Di2 questions
Old 02-24-18, 09:15 PM
MikeOK
Yo
MikeOK's Avatar
Bikes: 2003 Yeti AS-R, 2018 Waltly ti
Quoted: 427 Post(s)
Di2 questions
Hi all, I have ultegra Di2 on my road bike and I have the SM-BTR2 battery. Which battery do I need to get so I can set up synchronized shifting? And I would like to use my iPad with the etap software over Bluetooth, what would I need to accomplish that? Thanks!
MikeOK is offline
Old 02-24-18, 09:57 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1178 Post(s)
Liked 43 Times in 30 Posts
Awesome! I as well also have UDI2 (and now am playing with synchro shift) on one of my road bikes and love it. You would need the BT-DN110 and assuming you have 6870 (or whatever the 6800 UDI2 number is) you should be able to go into E-Tube software and set it up (though you might need to update your software which you should generally do from time to time anyway) for the wireless E-Tube set up you need the EW-WU111 (they made another one EW-WU101 but I think they stopped) and a short E-Tube wire. I set mine up through my seat tube and just plugged straight into the battery. However I think they recommend doing it externally.
I an pretty sure the SM-BTR2 is non-compatible with Synchro shift but I am not 100% on it. I know it is not compatible with the Wireless D-Fly unit. Also one last useful note USE THE E-TUBE WIRE TOOL (TL-EW02), pliers and other objects are rough on the wires and the tool works so well I see no need not to use it. We are talking DI2 not Tourney here ; )
I am a geek so that is why I went wireless but honestly I didn't really need it, I don't feel the need to play with my DI2 set up often it is just fun to have the option. Not trying to discourage you just putting that out there.
veganbikes is offline
Old 02-24-18, 10:32 PM
MikeOK
Yo
MikeOK's Avatar
Quoted: 427 Post(s)
Thanks vegan, I was pretty sure my current battery wouldnít allow synchro shift. My battery is in my seatpost, could I put the wireless unit in series with the wire that connects to the battery? Oh and I do have the little tool but I found that it was easier to just use my fingers. I was skeptical at first about di2 but after having it for a couple thousand miles I canít imagine life without it. I have 2753 miles on it so far and Iíve not had to adjust it ever, not one single time. And Iíve only charged the battery twice and both times it was still at 50%!
MikeOK is offline
Old 02-24-18, 11:04 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6444 Post(s)
Liked 356 Times in 232 Posts
The wireless unit can go in series with the battery. That is how mine is set up, inside the seat tube, wrapped in some foam so it doesn't rattle around.
The components don't care where they are plugged in. As long as everything has a way to connect back to the battery it will all work.
-Tim-
TimothyH is offline
Old 02-25-18, 09:45 AM
metalheart44
metalheart44's Avatar
Bikes: Holland Exogrid & Holland HC
Quoted: 71 Post(s)
I am thinking of doing the same thing and my current battery is in the seat tube. My bike is Ti and I am wondering if there are any issues in putting the wireless unit in series with the battery in the seat tube?
metalheart44 is offline
Old 02-25-18, 10:09 AM
MikeOK
Yo
MikeOK's Avatar
Quoted: 427 Post(s)
I was wondering this too. Will being in the seat tube of a ti bike affect the Bluetooth signal?
MikeOK is offline
Old 02-25-18, 04:06 PM
Steve B.
Bikes: Flyxii FR322, Soma Smoothie, Miyata City Liner, Specialized FSR Comp, Fuji Professional
Quoted: 1083 Post(s)
Liked 24 Times in 17 Posts
Iíve no clue as to the signal damping qualities of titanium, but the rub is if it doesnít work, itís a ***** to trouble shoot.
Thus and on a metal bike, Iíd likely be putting the WiFi unit right off the A Junction.
Steve B. is offline
Old 02-25-18, 06:51 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
There will be no issues with putting the wireless unit inside the seat tube of any bike. Steel, aluminum, titanium, carbon - it doesn't matter. It will work fine.
There are people who run them inside the stem, inside the downtube, shoved up into the bottom bracket area, etc. It isn't a problem.
