Shimano 11-sp expendables worth downgrading or upgrading?
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
Forum members give good advice here. Strong common sense and experience.
Looking for some possible places to cut costs. Darn inflation really jacked prices the past few years.
With the exception of my Ultegra cassette, all my components come from the Dura Ace line.
Rim braking, staying 11-speed mechanical, already own some new spare brifters, rings, pulleys, and pads.
Not racing anymore, but do not want to sacrifice too much in terms of performance. Always buy new and do my own wrenching.
Facing a reckoning in the very near future with the following consumables:
1. Bottom bracket.
2. Chain.
3. Wheelset.
4. Pedals.
5. Cassette.
Not much bang-for-the-buck with the first two, unless it involves dropping to (gasp!) 105-level.
The wheels could save some real money. Big fan of the bulletproof 9000/9100 line, which typically get me 40k miles.
(My recent rebuild showed wear, giving me the impression of less than 10k to go.)
Please let me know your thoughts and recommendations.
1. Bottom bracket.
2. Chain.
3. Wheelset.
4. Pedals.
5. Cassette.
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,998 Times
My bottom brackets are usually from Wheels MFG though I did just get a Kogel B.B. but that was more of a really good deal as I got it at a fire sale at my old shop since they are trying to liquidate stuff but I have been pretty much the only former staff helping out as well (because I was recommended and trusted not because nobody else would help). Chain I usually stick around Ultegra level I don't see a major need for DA for that same with Cassette. Pedals are XT level for added durability V.S. XTR (since I run SPD not SL or Look KEO...) Wheels are all handbuilt and in the case of my main modern 11 speed road bike with rims brakes they are White Industries hubs laced to H+Son rims (because the Hard Ano Gray look so good) and those are certainly not really consumables in that same way if I do wear out the rims and I still have the bike I will probably just re-lace the hubs because I expect them to last for quite a while.
I personally don't see a need for DA for most modern things but I think Ultegra usually has looked better in most cases (except maybe 9 speed it diverged and of course 25th anniversary stuff looked fantastic) However I am not opposed to buying it if that is your thing but most people won't see that as your riding by at least not consumable wise but if out and out weight reduction and performance are on the menu and you have the money go for it. I have bought plenty of "stupid" things for my bike because I wanted them.
I say get what you can afford and makes you happy.
Likes For veganbikes:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
As you already figured out, Dura-Ace cassettes are very expensive and wear faster than Ultegra or 105.
For the rest of the consumables, the differences may be quite marginal and I make my choices based on inventory and sales prices, which are too variable to make a hard suggestion.
Don’t forget to splurge on top quality tires, obv.
Likes For datlas:
Quoted: 6196 Post(s)
Liked 4,811 Times
The only mark 105 has against it is that it's heavier than Ultegra for most of it's components. However in most cases 105 will function just as well. So if weight isn't an issue, the 11 speed 105 stuff works with the 11 speed Ultegra and Dura Ace if you need to mix and match stuff. You do need to watch spec's though. IE, the RD's between the groups don't always have the same max cog, front difference, max capacity and etc.
Likes For Iride01:
Clark W. Griswold
Liked 3,998 Times
+1 on the tires, good tires can make a ride a slightly different chain that might be lighter won't be noticed. I highly highly highly recommend the Vittoria Corsa G+ or 2.0 or Pro or whatever they are on now, some really fantastic tires or for a little more puncture protection the Rubino Pros or the Corsa N.E.X.T. are also fantastic.
Sunshine
Quoted: 10966 Post(s)
Liked 7,493 Times
1. Bottom bracket.
2. Chain.
3. Wheelset.
4. Pedals.
5. Cassette.
1. Bottom bracket.
2. Chain.
3. Wheelset.
4. Pedals.
5. Cassette.
Chain- shimano or kmc- there are multiple options at the Ultegra level and vary in cost. Just buy whatever is cheapest at that level. Hg601 and hg701 are basically the same weight. And I am not convinced the extra pink process for a 701 chain actually matters.
Wheelset- btlos or lightbicycle. Look into both. Pick your hub, pick your rim, pick your spokes.
You mention you like 9000 and 9100 wheels and typically get 40k mi out of them. First off, which wheels are you even talking about? There are probably 10 different wheels under the 9000 and 9100 lines. Secondly, those lines have been around for what...11 years? And you have gone thru enough wheels to have a 'typical' distance they last? And that distance is 40k mi? If you have even gone thru 2 wheelsets in that time, that's an instance amount of riding year after year. Thats 8,000 yearly for over a decade. Impressive. I wouldn't use 'typically' for anything fewer than 3 or possibly 4 examples of something, but even at 2 wheelsets that's impressive.
