Road Ti Bikes + 28 to 35 mm Tires?
Old 11-15-17, 12:02 AM
city_cowboy
Quoted: 49 Post(s)
I was taking a look at value leader Motobecane Ti road bikes. Pretty phenomenal pricing for Dura Ace or Etap.
However, the frame cannot accommodate 28 mm tires. I want a minimum of 28mm, and preferably the option to fit larger, 32 or even 35 mm.
Are there any endurance or race Ti frames which can accommodate wider tires? I've checked Lynskey and Motobecane so far and neither can accommodate wider tires.
city_cowboy is offline
Old 11-15-17, 12:27 AM
twodownzero
Bikes: Surly Disc Trucker, Ribble Nero Corsa
Quoted: 186 Post(s)
there have been two threads on the forum about the Lynskey R260 in the last week. I even asked for pictures of the tire clearance!
twodownzero is offline
Old 11-15-17, 12:42 AM
SethAZ
SethAZ's Avatar
Bikes: 2018 Lynskey R260, 2005 Diamondback 29er, 2003 Trek 2300
Quoted: 383 Post(s)
These pics are of frame or fork clearance around a Compass 32mm Stampede Pass tire mounted on a Lynskey R260. Inflated to 83psi the rear tire measured out to 33.25mm real width on the Grail rim.
The R260 ships with the Lynskey Pro Carbon Gravel fork:
I didn't measure it with a ruler, but eyeballing it there's around 3/8" (10mm) of space between the sides of the 32mm tire and the chain stays. I didn't take a pic showing the specific offset from the seat tube, but it's similar, and could fit a much taller tire.
SethAZ is offline
Old 11-15-17, 12:44 AM
superdex
staring at the mountains
superdex's Avatar
Bikes: Fairdale Goodship, Spesh Crux
Quoted: 277 Post(s)
Liked 19 Times in 15 Posts
regardless of frame material, if you're looking for more than 28mm tires, you're pretty much looking at discs. Plug that into your searches and you might be more successful...
superdex is offline
Old 11-15-17, 07:29 AM
fa63
fa63's Avatar
Bikes: A couple
Quoted: 38 Post(s)
Kinesis Racelight Grandfondo:
https://www.probikekit.com/cycling-f...Fct7wQodlskBxw
It says it fits 28 mm tires with fenders; I imagine 32 mm tires without them would work just fine.
fa63 is offline
Old 11-15-17, 07:43 AM
WhyFi
WhyFi's Avatar
Quoted: 8860 Post(s)
Liked 121 Times in 69 Posts
Originally Posted by city_cowboy View Post
...or even 35 mm.
An endurance frame that can accommodate 35s is gravel bike - you should be able to find a decent selection in Ti.
WhyFi is offline
Old 11-15-17, 08:49 AM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '05 Novara Big Buzz, '12 Mercier Nano, '95 DeKerf Team
Quoted: 1026 Post(s)
Foundry Overland can take 41c, the Chilkoot 28s.
There's Van Nicholas' Amazon Cross, too; that's gotta clear 35s, I'd think.
chaadster is offline
Old 11-15-17, 11:38 AM
carlos danger
carlos danger's Avatar
Bikes: steel is real. and so is Ti...
Quoted: 213 Post(s)
Liked 22 Times in 18 Posts
look at the cooper frame and/or proX, those can accommodate 40ies i think.
carlos danger is offline
Old 11-15-17, 11:56 AM
SethAZ
SethAZ's Avatar
Quoted: 383 Post(s)
Originally Posted by MichaelSneddon View Post
Ultimately the blast media you select will have a big impact on how fast you can remove powder coating. If you will be recovering your blast media aluminum oxide will be fastest while steel grit will be fast but a bit more cost effective. If you will not be recovering the blast media then crushed glass is a great blast media for removing power coating.
Huh? Quoting so that you get a message. Wrong thread. Interesting though.
SethAZ is offline
Old 11-15-17, 12:53 PM
Dean V
Quoted: 781 Post(s)
Liked 18 Times in 13 Posts
Domane disc will take 35s. Its not usually referred to as a gravel bike.
Dean V is offline
Old 11-15-17, 01:13 PM
markjenn
Quoted: 127 Post(s)
Dunno if you want to build up a bike, but Habanero's cross Ti frame can be set up with several different forks that have 45mm+ capability and there is no issue in the rear. Mine has a Ti fork from an old Everti and I absolutely love this bike as a general-purpose road touring bike and gravel bike. Not the lightest, but easy handling and very comfortable. And the frame is reasonably priced for Ti.
https://www.habcycles.com/cross.html
- Mark
markjenn is offline
Old 11-15-17, 01:20 PM
twodownzero
Quoted: 186 Post(s)
- Mark
If they made one I could stand over, I'd be tempted to order one right now. I don't know where they would find a rider that needs a 510mm top tube length who can stand over a top tube that is 780mm from the ground, but when you find me one of those people, you can sell me on their bikes.
