeclips but still no-float. Once I'm clipped in and rolling, this bike takes me to the same place. (Just slower but that's an engine issue.)
Quoted: 876 Post(s)
Liked 2,293 Times
1982 Medici Pro Strada
I like a set up like I have on this bike for a 2-3 hour ride max. For longer rides I have a taller stem but still like the race geometry due to my long legs and short torso. Most of my classics are race bikes from the era I’m from , the seventies. I am 68.
Likes For Kabuki12:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 570 Post(s)
Liked 773 Times
51 - been back at it for 4 years, getting back into form after looong layoff/back injury.
Riding a 58cm now with "race geometry" and a decent seat/bar height differential. I keep slowly dropping the bars as my fitness improves.
My next frame will be a 56cm with even more of an aggressive position.
The 58 will be my century bike, the 56 will be the fast/short ride bike.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I like older (1960s and 1970s) racing frames, which can accept wider tires and which represent a sweet spot compromise of sportiness and stability.
Quoted: 5888 Post(s)
Liked 3,471 Times
I like my 1982 Peugeot PXN 10 which was a racing bike back in the day. I used to own a step down model (a PKN 10) that I trained on regularly with all the local racers. The biggest differences from back in the day when I raced are that I run my handlebars a bit higher than I used to, I run a little fatter tires at a little lower pressure (28c rather than 23/25), and I run a little lower gears (48/36 rather than 52/42 up front and a bigger freewheel, 14-28 rather than 13-23).
So yeah get a racing bike if you want but think about (a) position; (b) tire choices; and (c) gearing (which isn't much of an issue on modern bikes but worth thinking about if you like riding hills--I do).
Quoted: 659 Post(s)
Liked 595 Times
‘88 Cannondale Criterium Series. I only ride the racers. Even the 1898 Glenwood is a hardcore 125yr old racer built for wood/board tracks.
Likes For OldsCOOL:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,647 Times
Oh now I am starting to feel old since I ride an endurance frame. However, the speeds I can maintain on an aero frame with deep section wheels is very similar to my late 40s with the same perceived effort, so I am fine with a more comfortable, less nervous frame which is not quite as responsive in fast tight downhills. The wheels in the picture are not my deep sections (duh).
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
I still race my old Tarmac.
I’d get a new one but I can’t justify it because 1) I have way too many rimbrake wheels and 2) my next new bike will probably be a new TT or CX bike.
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,482 Times
Okay here is my road "climbing" race bike. Wait, am I allowed to post two bikes?
Life Is Good
Bikes: Zipp2001 Carbon Belt Drive SS, Kestrel RT900SL, Kestrel KM40 Airfoil 1x10, Orbea Occam H30, Trek Stache 5 29 Plus, Giant Yukon 2 Fat Bike
Quoted: 277 Post(s)
Liked 870 Times
About to turn 63 this week and still love riding these road bikes.
Likes For ZIPP2001:
“Touring bikes have more rake than road and cyclocross bikes in order to increase their wheelbase length, provide more toe clearance from the front wheel and to increase the fork’s vertical compliance. The product of the head tube angle and the fork rake is the ‘trail’. This is the measurement that gives us the best indication of how fast a bike will steer. Touring bikes have a lot of ‘trail’ to slow steering response and keep heavy loads stable on fast descents.”
Likes For Calsun:
Getoutofmyway
Quoted: 9 Post(s)
Liked 12 Times
Maybe I’m on the wrong thread, I’m 58 and like a fast nervy bike as much as anyone, but I also like big tires and mountain bikes. This year I took a chance getting an inexpensive Sora Cannondale Topstone supposed gravel bike against everyone’s advice, I lowered the handlebar and put on Marathon Plus 38mm tires. If I want to go fast I pedal, the bike responds and I can plough ahead without minding what the pavement looks like. I like my race-oriented endurance road bike with 25-28mm tires but I think I’m having more fun with the heavy duty bike.
Expired Member
Liked 5,441 Times
Likes For shelbyfv:
Getoutofmyway
Quoted: 9 Post(s)
Liked 12 Times
I also recently got an AL Topstone for road riding, though I wasn't offered advice either way. Actually, I didn't think to ask. Anyway, I put on 38mm Gravelking slicks and I'm pretty happy with it. Still getting used to the 46-30 crank but I appreciate the stability, fat tires and comfortable fit. Mid-seventies, have to assume that faculties are diminished. WAG is that it's a couple of mph slower than my former road bikes. I've about aged out of my group anyway so speed is less important.
Expired Member
Liked 5,441 Times
Yes, I did that after my first ride. It was a skyscraper as delivered.
Likes For shelbyfv:
