Gas generator powered ebike with AC motor?
Old 07-30-18, 02:20 PM
toeofawesome
Where I live there is a restriction on Ebikes to 750 watts or 1 hp. I just so happen to have a 1hp 120v AC motor. Heavy duty rated for continuous use. So in theory can I plug that motor in to a small cheap gasoline generator, and use it to power a bike or trike? Im planning to just skip the whole battery thing, and run it direct. Can anyone see any problems i may have with this setup? I intend to use this for longer distance camping/hunting trips. to haul gear and whatnot.
toeofawesome is offline
Old 07-30-18, 02:46 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1210 Post(s)
Liked 76 Times in 51 Posts
I would guess there are restrictions on using gasoline engines also, even indirectly.
(please correct me if I'm wrong.)
tyrion is offline
Old 07-30-18, 03:47 PM
CliffordK
CliffordK's Avatar
Quoted: 8520 Post(s)
Liked 77 Times in 69 Posts
Hmmm...
It probably would work.
I'd look for a good 3 phase motor and 3 phase variable frequency drive.
But, the whole gas/electric system seems a bit redundant. One option would be to make it like a hybrid, with the generator charging the battery which runs the motor. Thus you can run the generator at a constant rate, and use a bit more or less power as needs require.
Running it at times in full E-Bike mode would get around complaints that it is a gas bike with a electric coupled transmission.
CliffordK is offline
Old 07-30-18, 04:08 PM
2old
Quoted: 211 Post(s)
Liked 8 Times in 7 Posts
+1 with CK, but watch out for the "greenies" who might point out that you are using an inefficient gas engine to charge a battery (probably somewhat inefficiently) to power an electric motor relatively efficiently (85% or so if the data are correct). Please note this analysis is from a Chemist, not a smart person.
2old is offline
Old 07-30-18, 04:32 PM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 399 Post(s)
Liked 47 Times in 40 Posts
I considered this myself and couldn't see a legal issue. There is no law against carrying a generator. There is no law stating how your e-bike get's it's electricity. The law states the bike must be powered by the electric motor, it must be 250watts, pedal assisted, and restricted to 15.5mph in the UK. The generator is not propelling the vehicle itself.
Generators are quite weighty, given the amps you'll need, and i struggled to find one that'd put out the required wattage for that ampage. If you can find one small and light that'd do 20A at 24v then that'd probably be the best route, as finding 36v is likely to prove trickier.
MikeyMK is offline
Old 07-30-18, 05:14 PM
CliffordK
CliffordK's Avatar
I have played around with generators in the past.
I think there are some small 350 to 500W generators. 2 cycle? 4 cycle? They are light and compact.
Of course, 1 HP continuous will require somewhere between 1KW and 1.5 KW. But, intermittent with battery, it should be able to use a bit less.
One issue I ran into with small generators is that their DC output was generally very limited. Maybe 8A, 12V. One had to use 110V (or 220V) to get their full output power. And, thus more power conversion to whatever the battery bank requires.
Old 07-30-18, 05:53 PM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 381 Post(s)
I read the whole thread, and amazed at the many posters failed to read: " I .... have a 1hp 120V AC motor." So you are looking for a generator system that puts out ~10A @ 120V .; which are very common in the USA.
How do you plan on controlling the output of the motor? What style of AC motor is it? ref: https://en.wikipedia.org/wiki/AC_motor
There are almost as many control types as there are types o AC motor. Some are practical for use in powered vehicles.
Advantages of having batteries:
* you don't need to run the ic engine all the time.
* you can get away with a smaller generator because it is highly unlikely that you will be going flat out all the time (the police would notice you racing along at over 30mph).
* reference: research studies on the optimal size for a hybrid vehicle's battery system.
A BLDC motor (very common for ebike use) is a sort of AC motor, it is fed 3 phase variable frequency AC, usually synchronized by Hall effect sensors. It can just as easily be fed 50/60 Hz three phase and would spin at a constant speed.
nfmisso is offline
Old 07-31-18, 07:05 PM
toeofawesome
I have no idea specifically what kind of motor it is. i know its single phase, AC and 120v. Plugs into a wall outlet so i figure it can run on a genny. I plan to gear this very low. 10mph Max. This isn't an in town commuter. its more of a mechanical mule i can legally take places i can't take my moped/scooter, which is my main form of transportation. A Hunting/Camping tool. like an ATV For places ATVS aren't allowed, but bikes are. Hoping to get away with a simple On/Off switch, engaging once i pedal up to speed, like a car transmission. or some kind of dimmer switch.
Old 08-01-18, 02:03 PM
nfmisso
Nigel
nfmisso's Avatar
Quoted: 381 Post(s)
I have no idea specifically what kind of motor it is. ........
Until you determine this, and then learn how control that type of motor, the project is not going anywhere.
How fast does the motor spin? Is the speed frequency dependent? Many AC motors are rated for just under 3600 rpm (like 3450) at 60 Hz and just under 3000 rpm at 50 Hz. The just under is because they slip to produce torque, the output speed is dependent on the torque taken from the motor, it will try to get to its sync speed (for example 3600 rpm at 60 Hz, but it produces no torque at that speed).
To go ~10 mph, you need to spin the wheel at about 120 rpm; 30:1 gearing is non-trivial. It would be less expensive to purchase a hub motor wheel kit than a 30:1 reduction system that will survive the torque required for meaningful assist on a bike.
nfmisso is offline
Old 08-02-18, 06:59 AM
unterhausen
Randomhead
Liked 33 Times in 30 Posts
that's really not a suitable motor for speed control. It can be done, but it's not going to be light or cheap. Far better to get a retrofit kit that is made for purpose. I have worked in motor control and have a collection of small brushless motors and I have considered trying to use one of them. But it's just not worth it with the systems I can buy that already have all the engineering done.