From the looks of their geometry, this is really just the consequence of them not scaling their design for the different sizes.
Old 11-15-17, 01:38 PM
markjenn
Quoted: 127 Post(s)
Well, I'm not an expert on bike frame dimensions, but at 6-2" and with fairly normal proportions, I've never had a bike fit better than my 59cm Hab and I've done several multi-week tours with days approaching 100 miles with no comfort or bike handling issues. Standover seems more/less normal with other road bikes I have with level (or nearly level) top tubes. YMMV.
- Mark
markjenn is offline
Old 11-15-17, 01:42 PM
PedalingWalrus
PedalingWalrus's Avatar
Bikes: Surly Ice Cream Truck, Surly Disk Trucker, Salsa Warbird, Salsa Beargrease
Quoted: 259 Post(s)
Liked 7 Times in 6 Posts
I bought a used Ti frame of Salsa Warbird and built it up.
PedalingWalrus is offline
Old 11-15-17, 01:54 PM
SethAZ
SethAZ's Avatar
Quoted: 383 Post(s)
Another drive-by OP who never came back to see what others had offered up to their original question. Sigh.
SethAZ is offline
Old 11-15-17, 03:21 PM
WhyFi
WhyFi's Avatar
The Domane Disc Gravel, you mean?
WhyFi is offline
Old 11-15-17, 03:28 PM
Quoted: 8569 Post(s)
Liked 327 Times in 206 Posts
And you know that how? His last forum activity was within the last hour. Maybe he read the responses and is doing some research based on those responses. And the thread isn't even 24 hrs. old.
BTW...Your front tire has a cut in it.
Old 11-15-17, 03:48 PM
SethAZ
SethAZ's Avatar
Quoted: 383 Post(s)
If you're looking at what I think you're looking at, that's actually a shadow cast by a scrap of the flash that hasn't worn off yet. The tire is brand new plus 45 miles so far, and some of the flash is still there. The sun was still pretty low when that photo was taken, so the shadow is longer than the actual flash that cast it.
SethAZ is offline
Old 11-15-17, 04:33 PM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Bikes: BMC SLR01 TeamMachine Disk Di2; OPEN new U.P. Di2
Quoted: 797 Post(s)
Liked 17 Times in 13 Posts
Lynskey has a whole list of road bikes that will accommodate 32mm and wider tires. I ran 38mm on mine and had plenty of clearance.
But, as has been mentioned, you've got to look at the disc brake bikes.
FlashBazbo is offline
Old 11-16-17, 11:03 AM
gettingold
Bikes: 2018 Lynskey R 260 Disc; 2008 Trek 4.7 Madone; 2017 Framed Minnesota 3.0 Fat Bike; 1984 Nishiki International
Quoted: 111 Post(s)
Lynskey R 260 Disc. Easily accommodates 32mms and probably bigger.
gettingold is offline
Old 11-16-17, 11:26 AM
Wittyname
Some Guy on the Road
Wittyname's Avatar
Bikes: Foundry Chilkoot, Trek Domane
Quoted: 41 Post(s)
Chilkoot won't take all 28s... got rub when I tried Continental GP4000 IIS on the stock rims. Bontrager AW2 works just fine though
Wittyname is offline
Old 11-16-17, 07:37 PM
matt92037
Quoted: 28 Post(s)
My new Lynskey R275 easily fits a Pro One 28 that measures out at 30mm. Using calipers I measure the narrow area where the chain stays and tire converge at about 38mm or so.
I do not see myself ever running bigger than 28’s ever. Any and all dirt work is left for my MTBs.
matt92037 is offline
Old 11-16-17, 08:15 PM
thedave80
thedave80's Avatar
Quoted: 7 Post(s)
My Lynskey Cooper takes up to 40 ad has been excellent on 28's as a road bike. Only downside is it's a bit heavier than a straight up road bike
thedave80 is offline
Old 11-16-17, 10:07 PM
vintagerando
Quoted: 430 Post(s)
Liked 17 Times in 14 Posts
I wonder if a mid 90s Merlin will take 28mil. I have my eye on one; its out of state, so I cannot determine for sure if it will work. Any Merlin owners running 28mil?
1967 Frejus
1968 Peugeot PX-10
1983 Peter Mooney
1995 Waterford 1200
1996 Waterford 1200
2003 Dahon Speed P8
2013 Rawland Stag
2016 Giant Defy Advanced Pro 0
vintagerando is offline
Old 11-17-17, 03:07 AM
carlos danger
Quoted: 213 Post(s)
I have a medium cooper cx from 2015 i think. and it takes 35mm with fenders, but I think I can fit 40ies with fenders if I really wanted to.
the newer coopers and proX will most definitely take 40ies.
my cooper weighed in at 1700g (medium) and I measured a proX here recently and it came in at 1850g for the same size, but this one has plate style driveside chainstay and tapered headtube, twisted tubes, triangular toptube, swappable dropouts. I have a feeling those "features" is whats driving the weight up.