Just leave the wire from B junction to the wireless unit long enough so that the seatpost can be removed without having the wire drop down the seat tube. The end can be secured to the frame with a piece of tape for servicing the battery, saddle or seatpost off the bike. I had to reboot my system by disconnecting the battery once so removing the battery is not out of the question.
-Tim-
TimothyH is offline
Old 02-25-18, 07:36 PM
MikeOK
Yo
MikeOK's Avatar
Quoted: 427 Post(s)
TimothyH I like the stem idea, but how would you get it in there?
MikeOK is offline
Old 02-25-18, 07:43 PM
Steve B.
Stems, bars and forks now being designed for Di2 cabling.
Here’s a quote from the Pro Vibe review
“The Vibe handlebar has an exit hole at the rear which allows the battery cable to travel from the bar, through the stem body, and out of the hole you see above the steerer clamp in the photo. This means that if you use a fork steerer-mounted Di2 battery, everything is hidden from view.”
Steve B. is offline
Old 02-26-18, 12:23 PM
veganbikes
Clark W. Griswold
I have a a Ti bike and wireless is in the seat tube and no real issues. Now I do tend to be close to the bike when doing it and haven't been able to do it from a significant distance like say a bluetooth speaker but I don't really mind.
Old 02-26-18, 01:29 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Mine is in the seat tube.
If I had to do it over again I would have saved the $85 and not used wireless. I never use it.
-Tim-
TimothyH is offline
Old 02-26-18, 02:06 PM
superpletch
faster downhill
superpletch's Avatar
Bikes: more than my wife can keep track of
Quoted: 142 Post(s)
i have the new 9170 di2 setup with battery and ant wireless unit in seatpost and it works great. I love the wireless setup because I dont have a Microsoft computer, only apple, and shimano is not supported on apple products unless you have wireless connection and an app on your iphone or ipad. Also the new shimano shifters have extra buttons on top and with the wireless I can control my garmin which is quite handy.
di2 is awesome for its 100% consistency and crisp shifts with only the touch of a button like shifter. shifting to the large chainring on my 105 shifters now seems quite different.
superpletch is offline
Old 02-26-18, 04:13 PM
MikeOK
Yo
MikeOK's Avatar
Quoted: 427 Post(s)
I was wondering what improvements they had made. I have an old (very old) windows machine but I wonder if it will even boot up. I only have an iPhone and iPad thatís why I wanted wireless. I had my di2 on a carbon bike for over 2700 miles and I didnít have to adjust it one single time. In fact, when I moved it to my new ti bike I had to look up on the internet how to adjust it lol. Itís so easy I fine tuned it today without even stopping. 2800 miles on it now and Iíve only charged it twice and both times it was still at 50%
MikeOK is offline
Old 02-26-18, 09:53 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Keep in mind that as of January 2018, the iPhone version of E-Tube does not have error check.
Error check requires the iPad version.
There was a thread recently.
-Tim-
TimothyH is offline
Old 02-27-18, 06:51 AM
superpletch
faster downhill
Quoted: 142 Post(s)
[QUOTE=MikeOK;20192911]I was wondering what improvements they had made.
not sure of the improvements because this is the first di2 I've owned. I know the new Ultegra shifters have the buttons on top that can be set up to do lots of different things (shift derailleurs, control lights, control garmin etc.) this is very handy when riding on the hoods or controlling garming in the winter with gloves on. I also think there are weight savings over previous models. I think software is compatible with anything 6000 model and up.
Old 03-02-18, 08:28 AM
matt92037
Quoted: 28 Post(s)
I am also running 9170. I went with Pro Vibe carbon bars which have excellent internal routing. I run the bar-end junction box and placed the Bluetooth unit in the bar end just in past the junction. Pretty clean that way.
matt92037 is offline
Amabanana
Mountain Biking
1
12-11-14 01:54 PM
stuntmatt
16
10-21-11 08:23 AM
Bob S
Fifty Plus (50+)
4
04-03-08 04:21 PM
Chuck999
Road Cycling
36
05-17-07 07:18 AM
gonesh9
General Cycling Discussion
0
03-14-03 12:22 AM
