How many people tour self supporting with a double crank
Old 08-15-15, 07:42 AM
azza_333
azza_333's Avatar
Bikes: Custom Carbon Fibre Ultegra Di2 touring bike
Quoted: 91 Post(s)
I am curious to know how many others out there go in unsupported tours with a double chainring crank.
azza_333 is offline
Old 08-15-15, 08:09 AM
BigAura
BigAura's Avatar
Bikes: all steel stable: surly world troller, paris sport fixed, fuji ss
Quoted: 600 Post(s)
Liked 22 Times in 15 Posts
I hardly use my large chainring on my triple
BigAura is offline
Old 08-15-15, 08:40 AM
staehpj1
staehpj1's Avatar
Quoted: 156 Post(s)
Liked 3 Times in 3 Posts
I did on the Southern Tier and it worked out quite well. My setup was a bit unusual though. It was an old 7 speed with a 12-28 cluster and a 39/26 on the crank. The crank was an "ultra compact double" made by leaving the big ring off of a triple. It worked out to a range of 25 to 88 gear inches and I was very happy with the setup. I should probably mention that I was self supported, camping and cooking, but packed very light. I was carrying less weight than a lot of folks who are credit card touring, so a 25 " gear was plenty low enough.
staehpj1 is offline
Old 08-15-15, 09:06 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
I @ LBS, have shipped back compact double crank bikes for riders who finished the 3000+ mile transcontinental US tours.
they rode Un-Supported.. carried their own stuff ..
fietsbob is offline
Old 08-15-15, 10:28 AM
Bug Shield
I toured with a double back when I was young and foolish.
Now that I'm enlightened, I run single-speed.
Bug Shield is offline
Old 08-15-15, 12:02 PM
robow
robow's Avatar
Quoted: 246 Post(s)
I haven't toured with a double for a long time but might consider it again since this winter I purchased a new crank, 46/30 from Sugino and with my 11-34 cassette on the back, that works out to a gear inch range of 113-23.5" Btw, this is actually a little lower gearing than one of my older touring bikes that had the standard Shimano triple of a 52/42/30 and 28t large cog in back.
robow is offline
Old 08-15-15, 03:22 PM
wahoonc
Membership Not Required
wahoonc's Avatar
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 66 Post(s)
I tour on a variety of bikes, some only have a single crank with a 3 speed hub that is about as low as I will go. I have seen more than one person touring on a single speed bike. Their choice.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Old 08-15-15, 04:07 PM
azza_333
azza_333's Avatar
Quoted: 91 Post(s)
What about any on road doubles?
azza_333 is offline
Old 08-15-15, 04:27 PM
staehpj1
staehpj1's Avatar
Quoted: 156 Post(s)
I have seen quite a few who were doing just fine on them. Some on coast to coast and other long tours with real mountains. Some even were carrying heavier loads and didn't have a really big cluster on the back. I'd consider a road double or compact double with a wide range cluster on the rear and a very light load. If I toured in flatter terrain I'd even consider regular road bike gearing, but since I tend to tour in the mountains and am in my mid 60s I do tend to need fairly low gears where it gets steep at all.
staehpj1 is offline
Old 08-15-15, 04:38 PM
azza_333
azza_333's Avatar
Quoted: 91 Post(s)
What do you consider a wide range 11-32? and what do you consider a very light load?
azza_333 is offline
Old 08-15-15, 04:46 PM
prathmann
Quoted: 657 Post(s)
Haven't done a trans-cont., but have done lots of shorter self-supported camping tours on my Cannondale road bike with 53/39 rings and a 7-spd 13/32 cassette.
prathmann is offline
Old 08-15-15, 04:57 PM
staehpj1
staehpj1's Avatar
Quoted: 156 Post(s)
Yeah, about that.
It varies a bit with the trip, but around or below 20 pounds including bags is starting to get into the range. I was carrying about 14 pounds of gear, bags, and clothing for the Southern Tier, but have trimmed some weight on a few items since then. I figure that I can camp and cook with 9-12 pounds of stuff even with moderately cold overnight conditions.
staehpj1 is offline
Old 08-15-15, 07:09 PM
dh024
Quoted: 92 Post(s)
I swapped out the double on my cx bike for a Sugino wide/low double (40 x 24t). It doesn't have much top end, but with an 11-32 cassette, it is geared plenty low for climbing with a full load (I pulled a 55 lb trailer around the Rockies last year).
dh024 is offline
Old 08-16-15, 06:16 AM
staehpj1
staehpj1's Avatar
Quoted: 156 Post(s)
If it shifts the big jump from 24 to 40 well enough, that sounds like a pretty sweet setup. My 39/26 with a 12-28 was adequate for a light load and your setup has more range on both ends. I'd think that would make it pretty versatile. Did it shift between rings pretty well?
staehpj1 is offline
Old 08-16-15, 07:02 AM
OldZephyr
Bikes: 1985 Trek 720, 2010 CAAD9-6, mid-90s Trek 750 hybrid (winter bike)
We host people on Warmshowers, and we have *lots* of younger people coming through on compact doubles, and many have cassettes in the 12-27 range. Some of them have said their knees hurt, but many say it's just fine.
The most amazing rig we've seen, however, is the one ridden by a delightful young man who went from Montreal to Vancouver in 34 days pulling a trailer on a fixie with a 53 front and a 19 rear cog. Amazing.