Pedals- who cares. Buy want you want. There is a 40g difference between 105 and DA. Oh, and an extra bearing for longevity/stability in the DA pedal. If that matters to you, then buy it.
Cassette- Ultegra or 105, whichever is cheapest at the time you are looking. DA is bonkers expensive for the differences.
Likes For mstateglfr:
Thread derailleur
Quoted: 367 Post(s)
Liked 461 Times
Good idea on the White Industries hubs. You're clairvoyant or something, as I own a pair on some older sewups.
Might be worth relacing to clinchers. Not a whole lot of miles on 'em. 28 spoke rear and 24 front.
Those beautiful Wheels Mfg bottom brackets ain't cheap! And it looks like it requires their special tool?
Any of y'all able to comment on Ultegra vs DA spd-sl pedals? Huge price differential.
The 105 cassette sure outweighs Ultegra! I generally like 11-30 to go with my 50/34 compact.
Likes For roadcrankr:
Thread derailleur
Quoted: 367 Post(s)
Liked 461 Times
Bottom bracket- Um...just buy one. They are like $15-35 depending on retailer, time of year, and sale. Pretty sure 105 and Ultegra BBs are the same.
Not the deep versions. 25 to 30, I think. My current 9100's surpassed 30k miles recently. Tough rims and never needed truing.
Liked 2,979 Times
i'd go 105 for cassettes, cranks, & chains. DA for front/rear ders... BB from the OEM (or whom they grab it from) hasn't shown me to be better than some of the established aftermarket sources.
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Liked 3,998 Times
Thank you, fellas. Yes, I never skimp on my tires. Corsas or Michelin Power always.
In terms of Wheels MFG they aren't cheap but they also aren't cheap in quality or construction. I cannot recall the tool but I feel like I just used a standard HTII tool like a Park BBT-9 or similar. Maybe for 30mm cranks you need something bigger but I am 99% sure it was just a standard Shimano 16 notch tool. They have gone through different iterations and I think they stopped doing the hybrid ceramic one which I believe might have been what I got at least according to my notes.
Brisvegas roadie
Bikes: 2013 Trek Domane 6.9 (SRAM Red-22), 2010 Colnago CLX 2.0 (SRAM Red 10-speed mix), 2013 Pinarello FP Uno (Campagnolo Athena 11-speed), 2009 Fuji Roubaix Pro (Shimano 105 10-speed), 2009 Colnago EPS (dream build, under construction!)
Quoted: 15 Post(s)
Liked 17 Times
Brisvegas roadie
Quoted: 15 Post(s)
Liked 17 Times
P.S. the next post about BBs is something I agree with too. There are so many good quality BBs from third party manufacturers out there, this is an area where it's worth shopping around without sticking to the same brand as the groupset.
Quoted: 4416 Post(s)
Liked 4,871 Times
The rest of my 11-speed 105 7000 group set has been fine.
Quoted: 1529 Post(s)
Liked 718 Times
My inclination is to save on drivetrain expense by changing out chains early, and treating chainrings and cassettes as something I don't want to replace. Chains are cheaper than the other drivetrain parts, and pivot pin wear (and thus chain elongation) is the main cause of wear on the other parts.
That way, you might be able to justify a steel Edco cassette, which is lighter and more durable than DA half Ti, and it should last ages if you swap out your chain before it shows significant wear. Your rings might last the life of the groupset.
Quoted: 682 Post(s)
Liked 453 Times
I just decided to finally switch from mechanical gears on my main road bike. My DA front mech is just not working well, in spite of doing my best to look after it. So the whole lot is getting switched out for Ultegra 8100 which I think kind of mandates Shimano HG+ chains. I’m lucky I can use a govt cycle voucher scheme here to get income tax rebate which brings the price right down. 40k miles sounds about right for wheels, the big downside of rim brakes. I never buy Shimano wheels or pedals. Hunt wheels are good value and Look pedals are just better imho.
Likes For Kimmo:
Quoted: 1109 Post(s)
Liked 1,200 Times
Hmm. I don't consider wheels and pedals to be "consumable" any more than the derailleurs, brakes, shifters, etc.
I'll be surprised if you actually "consume" your Dura Ace pedals or wheels.
Quoted: 682 Post(s)
Liked 453 Times
I guess you can replace both of those if you know what you’re doing. I’ve put new bearings in Look Keo pedals.
Liked 1,200 Times
Yeah, certainly. But every part of a bike can wear out.. Pedals and rims aren't in the same category as chains, cassettes, tires, etc. which are consumables. Just IMHO but don't belong in the issue of replacing consumables.