I also don't think the power source is the important part of the legal power limit. So just because it's coming from a generator doesn't mean you can cheat on the limit. If I were really worried about it, I would just take the name plate off of it. You probably aren't going to get 1hp out of that motor anyway.
unterhausen is offline
Old 08-02-18, 02:04 PM
WillAdams
Bikes: Montague Swissbike X50
Quoted: 9 Post(s)
Not quite the same, but this was recently posted to a popular site which bills itself as "the front page of the internet" (original at: http://www.jankyshack.com/wp-content...801_151622.jpg ):
WillAdams is offline
Old 08-02-18, 07:23 PM
CliffordK
CliffordK's Avatar
If you enter a trail system that posts "no motorized vehicles"...
You might get away with a pure E-Bike.
If someone hears your gas powered bike motoring down the trail, you will get reported to the local forest rangers or local law enforcement.
I'd also be annoyed if I had hiked 10 miles in, and some showed up with a noisy generator (and E-Bike).
Old 08-02-18, 07:29 PM
CliffordK
CliffordK's Avatar
When I was driving an electric vehicle for a while, I did start thinking about a gas generator as a range extender.
My idea was to just fix up a small trailer with a small gas or diesel generator that generated, say half the power my pickup consumed.
So, say I had a range of about 50 miles. By using the 50% generator, I could likely push that 50 miles to 100 or so pretty easily. There would be less of a chance of getting stuck with a dead battery, and overnight, I could do a full recharge.
If you had a camping E-Bike. Then around town, just use the E-Bike. When you're ready for an overnight trip, grab the trailer and take off. Camp at the trailhead and fully charge. Then head out into the mountains, battery only. On your way out, camp at the trailhead again, recharge, then head home.
A small solar panel may also help.
Might as well also add an auxiliary battery and fuel tank to your range extender trailer.
Old 08-07-18, 08:37 AM
nasabiker
Quoted: 38 Post(s)
my eyes are bleeding from the mere sight of that ....thing
nasabiker is offline
Old 08-07-18, 01:27 PM
nfmisso
Nigel
nfmisso's Avatar
Quoted: 381 Post(s)
My idea was to just fix up a small trailer with a small gas or diesel generator that generated, say half the power my pickup consumed........
Like this: Mr.Sharkey's Pusher Trailer ?
nfmisso is offline
Old 08-07-18, 02:04 PM
CliffordK
CliffordK's Avatar
Originally Posted by nfmisso View Post
Similar idea.
I think a pusher trailer pushes.
A generator trailer supplies power to the battery/electric motor.
I think pushers are not uncommon for heavy cargo bikes, but I'm not sure I'd want to use one on a lightweight bike.
Old 08-11-18, 12:46 AM
Leisesturm
Quoted: 1236 Post(s)
Liked 18 Times in 17 Posts
A small solar panel may also help..
It would not. A very large solar panel. Like an entire roof top worth of surface area, now you are talking. If the o.p. wants a range extender, the most practical idea is to use the trailer to carry extra battery capacity. Most generators are not built with mobility in mind so they are unnecessarily heavy. A motor designed for 110V AC is also not going to be a willing participant in the project. It will not have the proper hardpoints to be mounted on the bicycle, or on the trailer for that matter, and it will be twice as heavy as it needs to be. Overweight generator+ overweight motor+ kludgy drive system = failure.
Leisesturm is offline
Old 08-13-18, 07:47 PM
7up
7up's Avatar
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 23 Post(s)
There is a legally blind gentleman on YouTube with a trike similar to what you would like to do.It is custom built so he can go long distance without the need of a license since it only does the federally allowed speed limit.
7up is offline
Old 08-17-18, 02:16 AM
Trevtassie
Quoted: 317 Post(s)
Liked 35 Times in 17 Posts
Good chance that is a squirrel cage motor, in which case the start up current will be higher than the running current, so your generator would need to be twice as big as the motor rating would suggest...
Trevtassie is offline
Old 08-22-18, 02:57 AM
mikster
LOL wow!
mikster is offline
Old 08-22-18, 03:07 AM
Bang0Bang00
41 calories/30 min typing
Bang0Bang00's Avatar
Quoted: 32 Post(s)
Pffft! This is a great idea! 49cc scooters are way too practical, along with ebikes that qualify.
I've got a small coal burning oven. Where can we fit this in?
Bang0Bang00 is offline
Old 08-22-18, 05:36 AM
unterhausen
Randomhead
Number one rule of bicycle design is that every possible bicycle-related invention already exists, regardless of merit. Colin Furze made a jet powered bicycle, and you can find youtubes of a steam powered bicycle made in the last few years.
Old 08-22-18, 12:14 PM
Bang0Bang00
Quoted: 32 Post(s)
Yeah, but clean coal is the future! The FUTURE! I tells ya!
Old 08-23-18, 06:50 AM
unterhausen
Randomhead
I'm reasonably sure the steam bike is powered by coal. Jet is powered by propane, but coal slurry has been used as a jet fuel in the past.
Old 08-23-18, 01:16 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
Lightbulb
On the river shore we have an old electric trolley ,
but without the overhead electric power lines,
it has a motor-generator, car , pulled in one direction ,
pushed in the opposite direction..
fietsbob is online now