As for me, my first tours in the 70s were with a double crank -- triples weren't that common, or at least I didn't know where to get them -- and boy did my knees hurt. Changing over to a 26-36-40 triple with a 14-34 custom 6 speed freewheel gave me the low I needed, and even though the top gear was only around 78 gear inches, I was much happier, and this worked for me for years.
OldZephyr is offline
Old 08-16-15, 07:34 AM
andrewclaus
Bikes: 2016 Fuji Tread
Quoted: 219 Post(s)
Liked 17 Times in 15 Posts
In recent years I've dropped my self-supported load down to well under twenty pounds, barely noticeable on my old touring bike. My next bike, if I ever need one, can be a double if everything else is perfect. My last XC trip with a triple, I only used the small chain ring (26) a few times to get out of campgrounds on steep gravel. For the paved hills I encountered, my 36 x 28 was just fine.
A lot depends on your load, on the grades and surfaces you expect to climb, and how you and your knees do with sustained climbing. There are many levels of ability and physiology and your bike needs to meet your needs.
andrewclaus is offline
Old 08-16-15, 08:00 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
have you done your own research ? like on https://www.crazyguyonabike.com/
Anecdote: one of my companions on an AYH group-tour from SF to SD, on the California Coast , in 1986
Used the bike he brought from Norfolk England, it had a classic TA 50t, 28t double on his bicycle.
Freewheels were no higher than 13t back then.
fietsbob is offline
Old 08-16-15, 10:26 AM
GamblerGORD53
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 628 Post(s)
Liked 7 Times in 5 Posts
Single 46 or 48, or nothing. 16T Rohloff on tour, 22 to 120 GI. Sturmey Archer 5 for century rides, 45 to 116 GI.
I flew to Vietnam and from China. I took ALL the same clothes and shaver kit as I put in my suitcase on other trips and car+bike vacations. That's 35 lbs + 6 drinks + 12 lbs tool/spares stuff + 5 lbs copper stuff + 5 lbs coat/ rain gear + 8 lbs of pannier bags and bins + 4 lb locks + 46 lbs bike. And that was a hoteling trip.
GamblerGORD53 is offline
Old 08-16-15, 10:40 AM
nun
Bikes: Rivendell Quickbeam, Rivendell Rambouillet, Rivendell Atlantis, Circle A town bike, De Rosa Neo Primato, Cervelo RS
Quoted: 85 Post(s)
I use a 46x34 crank paired with a 12x36 cassette. But, IMHO, a mountain double makes the best front touring crank.
https://www.sram.com/sram/mountain/products/x9-crankset
nun is offline
Old 08-16-15, 11:02 AM
winston63
winston63's Avatar
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 116 Post(s)
Liked 5 Times in 4 Posts
I do self-supported tours on my AWOL with a 48/34 up front and an 11-36 cassette. It's worked out fine for me so far.
winston63 is offline
Old 08-16-15, 11:36 AM
mdilthey
mdilthey's Avatar
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
I tour self-supported with 15 pounds of stuff or less. I'm sure your question assumes self-supported riders will have much more.
If I were going to a truly inhospitable area, I still can't imagine having more than 40lbs.
My compact double is 34-46, and has a 11-32 cassette. For a long time, I toured with a single front chainring and no front derailleur, 38T, but the off-road hills were a problem so I threw a FD back on there. I'm in the big ring 85% of the time.
mdilthey is offline
Old 08-16-15, 12:01 PM
Rob_E
Rob_E's Avatar
Bikes: Downtube 8H
Quoted: 258 Post(s)
Liked 7 Times in 6 Posts
My tours are short, a week at most, and no mountains (yet). I was running a Nuvinci hub with a compact double. After a while I realized I was only using one chainring, so I removed the derailer. Around town I would use the big ring, and if I was hauling a load, I would manually move it to the small ring. Then I got the new version of the hub, and I was having trouble getting the big ring to work with the narrower chainline, I went to one ring. Now I'm running an Alfine 8. I'd like a little more in the upper range for riding around town, but I'm guessing the small ring will do the trick when I'm touring.
Rob_E is offline
Old 08-16-15, 02:57 PM
alan s
alan s's Avatar
Quoted: 1321 Post(s)
Liked 45 Times in 29 Posts
I recently did a 5-day trip with moderate hills, and was fine with 50-34 11-32. For mountains, I'd prefer lower gears.
alan s is offline
Old 08-16-15, 09:24 PM
Mongoeric
I toured from Vancouver to San Francisco on a compact 50/34, 11/36. Self supported with tent, sleeping bag and portable cpap machine. In addition, I'm a big guy! A lot of mashing, though by nature, I'm a spinner. Didn't have to walk the bike once. My son who went with me had a touring triple. I spent hours watching him spinning in front of me, coveting a touring triple.
When I got back I quickly converted to a Sugino touring triple. This summer I went from Quebec City to Perce on the Gaspe Peninsula, same gear self supported. Lots of 15+% grades. Even with the triple I had to walk. One young buck has a compact road double and I can't count the times he said that he had to get a triple.
I think it matters a lot on where you are going, how much you are carrying, both luggage and dead weight, and the size of our engine.
Mongoeric is offline
Old 08-17-15, 01:54 AM
djb
Quoted: 1090 Post(s)
Liked 38 Times in 30 Posts
Mongoeric, truer words have not been spoken. Your last bit.
And yes, gaspe is a bugger of a route. Did me in, or one of my knees, in about 1990 , with the combo of too much weight, too high gearing (with a triple) some too long and steep hills as you mention, and a weak engine.
djb is offline
