Surly Disc Truker Tubing Wall Thickness
Old 09-07-15, 04:27 PM
john hawrylak
john hawrylak's Avatar
Bikes: 1975 Schwinn Voyageur II (Made by Panasonic), 1988 Schwinn Voyaguer (touring)
Quoted: 9 Post(s)
Anyone know the wall thickness of the 4130 tubing Surly uses in the main triangle of the Disc Trucker?? I know the diameter is OS.
john hawrylak is offline
Old 09-07-15, 07:13 PM
niknak
Quoted: 55 Post(s)
You're probably looking at .9/.6/.9 butted tubes, but it's very possible that the LHT runs straight gauge. That thing is a tank. Best way to find out is to email them.
niknak is offline
Old 09-08-15, 09:04 PM
vik
cyclopath
vik's Avatar
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
A Google search comes up with .8/.5/.8 for the LHT. Post is from 2011 so worth checking with Surly if the DT is different. I suspect the main triangle on the LHT and DT are the same.
safe riding - Vik
VikApproved
vik is offline
Old 09-09-15, 04:33 PM
john hawrylak
Quoted: 9 Post(s)
Vi
Thank you very much
Old 09-09-15, 05:21 PM
Brian25
Bikes: Road, mountain and track bikes and tandems.
Quoted: 238 Post(s)
I have retrofitted a few Surley's, with my take apart frame system. Using dial calipers the wall thickness is actually much thicker than previously reported. As I remember it was more like 1.6 mm. I measured at the thicker "butted" part of the tube, so I can't say what the thickness was for the mid (thinner)and if it was butted. If the frame was .8/.5, A Surley frame would be about four pounds, instead of the boat anchor weight that they are known for.
Brian25 is offline
Old 09-10-15, 06:02 AM
engineerbob
engineerbob's Avatar
Quoted: 15 Post(s)
According to Surly's web site, the main triangle is double-butted.
engineerbob is offline
Old 09-10-15, 04:01 PM
MassiveD
Quoted: 31 Post(s)
969 or straight would make most sense. As a welded frame and rugged I would pay extra for straight. Don, t know the spec though.
MassiveD is offline
Wheels Of Steel
Classic & Vintage
108
11-19-17 09:34 PM
NickFavicchio
Classic & Vintage
11
05-12-17 08:15 PM
jrennie
Road Cycling
28
02-21-08 08:34 AM
djn3454
Mountain Biking
8
08-01-06 10:43 PM
